Example: Vala as code generator
9 of 9 messages available
Example: Vala as code generator enselic@gmail.com 01 May 15:15
  [PATCH 1/2] configure.ac: Look for valac enselic@gmail.com 01 May 15:15
  [PATCH 2/2] app: Add GimpIdTable utility class enselic@gmail.com 01 May 15:15
  Example: Vala as code generator Michael Natterer 02 May 12:48
   Example: Vala as code generator Nicolas Robidoux 02 May 13:15
    Example: Vala as code generator Christopher Curtis 02 May 14:08
   Example: Vala as code generator Martin Nordholts 02 May 18:18
    Example: Vala as code generator Simon Budig 02 May 23:28
     Example: Vala as code generator Martin Nordholts 03 May 06:07
enselic@gmail.com
2011-05-01 15:15:29 UTC (almost 14 years ago)
Hi all,
We have discussed the possibility to use Vala as a code generator. What follows is a set of patches so we all can see what that would look like. Any objections to me pushing these commits?
I want a helper class in the implementation of single-window mode session management, and this is in my opinion a perfect example of when to use Vala: a small utility class at the bottom of the architecture with only GLib as a dependency.
These patches do not add any additional tarball build time dependencies, valac is only required when building from git.
/ Martin
enselic@gmail.com
2011-05-01 15:15:30 UTC (almost 14 years ago)
Look for valac and prepare app/core for .vala source files. valac is only needed when building from git, in tarballs the generated .c and .h files are distributed.
app/core/Makefile.am | 37 +++++++++++++++++++++++++++++++++++-- configure.ac | 3 +++
2 files changed, 38 insertions(+), 2 deletions(-)
diff --git a/app/core/Makefile.am b/app/core/Makefile.am index 3a8ee12..3f0985c 100644
--- a/app/core/Makefile.am
+++ b/app/core/Makefile.am
@@ -384,13 +384,21 @@ libappcore_a_sources = \ gimpviewable.c \
gimpviewable.h
+libappcore_a_built_sources_vala = \ + $(NULL)
+libappcore_a_extra_sources_vala = \ + $(NULL)
libappcore_a_built_sources = \
core-enums.c \
gimpmarshal.c \
- gimpmarshal.h
+ gimpmarshal.h \
+ $(libappcore_a_built_sources_vala)
libappcore_a_extra_sources = \
- gimpmarshal.list
+ gimpmarshal.list \
+ $(libappcore_a_extra_sources_vala)
libappcore_a_SOURCES = $(libappcore_a_built_sources) $(libappcore_a_sources)
@@ -429,3 +437,28 @@ core-enums.c: $(srcdir)/core-enums.h $(GIMP_MKENUMS) $(srcdir)/core-enums.h > xgen-cec \ && cp xgen-cec $(@F) \
&& rm -f xgen-cec
+# Vala helpers
+.vala.c:
+ $(VALAC_CHECK_AVAILABILITY)
+ $(VALA_V)$(VALAC) --compile --ccode --output=$@ $< + @touch $@ # See Bug 649084
+.vala.h:
+ $(VALA_V)$(VALAC) --compile --header=$@ $< + @touch $@ # See Bug 649084
+$(libappcore_a_built_sources_vala): Makefile.am $(VALAC) +
+# Valac is not needed when building tarballs, but we should still fail +# properly when valac is missing
+VALAC_CHECK_AVAILABILITY = @if test -z "$(VALAC)"; then echo "$, AC_PROG_CC
AM_PROG_CC_C_O
+# Determine a Vala compiler to use. Not needed when building tarballs. +AM_PROG_VALAC(0.9.3)
# Initialize libtool
AM_DISABLE_STATIC
AC_LIBTOOL_WIN32_DLL
enselic@gmail.com
2011-05-01 15:15:31 UTC (almost 14 years ago)
Add a GimpIdTable utility class, written in Vala. ---
app/core/.gitignore | 2 +
app/core/Makefile.am | 5 +- app/core/gimp.c | 15 +++--- app/core/gimp.h | 7 +-- app/core/gimpidtable.vala | 106 +++++++++++++++++++++++++++++++++++++++++++++ app/core/gimpimage.c | 22 ++------- app/core/gimpitem.c | 31 ++++--------- 7 files changed, 135 insertions(+), 53 deletions(-) create mode 100644 app/core/gimpidtable.vala
diff --git a/app/core/.gitignore b/app/core/.gitignore index 7827fe0..ba81322 100644
--- a/app/core/.gitignore
+++ b/app/core/.gitignore
@@ -3,6 +3,8 @@
/.libs
/Makefile
/Makefile.in
+/gimpidtable.c
+/gimpidtable.h
/gimpmarshal.c
/gimpmarshal.h
/libappcore.a
diff --git a/app/core/Makefile.am b/app/core/Makefile.am index 3f0985c..393fe27 100644
@@ -385,10 +385,11 @@ libappcore_a_sources = \ gimpviewable.h
libappcore_a_built_sources_vala = \ - $(NULL)
+ gimpidtable.c \
+ gimpidtable.h
libappcore_a_extra_sources_vala = \ - $(NULL)
+ gimpidtable.vala
core-enums.c \
diff --git a/app/core/gimp.c b/app/core/gimp.c index 434d1a7..7c19da7 100644
--- a/app/core/gimp.c
+++ b/app/core/gimp.c
@@ -62,6 +62,7 @@
#include "gimpdocumentlist.h"
#include "gimpgradient-load.h"
#include "gimpgradient.h"
+#include "gimpidtable.h"
#include "gimpimage.h"
#include "gimpimagefile.h"
#include "gimplist.h"
@@ -218,13 +219,11 @@ gimp_init (Gimp *gimp) gimp->images = gimp_list_new_weak (GIMP_TYPE_IMAGE, FALSE); gimp_object_set_static_name (GIMP_OBJECT (gimp->images), "images");
- gimp->next_image_ID = 1;
gimp->next_guide_ID = 1;
gimp->next_sample_point_ID = 1;
- gimp->image_table = g_hash_table_new (g_direct_hash, NULL); + gimp->image_table = gimp_id_table_new ();
- gimp->next_item_ID = 1;
- gimp->item_table = g_hash_table_new (g_direct_hash, NULL); + gimp->item_table = gimp_id_table_new ();
gimp->displays = g_object_new (GIMP_TYPE_LIST, "children-type", GIMP_TYPE_OBJECT, @@ -417,13 +416,13 @@ gimp_finalize (GObject *object)
if (gimp->item_table)
- g_hash_table_destroy (gimp->item_table); + g_object_unref (gimp->item_table); gimp->item_table = NULL;
if (gimp->image_table)
- g_hash_table_destroy (gimp->image_table); + g_object_unref (gimp->image_table); gimp->image_table = NULL;
@@ -492,8 +491,8 @@ gimp_get_memsize (GimpObject *object, memsize += gimp_object_get_memsize (GIMP_OBJECT (gimp->plug_in_manager), gui_size);
- memsize += gimp_g_hash_table_get_memsize (gimp->image_table, 0); - memsize += gimp_g_hash_table_get_memsize (gimp->item_table, 0); + memsize += gimp_id_table_get_memsize (gimp->image_table, 0); + memsize += gimp_id_table_get_memsize (gimp->item_table, 0);
memsize += gimp_object_get_memsize (GIMP_OBJECT (gimp->displays), gui_size);
diff --git a/app/core/gimp.h b/app/core/gimp.h index 6658c19..7cb624a 100644
--- a/app/core/gimp.h
+++ b/app/core/gimp.h
@@ -21,6 +21,7 @@
#include "gimpobject.h"
#include "gimp-gui.h"
+#include "gimpidtable.h" /* See Bug 648973 */
#define GIMP_TYPE_GIMP (gimp_get_type ()) @@ -74,13 +75,11 @@ struct _Gimp
GimpPlugInManager *plug_in_manager;
GimpContainer *images;
- gint next_image_ID; guint32 next_guide_ID; guint32 next_sample_point_ID; - GHashTable *image_table; + GimpIdTable *image_table;
- gint next_item_ID; - GHashTable *item_table; + GimpIdTable *item_table;
GimpContainer *displays; gint next_display_ID; diff --git a/app/core/gimpidtable.vala b/app/core/gimpidtable.vala new file mode 100644
index 0000000..3986a5a
--- /dev/null
+++ b/app/core/gimpidtable.vala
@@ -0,0 +1,106 @@
+/* GIMP - The GNU Image Manipulation Program + * Copyright (C) 1995 Spencer Kimball and Peter Mattis + *
+ * gimpidtable.vala
+ * Copyright (C) 2011 Martin Nordholts + *
+ * This program is free software: you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 3 of the License, or + * (at your option) any later version. + *
+ * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + *
+ * You should have received a copy of the GNU General Public License + * along with this program. If not, see . + */
+ * Contains a hash table with "int -> void *" mappings. The id for an + * object either automatically becomes the lowest unused id or is + * assigned manually.
+public class GimpIdTable : GLib.Object +{
+ private static int START_ID = 1;
+ private static int END_ID = int.MAX; +
+ private int next_id = START_ID;
+ private GLib.HashTable id_table = + new GLib.HashTable(GLib.direct_hash, null); +
+ * Insert an object and assign it the lowest available id. + *
+ * Returns: The assigned id.
+ public int insert (void *data)
+ int new_id = next_id; // Must initialize, Bug 574352 +
+ do
+ new_id = next_id++;
+ if (next_id == END_ID)
+ next_id = START_ID;
+ while (lookup (new_id) != null); +
+ return insert_with_id (new_id, data); + }
+ * Insert an object with the given id. + *
+ * Returns: The assigned id if it wasn't used, -1 otherwise. + */
+ public int insert_with_id (int id, void *data) + {
+ if (lookup (id) != null)
+ return -1;
+ id_table.insert(id, data);
+ return id;
+ * Wrapper around GLib.HashTable.replace() + */
+ public void replace (int id, void *data) + {
+ id_table.replace (id, data);
+ * Wrapper around GLib.HashTable.lookup() + */
+ public void *lookup (int id)
+ return id_table.lookup (id);
+ * Wrapper around GLib.HashTable.remove() + */
+ public bool remove (int id)
+ return id_table.remove (id);
+ * GimpObject::get_memsize() implementation. + */
+ public int64 get_memsize (int64 data_size) + {
+ /* Copy of gimp_g_hash_table_get_memsize() */ + return (2 * sizeof (int) +
+ 5 * sizeof (void *) +
+ id_table.size () * (3 * sizeof (void *) + data_size)); + }
diff --git a/app/core/gimpimage.c b/app/core/gimpimage.c index 01d02cd..f156f2d 100644
--- a/app/core/gimpimage.c
+++ b/app/core/gimpimage.c
@@ -42,6 +42,7 @@
#include "gimpgrid.h"
#include "gimperror.h"
#include "gimpguide.h"
#include "gimpimage-colorhash.h"
#include "gimpimage-colormap.h"
@@ -749,19 +750,8 @@ gimp_image_constructed (GObject *object)
config = image->gimp->config;
- do
- private->ID = image->gimp->next_image_ID++; -
- if (image->gimp->next_image_ID == G_MAXINT) - image->gimp->next_image_ID = 1; - }
- while (g_hash_table_lookup (image->gimp->image_table, - GINT_TO_POINTER (private->ID))); -
- g_hash_table_insert (image->gimp->image_table, - GINT_TO_POINTER (private->ID), - image);
+ private->ID = gimp_id_table_insert (image->gimp->image_table, + G_OBJECT (image));
template = config->default_image;
@@ -997,8 +987,7 @@ gimp_image_finalize (GObject *object)
if (image->gimp && image->gimp->image_table) {
- g_hash_table_remove (image->gimp->image_table, - GINT_TO_POINTER (private->ID)); + gimp_id_table_remove (image->gimp->image_table, private->ID); image->gimp = NULL;
@@ -1502,8 +1491,7 @@ gimp_image_get_by_ID (Gimp *gimp, if (gimp->image_table == NULL)
return NULL;
- return (GimpImage *) g_hash_table_lookup (gimp->image_table, - GINT_TO_POINTER (image_id)); + return (GimpImage *) gimp_id_table_lookup (gimp->image_table, image_id); }
void
diff --git a/app/core/gimpitem.c b/app/core/gimpitem.c index 856e962..6ed7167 100644
--- a/app/core/gimpitem.c
+++ b/app/core/gimpitem.c
@@ -337,8 +337,7 @@ gimp_item_finalize (GObject *object)
if (private->image && private->image->gimp) {
- g_hash_table_remove (private->image->gimp->item_table, - GINT_TO_POINTER (private->ID)); + gimp_id_table_remove (private->image->gimp->item_table, private->ID); private->image = NULL;
@@ -1600,8 +1599,7 @@ gimp_item_get_by_ID (Gimp *gimp, if (gimp->item_table == NULL)
return NULL;
- return (GimpItem *) g_hash_table_lookup (gimp->item_table, - GINT_TO_POINTER (item_id)); + return (GimpItem *) gimp_id_table_lookup (gimp->item_table, item_id); }
GimpTattoo
@@ -1649,19 +1647,8 @@ gimp_item_set_image (GimpItem *item,
if (private->ID == 0)
- do
- private->ID = image->gimp->next_item_ID++; -
- if (image->gimp->next_item_ID == G_MAXINT) - image->gimp->next_item_ID = 1; - }
- while (g_hash_table_lookup (image->gimp->item_table, - GINT_TO_POINTER (private->ID))); -
- g_hash_table_insert (image->gimp->item_table, - GINT_TO_POINTER (private->ID), - item);
+ private->ID = gimp_id_table_insert (image->gimp->item_table, + G_OBJECT (item));
g_object_notify (G_OBJECT (item), "id"); }
@@ -1715,13 +1702,13 @@ gimp_item_replace_item (GimpItem *item, gimp_object_set_name (GIMP_OBJECT (item), gimp_object_get_name (replace));
if (private->ID)
- g_hash_table_remove (gimp_item_get_image (item)->gimp->item_table, - GINT_TO_POINTER (gimp_item_get_ID (item))); + gimp_id_table_remove (gimp_item_get_image (item)->gimp->item_table, + gimp_item_get_ID (item));
private->ID = gimp_item_get_ID (replace); - g_hash_table_replace (gimp_item_get_image (item)->gimp->item_table, - GINT_TO_POINTER (gimp_item_get_ID (item)), - item);
+ gimp_id_table_replace (gimp_item_get_image (item)->gimp->item_table, + gimp_item_get_ID (item), + G_OBJECT (item));
/* Set image before tatoo so that the explicitly set tatoo overrides * the one implicitly set when setting the image
Michael Natterer
2011-05-02 12:48:41 UTC (almost 14 years ago)
On Sun, 2011-05-01 at 17:15 +0200, enselic@gmail.com wrote:
Hi all,
Yes, and I'm currently on vacation and can't respond in detail, but IIRC I have made myself very clear about vala.
/ Martin
Nicolas Robidoux
2011-05-02 13:15:57 UTC (almost 14 years ago)
The following statement of Mich's unfortunately describes most of nowadays C.S. students [1]
And this is *exactly* the problem. We would end up with programmers that quickly learnt vala, having no clue about GObject. That's absolutely horrible. Just like the people who only know how to write java or #C code. They know how to use all the fancy classes, but they have never implemented a list or anything lowlevel themselves. I don't want people who know vala, but don't "had to learn" GObject.
One way of viewing the issue is:
Do you want to cater to the programmers you want, or the programmers you have? (With the hope of turning the latter into the former.)
Nicolas Robidoux
[1] research.cs.queensu.ca/~cisc422/2010f/readings/papers/whereAreTheSoftwareEngineersOfTomorrow.pdf
Christopher Curtis
2011-05-02 14:08:53 UTC (almost 14 years ago)
On Mon, May 2, 2011 at 9:15 AM, Nicolas Robidoux
It's worse than that, even. This is a perpetual argument.
People were railing against C in the 70s because people who weren't programming in assembler weren't intimate with the stack, heap, or registers. They hated the subroutine call inefficiency. They hated losing the ability to dynamically change executing code, or freely use instructions as data.
Software development - all engineering, really - is about trades. C imposed a base level of inefficiency for a higher level of productivity.
Today, C is a hindrance to even greater productivity (GObject itself is evidence of this). It's less useful to know how to write a hash table interface with its own unique API than it is to know how or when to use one. If a hash table is part of the language, then it becomes the One True Implementation and Everybody knows it and uses it, and does so mostly-correctly.
FWIW, to me, Vala seems like a reasonable choice for GObject based systems. I don't think it's going to expand the developer base now because Vala prefers an understanding of GObject, which is little used outside OSS systems. The syntax should be familiar to C/C++/C# users, but the trade here is for productivity.
While another language (C++, C# or Java) may have more developers, that language would require an object system be built around GObject, which just raises the question: "Why not Vala?" One would assume that a stable Vala compiler exists or is currently stable enough to use on all target platforms.
Chris
Martin Nordholts
2011-05-02 18:18:19 UTC (almost 14 years ago)
2011/5/2 Michael Natterer :
Hi all,
Hi Michael,
I'm trying hard to find time hacking on GIMP, and not having to waste time on GObject C boiler plate means a lot to me. At first I was thinking "what the hell, I'll just come up with the the damn boilerplate code manually then". But right after I began doing that I started to feel like I was wasting my time, and I can't stand that feeling. I find your blunt dismissal of these two patches really discouraging. Can't we at least push them to master and have them in for a while and see if we can discover some real problems? If it really doesn't work out, we can just reformat the generated .h and .c files and discard the .vala file.
If you are on vacation and don't have time to properly review or test these patches, please take your time to do so. I'm not going to push these patches without your OK, and if you're busy for a few weeks, then I'll have to wait. I can work on other items on the GIMP 2.8 schedule in the meantime...
Regards, Martin
Simon Budig
2011-05-02 23:28:17 UTC (almost 14 years ago)
Hm. This paragraphs leaves me a bit perplexed, because it gives the impression that the most important thing about including vala is to make you more comfortable with our codebase. You blame mitch for a blunt dismissal, but this reads a lot like bluntly forcing down something through mitchs throat. Not sure if that is any better.
I must say that - while I have my share of frustrations with the gobject boilerplate code - I don't think that adding vala helps the quality of the Gimp codebase. And this is IMHO what should be in our focus.
From reading a lot of code in a lot of different free software projects
I have to say, that Gimp still is one of the shining examples regarding consistency and quality of the source code. This has a lot to do with mainly Sven and Mitch investing countless hours into refactoring and restructuring the code, enforcing a common code structure and generally fighting against sloppiness.
I don't see how mixing this code with code written in a new language will help the quality of the source. Vala code will inherently develop a set of patterns that differs from the C code (and don't underestimate the value of grepping through the code base). Also new contributors will not only have to learn about GObject and GTK+, they have to learn vala as well. And adding vala *is* adding a new entry barrier, vala is by no means a lingua franca.
Bye,
Simon
Martin Nordholts
2011-05-03 06:07:41 UTC (almost 14 years ago)
2011/5/3 Simon Budig :
You are right, that isn't any better. I should just give up on these patches, I clearly don't have the support for them I hoped for.
Obviously, in my opinion we increase the quality of our codebase by using Vala for this helper class mostly because the number of readable and documented version controlled lines of code is less than if we would also version control the GObject C boiler plate. That is not the only measurement of code quality however and we are simply weighting the pros and cons differently.
/ Martin
