Adding a layer mode
7 of 7 messages available
Adding a layer mode "J 03 Mar 01:00
  Adding a layer mode Joao S. O. Bueno 03 Mar 02:14
   Adding a layer mode Jörn P. Meier 03 Mar 17:06
  Adding a layer mode Martin Nordholts 03 Mar 05:26
   Adding a layer mode "J 03 Mar 17:03
    Adding a layer mode Martin Nordholts 03 Mar 18:56
     Adding a layer mode "J 03 Mar 20:04
"J
2011-03-03 01:00:50 UTC (almost 14 years ago)
Adding a layer mode
I would like to implement the following layer mode in the GIMP:
1) Transform destination and source pixels to HSL space. 2) Note original destination pixel saturation. 3) Set luminance component of destination pixel to luminance component of source pixel.
4) Transform destination to HSV color space. 5) Set saturation of destination pixel to original saturation of destination pixel.
I'm assuming destination is also the result of the operation. Not sure how GIMP handles this, though.
The purpose of the mode is to colorize a greyscale image while keeping both the saturation and hue data of the color layer and the luminance data of the greyscale image. Existing modes (as far as I see) unfortunately either mess up the color information or the luminance information.
So, the question is, what changes would I need to make to add this layer mode?
I would be very grateful for any hints. :)
Cheers,
Jörn
Gimp-developer mailing list
Joao S. O. Bueno
2011-03-03 02:14:08 UTC (almost 14 years ago)
Adding a layer mode
Hi John ---
regardless of the desired operation, it would be very difficult to stick a new layer operation in GIMP - due to file compatibilities, and everything else.
When I first started hacking around the GIMP source code, some years ago, new layer operations
also where something that I messed with.
But see..even if one doe shave a great idea, and a nice pacth taht wuld be included in the GIMP's source, there would be a problem of compatibility of new XCF images using the new layer mode, and older GIMP versions around.
So, while, yes, you could create a new layer mode just to poke around, it would be of little use other than for yourself. (Regardless, it is fun enough, I suggest you try it). If you get a usefull enough result, maybe yu could make a plug-in that would combine two normal layers using the algorithm you describe. You loose all real time niceness, but at least you can achieve your result. (and this plug-in can be passed around to others).
As for where to create a layer mode-- there are some files - -I don remember which now -- part of the fun is locating them -- you get to know yoru way around GIMP. You will even find out that there are different code paths to render layers on the source tree. There are all the files on the app/composite directory -- or one can enable GEGL compositing, for which the files are under app/gegl
This article can have some usefull hints on how to poke around GIMP' s source: http://www.ibm.com/developerworks/linux/library/os-gimp
js ->
Cheers,
Jörn _______________________________________________ Gimp-developer mailing list
Martin Nordholts
2011-03-03 05:26:36 UTC (almost 14 years ago)
Adding a layer mode
There is already a patch for that (using the CIELCH space instead), see the most recent patch in
https://bugzilla.gnome.org/show_bug.cgi?id=325564
/ Martin
My GIMP Blog:
http://www.chromecode.com/
"Why GIMP 2.8 is not released yet"
"J
2011-03-03 17:03:13 UTC (almost 14 years ago)
Adding a layer mode
Hi Martin,
very cool. Is this a patch against the git version?
Cheers,
Jörn
/ Martin
Jörn P. Meier
2011-03-03 17:06:26 UTC (almost 14 years ago)
Adding a layer mode
Hi Joao,
thanks for the input!
Right now this would be only for me since my workflow somewhat depends on this mode.
I have already written an external implementation which is run from a script, but of course it would speed up things a lot if I had a realtime feedback on what the result will look like. :)
I might still take a look at the sources you mentioned. Maybe I'll learn something about how GIMP works. :)
Cheers,
Jörn
Hi John ---
js ->
Cheers,
Martin Nordholts
2011-03-03 18:56:00 UTC (almost 14 years ago)
Adding a layer mode
Yes, and help with reviewing and testing it for inclusion in GIMP 2.8 would be appreciated.
/ Martin
My GIMP Blog:
"J
2011-03-03 20:04:50 UTC (almost 14 years ago)
Adding a layer mode
Compiling worked, but after clicking around a bit I persistently get
(gimp-2.7:27459): Gimp-Display-CRITICAL **: gimp_display_shell_pointer_ungrab: assertion `shell->pointer_grabbed == TRUE' failed
gimp_display_shell_pointer_grab: gdk_pointer_grab failed with status 1
and that's it.
Cheers,
Jörn
/ Martin
