[PATCH] Fix some memleaks
[PATCH] Fix some memleaks Nelson A. de Oliveira 16 Aug 23:14
  [PATCH] Fix some memleaks Kevin Cozens 17 Aug 16:43
   [PATCH] Fix some memleaks Nelson A. de Oliveira 17 Aug 17:16
    [PATCH] Fix some memleaks Kevin Cozens 18 Aug 20:43
2011-08-16 23:14:03 UTC (over 13 years ago)
Hi!
Can somebody verify and commit it, please? http://people.debian.org/~naoliv/misc/0001-Fix-some-memleaks.txt
Thank you!
Best regards, Nelson
Kevin Cozens
2011-08-17 16:43:13 UTC (over 13 years ago)
Thank you for the patch. There are some minor changes needed before the patch can be applied.
The patch file should not contain tabs. Please change the tabs before the g_free() calls you added to spaces.
The second change to psd-util.c frees pascal_str but it looks to me that it also needs to be freed after the call to g_debug().
After you make the above mentioned changes, send a link to the updated patch file.
2011-08-17 17:16:33 UTC (over 13 years ago)
Hi!
Updated patch available at
http://people.debian.org/~naoliv/misc/0001-Fix-some-memleaks-2.txt
Thank you!
Kevin Cozens
2011-08-18 20:43:25 UTC (over 13 years ago)
Patch was committed as revision ce3db28f5abe3667a97be3ad2d44a0794efecb16. Thanks again for spotting the leaks and the patch.
