Development environment
Development environment Malix0 24 Feb 02:33
  Development environment Malix0 24 Feb 07:17
   Development environment Martin Nordholts 24 Feb 07:39
   Development environment Malix0 26 Feb 15:53
Malix0
2011-02-24 02:33:15 UTC (over 14 years ago)
which development environmento do you use for Gimp? Do You use an IDE or just vi or emacs? I like to know which is the best way to start with Gimp development. I think that fot the beginners an IDE will be helpful, but expert programmers tend to use just an advanced editor. For example I'm a PL/SQL developer and before I used Toad. But now I just use Notepad++ with custom script for compiling directly within the editor. This because Toad editor is really poor and for me a powerful editor is fundamental.
I like to know what is your configuration and if you plan to have a gimp wiki where those information can be put.
For example various configurations can be explained: Eclipse + plugin x + plugin y, Vim + script x + script y, Anjuta + ..., Monodevelop and ... so a new developer can chose the perfect environment that fit his requirements.
Kind regards
Massimo Fidanza
Malix0
2011-02-24 07:17:31 UTC (over 14 years ago)
What you think about a questionnaire?
I try to write a draft, please add to this draft whatever you think is relevant.
---------------------- QUESTIONNAIRE START ---------------------- Q: What is the tool that you use for Gimp development (ex: Vim, Emacs, Eclipse, Anjuta, ...) ?
A:
Q: Your development environment supports direct compilation (answer yes or no)? If so plese explain how on the Note (ex. ide/editor feature or with plugin x, script y, ...)?
A:
Note:
Q: Your development environment supports code completion (answer yes or no)? If so plese explain how on the Note (ex. ide/editor feature or with plugin x, script y, ...)?
A:
Note:
Q: Your development environment supports documentation browser? (answer yes or no)? If so plese explain how on the Note (ex. ide/editor feature or with plugin x, script y, ...)? A:
Note:
Q: Your development environment supports bebugging? (answer yes or no)? If so plese explain how on the Note (ex. ide/editor feature or with plugin x, script y, ...)?
A:
Note:
Q: Your development environment supports code refactoring? (answer yes or no)? If so plese explain how on the Note (ex. ide/editor feature or with plugin x, script y, ...)?
A:
Note:
---------------------- QUESTIONNAIRE END ----------------------
Bye Massimo
Kind regards
Massimo Fidanza
Martin Nordholts
2011-02-24 07:39:22 UTC (over 14 years ago)
Tool:
Emacs + https://github.com/Enselic/enselic-home/tree/master/elisp
Direct compilation: Yes, with M-x compile and M-x flymake-mode
Code completion: Kind of, Emacs supports tab-completion for symbols in all buffers, so if I have the relevant headers open, I have tab-completion for e.g. all gtk_ functions. Not the best code completion, but you come pretty far with it.
Documentation browser: I use exuberant-ctags for symbol definition lookup, so to get to the documentation of a function, I usually go to the declaration/definition of it using the exuberant-ctags indexes. I also occasionally use devhelp, but that's an external program.
Debugging: Yes, M-x gdb
Refactoring:
No, unfortunately not.
/ Martin
Malix0
2011-02-26 15:53:00 UTC (over 14 years ago)
Many thanks to Martin that send his configuration. I send a request to Alexia Death for a wiki account. If I get that I will put those information here http://gimp-wiki.who.ee where I see already exists details about Netbeans.
Someone else has different configuration?
Thanks in advance. Massimo
A:
Q: Your development environment supports direct compilation (answer yes or no)? If so plese explain how on the Note (ex. ide/editor feature or with plugin x, script y, ...)? A:
Note:
A:
Note:
Note:
A:
Note:
Q: Your development environment supports code refactoring? (answer yes or no)? If so plese explain how on the Note (ex. ide/editor feature or with plugin x, script y, ...)? A:
Note:
Bye Massimo
Kind regards Massimo Fidanza
