Write basic gegl plugin
16 of 16 messages available
Write basic gegl plugin Madhav yadav 04 Apr 14:32
  Write basic gegl plugin Tobias Jakobs 04 Apr 14:39
   Write basic gegl plugin shivani maheshwari 04 Apr 15:02
    Write basic gegl plugin Jon Nordby 04 Apr 15:17
     Write basic gegl plugin Madhav yadav 05 Apr 05:41
      Write basic gegl plugin sourav de 05 Apr 06:55
       Write basic gegl plugin Alexia Death 05 Apr 07:25
       Write basic gegl plugin Jon Nordby 05 Apr 07:34
        Write basic gegl plugin Tobias Jakobs 05 Apr 08:06
         Write basic gegl plugin Madhav yadav 05 Apr 09:01
          Write basic gegl plugin Alexia Death 05 Apr 09:04
Write basic gegl plugin Madhav yadav 05 Apr 09:08
  Write basic gegl plugin Alexia Death 05 Apr 09:13
  Write basic gegl plugin Jon Nordby 05 Apr 09:37
   Write basic gegl plugin gg@catking.net 06 Apr 00:03
    Write basic gegl plugin Alexandre Prokoudine 06 Apr 02:53
Madhav yadav
2011-04-04 14:32:23 UTC (about 14 years ago)
I want to write basic gegl plugin....Can anybody help me with the same..
Tobias Jakobs
2011-04-04 14:39:49 UTC (about 14 years ago)
Have you seen this page?
http://wiki.gimp.org/index.php/Users:Beginner_Developer%27s_FAQ
shivani maheshwari
2011-04-04 15:02:05 UTC (about 14 years ago)
Yes i did see that . But I am not able to gather where to begin from??
Jon Nordby
2011-04-04 15:17:05 UTC (about 14 years ago)
Get the code, build it on your computer, start working on the plugin.
Shivani Maheshwari
Under Graduation( BTech.)
Indian Institute of Information Technology, Allahabad (Amethi Campus)
India
Madhav yadav
2011-04-05 05:41:56 UTC (about 14 years ago)
If i have to submit my sample on the gegl master branch then how will i go forthh.
On Mon, Apr 4, 2011 at 8:09 PM, Tobias Jakobs <
tobias.jakobs@googlemail.com>
same..
Shivani Maheshwari
India
Jon Nordby - www.jonnor.com
sourav de
2011-04-05 06:55:34 UTC (about 14 years ago)
same..
Shivani Maheshwari
India
I'm also facing the same problem. After translating the code using GEGL operations, how am I supposed to create patch file of it and submit it into the master branch.
Alexia Death
2011-04-05 07:25:14 UTC (about 14 years ago)
Basic ability to operate git version control system is also expected of the students. There are plenty of GIT guides on the internet. Basic commands for git you need to use and understand are clone, pull, commit, add and format-patch plus if you get accepted, push.
Jon Nordby
2011-04-05 07:34:59 UTC (about 14 years ago)
Use git to commit your changes and create a patch/patches. See http://wiki.gimp.org/index.php/Hacking:Patches I also recommend reading a tutorial on general git usage. After that you create a ticket in bugzilla under the gegl product, and add the patch(es) there.
We will then review the code, and once everything has been sorted out, it will be pushed to master.
Tobias Jakobs
2011-04-05 08:06:34 UTC (about 14 years ago)
And if there are some informations are missing in the Wiki, pleas get an account and add this informations.
Regards, Tobias
Madhav yadav
2011-04-05 09:01:24 UTC (about 14 years ago)
The problem doesn't actually lie in how to submit a patch . A patch is a file that contains the differences between the current version and the fixed version but we have to submit a self made plugin. Then how can we submit it as a patch against a main branch
Regards, Tobias
Alexia Death
2011-04-05 09:04:13 UTC (about 14 years ago)
Git patches can contain whole new files. see the add command and commit command I talked about earlier.
Madhav yadav
2011-04-05 09:08:02 UTC (about 14 years ago)
Don;t we need to authenticate to add new files to the branch??
fixed
it
-- --Alexia
Alexia Death
2011-04-05 09:13:08 UTC (about 14 years ago)
In git you can do all that locally. You only need to authenticate for push. This is why I told you to find out about git... Gimp students are expected to be autonomous and capable of finding out things like this for themselves once pointed in the right direction.
Jon Nordby
2011-04-05 09:37:20 UTC (about 14 years ago)
No, with git you primarily work against your local repository. You can do whatever you like there.
Please read a tutorial or two on git, so that you come to terms with the basic concepts.
gg@catking.net
2011-04-06 00:03:20 UTC (about 14 years ago)
Why wouldn't you want to work *with* your local repo rather than against it ?
Because I'm a cool l33t hack3rz type dude , I drink my coffee against a cup. I eat my dinner against a knife and fork.
2011-04-06 02:53:19 UTC (about 14 years ago)
Right, it's about time somebody did a "Speak English properly against us" session :)
