A modest proposal...
A modest proposal... Noel Stoutenburg 05 Sep 07:18
  A modest proposal... Mikael Magnusson 05 Sep 08:45
   A modest proposal... gg@catking.net 05 Sep 09:48
Noel Stoutenburg
2011-09-05 07:18:42 UTC (over 13 years ago)
Friends,
...or maybe not, since I don't know the code involved. But may I suggest rearranging the left most pane in the dialog windows for the file operations "open" and "save as"?
Presently, when I use either operation, and want to access a location to which I have a bookmark, I'm obliged to scroll down the screen in the left most pane; what I'd propose is to move the bookmarks (if any exist) to the top of the pane, just below the "recently used" entry.
Or, have I missed a setting somewhere that would let me configure the order in which the items in this pane are listed?
ns
Mikael Magnusson
2011-09-05 08:45:54 UTC (over 13 years ago)
On 5 September 2011 09:18, Noel Stoutenburg wrote:
Friends,
ns _______________________________________________ Gimp-developer mailing list
Yes, it's stupid, but it's not gimp's fault. You can rebuild your gtk+ with this patch
http://mika.l3ib.org/patches/gtk-filechooser-only-File-System.diff or modify it to your liking, the code is fairly obvious.
gg@catking.net
2011-09-05 09:48:50 UTC (over 13 years ago)
Friends,
Thanks for that patch. I fixed this annoying mess of irrelevant "bookmarks" that I never requested spamming the interface in 2.6.something but it no long applies cleanly. You saved me the effort of fixing it again. :)
Anyone who finds this annoying please bug report to gtk+ (rather than here) . I did open a bug and submitted the patch but it spat out as per usual .
If they realise this is unpopular maybe it will get some traction.
regards.
