Some edge filters in GEGL
Some edge filters in GEGL Victor Oliveira 30 Mar 16:12
  Some edge filters in GEGL Martin Nordholts 30 Mar 16:43
Victor Oliveira
2011-03-30 16:12:23 UTC (over 14 years ago)
Hello everyone. As a way to learn how GEGL works, I decided to implement some GIMP plug-ins in it [1,2]. I hope this code can help someone in the task of making your own plugins. I've done a sobel and a laplace filter. Both use RGBA float format for input and output. Basically, I just do a convolution with the appropriate mask, although in sobel filter I implemented some of the options of the original GIMP plugin.
There are some differences in the results, but I think this code is "almost there" to whom wants to port these plugins to GEGL.
[1] http://git.gnome.org/browse/gimp/tree/plug-ins/common/edge-sobel.c [2] http://git.gnome.org/browse/gimp/tree/plug-ins/common/edge-laplace.c
Martin Nordholts
2011-03-30 16:43:05 UTC (over 14 years ago)
2011/3/30 Victor Oliveira :
(BCC:ing gimp-developer)
Thanks! I haven't done a thorough review, but it looks like a good start. Can you create a patch with git format-patch and attach it to bugzilla please?
Martin
