Tiny-Fu and its possible R6RS (beyond) future...
Tiny-Fu and its possible R6RS (beyond) future... Kevin Cozens 01 Apr 18:05
Kevin Cozens
2011-04-01 18:05:23 UTC (about 14 years ago)
The following is a reply to an old e-mail message sent to gimp-devel that has been bit rotting for some time in my drafts folder.
Andreas Posur wrote:
Many thanks for contributing to G.I.M.P
yw
I heard lots of different complains about working with scheme for GIMP (mostly: ugly interface and "unsexy") Scheme (TinyScheme/Fu and as well SIOD) are not up to date nor do they feature some stuff which is meanwhile often requested (such as) intensive (unit) testing...
SIOD was old and didn't really follow existing Scheme standards. TinyScheme is meant to be tiny, or at least small, and will be seen as missing features when viewed by those used to a full-blown Scheme implementation such as Guile.
There are a couple of scripts for testing Scheme implementations for compatability with R4RS and R5RS. TinyScheme can't run the R5RS tests as it doesn't support define-syntax. It does quite well running the R4RS tests when you take in to account the lack of support for things like complex numbers and big numbers.
The "Programming Languages Teaching Team" is reshaping their version of scheme to another much less misunderstood name on Google called "Racket". They will feature their implementation of R6RS Standard
Thank you for the information on Racket. It looks interesting but it would be too big to include with GIMP.
How
difficult could it be to write at least a GIMP (Tiny-Fu I don't think we would need tinyscheme that bad, but perhaps I'm wrong) rewrite perhaps together with M. Felleisen and his crew to get this "not so much convenient" method to do effective scripting updated (upgraded).
[snip]
You will find the whole discussion here: http://list.cs.brown.edu/pipermail/plt-dev/
I don't understand what you are asking. The link to the discussion is just a link to the entire mailing list archive for PLT. If you have a direct link to the message thread I will look at it. I'm not going to dig through their archives to find the discussion you wanted me to look at.
GIMP will have crucial feature changes (GEGL) with 3.0 and with Scheme/Racket we could to try to automate and enhance them for the greater good of people. PLT-Scheme coding is such much more comfortable and no it is not that "power-limited"...
Every so often someone suggests that Script-Fu should use some more full-featured version Scheme implementation. It's fine to suggest such a thing but you have to keep a couple of things in mind.
Is the proposed implementation of Scheme available for all environments that can run GIMP? How big is the implementation and can it be embedded with Script-Fu?
Most of the more "complete" implementations of Scheme are too big and contain features not needed for basic scripting and automation of GIMP. If someone can propose additions to TinyScheme to add any "needed" features, or knows of a more full featured Scheme interpreter that isn't a lot bigger than TinyScheme, I would be interested to look at the proposal.
For GIMP 3.0 I would like to get the changes I have planned for version 2 of Tiny-Fu in as the new Script-Fu which will make it easier to use alternative Scheme interpreters.
