"class" to "operation" diff.
"class" to "operation" diff. Victor Bogado 01 Sep 20:22
Victor Bogado
2006-09-01 20:22:29 UTC (over 18 years ago)
Here it is the diff file that changes the "class" property to "operation". I found a little problem while doing this, the "Gegl_node" object already had a property named "operation", so I renamed that to "gegl_operation".
Also I tried to make sure that this remained backward compatible, with bath the XML format and the API. With this patch the library will warn the user when he uses a "class" property advising him to change it to "operation".
I test this with the gegl-demo applications and XML files and it all went fine. Well there were lots and lots of warnings, but all the output were okay.
