tool presets
13 of 13 messages available
tool presets Alexandre Prokoudine 05 Sep 03:38
  tool presets Liam R E Quin 05 Sep 04:51
  tool presets Martin Nordholts 05 Sep 05:00
   tool presets Alexandre Prokoudine 05 Sep 05:09
    tool presets Martin Nordholts 05 Sep 05:24
     tool presets Alexandre Prokoudine 05 Sep 05:40
  tool presets Alexia Death 05 Sep 05:29
   tool presets Martin Nordholts 05 Sep 07:03
    tool presets Alexia Death 05 Sep 07:37
     tool presets Martin Nordholts 05 Sep 08:30
      tool presets Alexia Death 05 Sep 08:36
       tool presets Michael Natterer 05 Sep 10:25
        tool presets Alexia Death 05 Sep 11:15
2011-09-05 03:38:52 UTC (almost 14 years ago)
tool presets
We currently have the new Tool Presets dockable dialog that has zero factory preset. Maybe we should should opulate it a bit? Some cropping presets for popular photo paper formats, DVD and whatnot? Steal some presets for painting tools from G-P-S?
Oh, and will those be translatable?
Liam R E Quin
2011-09-05 04:51:29 UTC (almost 14 years ago)
tool presets
Can you bind presets to keystrokes? If not, I don't think it's worth it.
A minimum of three clicks to choose a preset (assuming the dialogue is docked but not on top) means it'll only be a win for fairly specific settings, and those are more likely to depend on the user/task/project.
Martin Nordholts
2011-09-05 05:00:57 UTC (almost 14 years ago)
tool presets
2011/9/5 Alexandre Prokoudine :
This is not something that blocks a 2.8 release and we badly badly need to make a release. This should wait until after 2.8.
/ Martin
2011-09-05 05:09:34 UTC (almost 14 years ago)
tool presets
How does it prevent you from releasing 2.8?
Martin Nordholts
2011-09-05 05:24:08 UTC (almost 14 years ago)
tool presets
Any feature we add at this point will delay the 2.8 release because someone needs to actually write the code, test the feature, fix bugs, take feedback into account etc. Even if we get a patch from the outside, a core developer basically needs to do all of the above except writing the initial code. With limited resources, we have to prioritize. And releasing 2.8 has higher priority than having default tool presets. We can always add those later. And with the shorter development cycles we aim for, it's not a big deal if a feature makes it into x.y or x.(y + 2).
/ Martin
Alexia Death
2011-09-05 05:29:46 UTC (almost 14 years ago)
tool presets
I agree. It should have at least something in it.
Some cropping
We shoudn't probably offer straight up GPS tools, because people a likely to install gps themselves. But a few examples should be included I guess.
Resources are not translatable by nature as far as I know. ..
You cant, but I cant see how thats relevant. The old tool presets always required 2 clicks, same for bringing up the dockable and selecting a preset. Now, I personally just keep the preset selector on top most of the time with tag active for currently relevant tool set. Tool presets pay off when you need to use the same tool with very different settings. Paint tools are an obvious case, but Im sure there are others. I personally have presets for the common cut 2:3 + rule of thrids guides. Its easyer to use the preset when ever I need it than to go and configure it.
Since when does adding default resources counts as a feature or involves significant amount of coding and risk of breakage? I would agree if this was a coding task. It is not. If it was, there would be something very wrong with the setup. We sort of promised our users better resources with this release but nobody has take it up... The very least we could do is to provide some defaults for the new things so people know what it does.
2011-09-05 05:40:19 UTC (almost 14 years ago)
tool presets
Are we still talking about a single resource file and a patch to Makefile.am to make this resource file installable? What sort of risk does it impose on release of 2.8?
Martin Nordholts
2011-09-05 07:03:16 UTC (almost 14 years ago)
tool presets
2011/9/5 Alexia Death :
What I call "feature" is something that makes GIMP better and that we don't _have_ to do. Having default tool presets is better than not having default tool presets, but it is not something we _have_ to do before releasing 2.8, so adding default tool presets is a feature.
When I say that we should not do this to 2.8, I say that because I want us to make a 2.8 release as soon as possible. However, people are of course, as always, free to work on whatever they want to.
Regards, Martin
Alexia Death
2011-09-05 07:37:00 UTC (almost 14 years ago)
tool presets
It's practically no risk coding free change. I agree, we dont have to do this before 2.8. But if someone does this, I see no reason to reject it.
Of course, but I see no reason to actively discourage resource changes at a point when we dont even have a new splash set yet...
Martin Nordholts
2011-09-05 08:30:27 UTC (almost 14 years ago)
tool presets
Well, the reason we don't have a splash is because nobody had time to get us one yet. From the point of view of making a 2.8 release happen, it would be better if you took the lead in finding a 2.8 splash rather than adding default tool presets.
But then there is the point of view of fun, and if you get a kick out of giving users default tool presets in 2.8, which is perfectly sensible, please do that. I get a kick out of trying to make a 2.8 release happen as soon as possible as well as improving the way we work so that we can shorten our release cycles, so that's what I do.
Best regards, Martin
Alexia Death
2011-09-05 08:36:35 UTC (almost 14 years ago)
tool presets
I dont see how one excludes the other really...
Michael Natterer
2011-09-05 10:25:31 UTC (almost 14 years ago)
tool presets
That's because it doesn't.
Now can you guys stop this silly thread and move on to what gives you the kicks? :P
--Mitch
Alexia Death
2011-09-05 11:15:57 UTC (almost 14 years ago)
tool presets
I think its appropriate to remind people of the preset converter, that as it stands lacks any feedback:
http://wiki.gimp.org/index.php/Mindstorm:Preset_converter
