gimp-help-2 tools/get_po_status.pl
gimp-help-2 tools/get_po_status.pl Ulf-D. Ehlert 20 Mar 13:16
Ulf-D. Ehlert
2011-03-20 13:16:46 UTC (about 14 years ago)
Vitaly Lomov (Wednesday, 16. March 2011)
Hi Ulf,
I use that file all the time on Windows7 with Cygwin. It works for all languages and all parameters. Once I got a bad address error on --nofiles param, but I think it's cygwin problem.
Yes, "--nofiles" just suppresses some output.
So you can update the comment in the file that it's tested on Windows. Vitaly.
Done. Thanks for the note. :-)
btw, I am back translating into ru, the *master branch. Is it correct or do we use a different branch now?
You should still use the master branch. If/when we start writing documentation for GIMP-2.8 we will probably use a second branch (master + gimp-help-2-6, or master + gimp-help-2-8).
Bye, Ulf
Allein bin ich manchmal einsam; mit anderen oft;
in Gesellschaft fast immer. Was mich mehr als alles
krank macht, sind die unheilbar Gesunden.
		-- Karlheinz Deschner
