Fwd: Recent Gegl-0.1.7 build fails
Fwd: Recent Gegl-0.1.7 build fails | Partha Bagchi | 28 May 12:58 |
Recent Gegl-0.1.7 build fails | Partha Bagchi | 04 Jun 12:14 |
Recent Gegl-0.1.7 build fails | " | 04 Jun 17:55 |
Recent Gegl-0.1.7 build fails | Partha Bagchi | 04 Jun 18:15 |
Recent Gegl-0.1.7 build fails | Michael Schumacher | 06 Jun 07:26 |
Recent Gegl-0.1.7 build fails | Partha Bagchi | 06 Jun 09:27 |
Sorry, forgot to send to the list.
---------- Forwarded message ----------
Date: Sat, May 28, 2011 at 8:57 AM
Subject: Re: [Gimp-developer] Recent Gegl-0.1.7 build fails
To: Øyvind Kolås
On Sat, May 28, 2011 at 8:39 AM, Øyvind Kolås wrote:
Platform/Distribution HP Pavilion dv8t Intel Core i7/ Windows 7, 64bit $ gcc -v
Using built-in specs.
Target: x86_64-w64-mingw32
Configured with: ../gcc44-svn/configure --host=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 --disable-multilib --enable-checking=r elease --prefix=/mingw64 --with-sysroot=/mingw64 --enable-languages=c,c++,fortran,objc,obj-c++ --enable-libgomp --with-gmp=/mingw64--with-mpfr=/mingw64 --disable-nls --disable-win32-registry Thread model: win32
gcc version 4.4.5 20101001 (release) [svn/rev.164871 - mingw-w64/oz] (GCC)Note that this error did not happen a couple of weeks ago.
The error might be fixed in git master now, you can either do a git checkout; or wait for new nightly tarballs to appear. I hope this fixes it.
/Øyvind K.
«The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/
Thanks!! I did a temporary fix by doing the following:
copied gegl-buffer-save.c & gegl-tile-backend.c from a previous git source and built GEGL by passing -DHAVE_GIO since I noticed that, that was removed from the current source.
Moreover, (while I have your attention, :)) I noticed that gdk-pixbuf-2.0 is no longer automatically configured. So, I had to pass that in my command line as GDK_PIXBUF_CFLAGS="`pkg-config --cflags gdk-pixbuf-2.0`" GDK_PIXBUF_LIBS="`pkg-config --libs gdk-pixbuf-2.0`"
Thanks again, Partha
Gimp-developer mailing list Gimp-developer@lists.XCF.Berkeley.EDU https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-developer
I tried again. The error still persists:
gegl-buffer-save.c: In function 'gegl_buffer_save': gegl-buffer-save.c:227: error: 'S_IRGRP' undeclared (first use in this function) gegl-buffer-save.c:227: error: (Each undeclared identifier is reported only once gegl-buffer-save.c:227: error: for each function it appears in.) gegl-buffer-save.c:227: error: 'S_IWGRP' undeclared (first use in this function) gegl-buffer-save.c:227: error: 'S_IROTH' undeclared (first use in this function) gegl-buffer-save.c:227: error: 'S_IWOTH' undeclared (first use in this function) make[4]: *** [gegl-buffer-save.lo] Error 1
---------- Forwarded message ---------- From: Partha Bagchi
Subject: Re: [Gimp-developer] Recent Gegl-0.1.7 build fails To: Øyvind KolåsOn Sat, May 28, 2011 at 8:39 AM, Øyvind Kolås wrote:
/Øyvind K.
«The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/Thanks!! I did a temporary fix by doing the following:
That is the same error, but elsewhere, if you provide git formatted patches fixing such issues I will integrate them with GEGL.
/Øyvind K.
«The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/ _______________________________________________ Gimp-developer mailing list Gimp-developer@lists.XCF.Berkeley.EDU https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-developer
/Øyvind K.
«The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/ _______________________________________________ Gegl-developer mailing list Gegl-developer@lists.XCF.Berkeley.EDU https://lists.XCF.Berkeley.EDU/mailman/listinfo/gegl-developer
OK. I create a patch using diff. Would that be sufficient? I attached it to this mail. Hope it comes through.
Thanks for all your help.
Partha
/Øyvind K.
-- «The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/
Von: Partha Bagchi
The S_*GRP and S_*OTH flags aren't defined on the Windows platform, and to my knowledge the bits associated to them don't have any meaning there anyway. I've committed a change to GEGL to fix this (a #ifdef check to change the open command to not use them on the Windows platform).
The next problem that you'll most likely encounter is the undefined fsync in gegl/buffer - in my local tree, I've added a AC_CHECK_FUNS(fsync) directive to my configure.ac and wrapped the fsync calls in #if HAVE_FSYNC.
I guess that fsync could be redefined to FlushFileBuffers (see http://www.humboldt.co.uk/2009/03/fsync-across-platforms.html) on the Windows platform unless a fsync implementation is found by the check.
Regards, Michael
Von: Partha Bagchi
Regards, Michael
You are absolutely right. fsync was a problem while compiling. I fixed that by passing -Dfsync=_commit
See for example: http://lists-archives.org/mingw-users/10348-mingw-now-works-sorta.html
Thanks, Partha
Von: Partha Bagchi
Regards, Michael
Empfehlen Sie GMX DSL Ihren Freunden und Bekannten und wir belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.gmx.de _______________________________________________ Gimp-developer mailing list
