gegl build fails
7 of 7 messages available
gegl build fails Michael J. Hammel 30 Mar 03:21
  gegl build fails Mukund Sivaraman 30 Mar 04:51
   gegl build fails Michael J. Hammel 30 Mar 16:28
    gegl build fails Jon Nordby 30 Mar 17:10
     gegl build fails Michael J. Hammel 30 Mar 17:24
      gegl build fails Jon Nordby 01 Apr 21:35
       gegl build fails Michael J. Hammel 03 Apr 20:11
Michael J. Hammel
2011-03-30 03:21:28 UTC (over 14 years ago)
gegl build fails
I've been having some problems building from git recently. Today I tried to figure out why. I use simple scripts to update the trees and then build them. BABL builds fine. GEGL fails here:
make[3]: Entering directory `/home/mjhammel/src/graphics/gimp/git/gegl/gegl' CC gegl-c.lo
CC gegl-config.lo
CC gegl-cpuaccel.lo
CC gegl-dot.lo
CC gegl-dot-visitor.lo
CC gegl-init.lo
CC gegl-instrument.lo
CC gegl-utils.lo
CC gegl-lookup.lo
CC gegl-xml.lo
CC gegl-matrix.lo
CCLD libgegl-0.1.la
GISCAN Gegl-0.1.gir
Couldn't find include 'Babl-0.1.gir' (search path: ['.', '/usr/share/gir-1.0', '/usr/share/gir-1.0', '/usr/share/gir-1.0']) make[3]: *** [Gegl-0.1.gir] Error 1
The commands to build it were as follows: export LD_LIBRARY_PATH=/usr/local/gimpgit/lib:$LD_LIBRARY_PATH export PKG_CONFIG_PATH=/usr/local/gimpgit/lib/pkgconfig/: $PKG_CONFIG_PATH
./autogen.sh -prefix=/usr/local/gimpgit make
These are the same command used to build BABL. The missing file is in the proper place:
mjhammel(tty6)$ find /usr/local/gimpgit -name Babl-0.1.gir /usr/local/gimpgit/share/gir-1.0/Babl-0.1.gir
Am I missing something new related to building GEGL from git? Seems I'm not telling GEGL about the install dir correctly.
Thanks.
Mukund Sivaraman
2011-03-30 04:51:53 UTC (over 14 years ago)
gegl build fails
export XDG_DATA_DIRS=/usr/local/gimpgit/share/
Mukund
Michael J. Hammel
2011-03-30 16:28:13 UTC (over 14 years ago)
gegl build fails
That got me a little further:
GISCAN Gegl-0.1.gir WARNING: Skipping unknown interface GeglVisitable GICOMP Gegl-0.1.gir
Gegl-0.1.gir: error: Type reference 'GeglMatrix3' not found
Jon Nordby
2011-03-30 17:10:00 UTC (over 14 years ago)
gegl build fails
Yeah, this has been reported by other as well. I'll try to fix it now. Which distribution are you using, and what is the version of gobject-introspection?
Michael J. Hammel
2011-03-30 17:24:52 UTC (over 14 years ago)
gegl build fails
On Wed, 2011-03-30 at 19:10 +0200, Jon Nordby wrote:
GISCAN Gegl-0.1.gir
Fedora 13. Is gobject-introspection within gobject-2.0? If so: $ pkg-config --modversion gobject-2.0 2.24.1
Jon Nordby
2011-04-01 21:35:20 UTC (over 14 years ago)
gegl build fails
 GISCAN Gegl-0.1.gir
No, the introspection toolchain is separate. Typically packaged as gobject-introspection or similar.
Anyhow, does it work for you now? I pushed a fix.
Michael J. Hammel
2011-04-03 20:11:14 UTC (over 14 years ago)
gegl build fails
I was able to do a proper rebuild today (git pull and build) and gegl built fine.
Thanks!
