Google Summer of Code 2011 - Project Ideas/Suggestions
34 of 34 messages available
Google Summer of Code 2011 - Project Ideas/Suggestions LightningIsMyName 12 Feb 23:04
  Google Summer of Code 2011 - Project Ideas/Suggestions Liam R E Quin 12 Feb 23:31
   Google Summer of Code 2011 - Project Ideas/Suggestions Michael Natterer 13 Feb 00:02
   Google Summer of Code 2011 - Project Ideas/Suggestions " 13 Feb 15:57
    Google Summer of Code 2011 - Project Ideas/Suggestions Liam R E Quin 13 Feb 17:56
  Google Summer of Code 2011 - Project Ideas/Suggestions Alexandre Prokoudine 13 Feb 17:34
  Google Summer of Code 2011 - Project Ideas/Suggestions Martin Nordholts 13 Feb 17:55
   Google Summer of Code 2011 - Project Ideas/Suggestions Sven Neumann 15 Feb 23:01
  Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 25 Feb 01:30
   Google Summer of Code 2011 - Project Ideas/Suggestions " 25 Feb 10:32
    Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 26 Feb 17:38
  Google Summer of Code 2011 - Project Ideas/Suggestions LightningIsMyName 01 Mar 21:52
   Google Summer of Code 2011 - Project Ideas/Suggestions Kevin Cozens 01 Mar 22:19
    Google Summer of Code 2011 - Project Ideas/Suggestions Alexander Rabtchevich 02 Mar 07:06
     Google Summer of Code 2011 - Project Ideas/Suggestions Alexandre Prokoudine 02 Mar 13:56
   Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 02 Mar 00:20
   Google Summer of Code 2011 - Project Ideas/Suggestions Tobias Jakobs 02 Mar 07:59
   Google Summer of Code 2011 - Project Ideas/Suggestions Bill Skaggs 02 Mar 17:52
    Google Summer of Code 2011 - Project Ideas/Suggestions Bill Skaggs 02 Mar 17:58
  Google Summer of Code 2011 - Project Ideas/Suggestions Alexandre Prokoudine 08 Mar 18:21
   Google Summer of Code 2011 - Project Ideas/Suggestions Tobias Oelgarte 08 Mar 18:40
    Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 08 Mar 18:56
     Google Summer of Code 2011 - Project Ideas/Suggestions Alexandre Prokoudine 08 Mar 19:24
      Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 08 Mar 19:49
   Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 08 Mar 19:23
    Google Summer of Code 2011 - Project Ideas/Suggestions Alexandre Prokoudine 08 Mar 19:35
     Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 08 Mar 20:00
      Google Summer of Code 2011 - Project Ideas/Suggestions " 08 Mar 20:20
       Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 08 Mar 20:30
    Google Summer of Code 2011 - Project Ideas/Suggestions Tobias Oelgarte 08 Mar 19:35
     Google Summer of Code 2011 - Project Ideas/Suggestions Bogdan Szczurek 08 Mar 20:07
      Google Summer of Code 2011 - Project Ideas/Suggestions Tobias Oelgarte 08 Mar 20:31
Google Summer of Code 2011 - Project Ideas/Suggestions Michael Grosberg 13 Feb 08:26
  Google Summer of Code 2011 - Project Ideas/Suggestions Liam R E Quin 16 Feb 01:18
LightningIsMyName
2011-02-12 23:04:07 UTC (about 14 years ago)
I'm starting this thread to list ideas for Google Summer of Code 2011, for the GIMP project. Since in the last year collecting ideas was done partially by the mailing list, let's try it again this year and keep most ideas here.
One should aslo take a look at GEGL's page about contributing (too bad GIMP doesn't have something like that): http://gegl.org/contribute.html
Here is a list of ideas from 2010, that are still not implemented, and *may* be relevant.
JavaScript scripting in the core and/or plug-ins - using GNOME Java Script infrastructure (GJS)
GIMP scripts and plug-ins can be written in Scheme, Perl, Python and C. Scheme is always available, but limited in its application in regard on image manipulation. Additionally, as a list-processing language, it may appear as weird to most users. Its main purpose is scripting workflows for repetitive work.
The Perl binding is currently the least supported one and not available on platforms other than Unix. The Python binding and the C libraries are current the most powerful ones.
Javascript could take over Scheme's role as the genreral purpose scripting language for GIMP.
[Note]: At least for scheme, there are no debuggers for scripting in GIMP, and only tracing is supported. It would be neat if as a part of this project, a javascript debugger will be integrated so scripts could be debugged in a sane way. Again, this is not a part of the original project suggestion (as suggested last year), but this is something that could be helpful.
Make menus searchable
... i.e. have a textbox, in te menu for example, and anything typed will be matched against all menu items and their blurbs and maybe something more (like procedures not registered in menus).
Implement the free transform tool
For exact specifications, see: http://gui.gimp.org/index.php/Transformation_tool_specification
(may be offline at the moment)
Replace the GimpSizeEntry widget
Right now both the code and the UI is a mess. The unit should for example be in the text entry itself instead of in a combo box
Brush selector wigdet
More precisely one that is also capable for brush transform input (size/angle/aspect ratio).
Slicing tool
One of the most requested features by web designers and/or interface designers, is the addition of a slice tool. Currently slicing images inside GIMP can only be done in grids (using guides and the guillotine action) and you can't split just one rectangle in the middle.
For example, the following slice can not be achieved:
Porting GIMP plugins to GEGL operations
There are many many GIMP plugins that would need eventually to be converted to GEGL operations, if we want to use them in future versions of GIMP.
Now, I'll throw in a first idea myself:
Adaptive Image Cloning (aka Semaless Cloning)
Direct cloning of parts from one image to another, usually ends in bad results because of different lighting conditions and other settings (such as white-balance) which causes the color of the cloned part not to match the source image and look out of place. There are some techniques to solve this, by using poisson equations and some other methods.
It differes from the existing heal tool, since it is meant for taking one area from an image, and paste it smoothly in some other area. The current algorithm implemented by the healing tool allows to remove local irregularities (such as dots, hairs, etc.) very well, but experiments of using it to do "adaptive cloning" of areas (for example copying a person from one image to the other) do not produce good results.
(It should be said that I'm a bit biased torwards this idea, because I want to work on it as a student in GSoC and I already collected papers about it. Still, I'd like a lot to see somthing like this in GIMP, no matter who implements it)
Liam R E Quin
2011-02-12 23:31:01 UTC (about 14 years ago)
On Sun, 2011-02-13 at 01:04 +0200, LightningIsMyName wrote:
a couple of comments
I still think the right way to do this is to have all the menus constructed through scripting, or at least to have ways to override and inspect all the menus from scripting.
It had better not be :-) Let me know if there are problems with it.
Implementing a compatibility framework to run older plugins and scripts once gegl is in place might be the best way to go here. Think of all those scripts on the gimp.org Web site...
Sounds interesting.
I'd add maybe
Macro recording (actions), possibly with pop-up dialogue boxes to ask for values;
Font selection using tags (preferably compatibly with fontmatrix and inkscape at least)
Undo/redo/"again"
Integrate vector layers with gegl
Better HDR support - e.g. aligning layers, (I think there may be patents on the various hugin algorithms for combining images though)
Fractal image upscaling (required by many stock agencies these days)
PhotoShop CS6 :-) import/export
But right now, some of the most important areas are (1) single window mode design and implementation and subsequent redesign :-)
(2) ability to do at least basic > 8bit-per-channel processing, preferably using gegl
(3) user interface design for everything else
Michael Natterer
2011-02-13 00:02:07 UTC (about 14 years ago)
The menus are defined in XML files which bind code-defined actions to menu items. This stuff if fully introspectable and an experienced GIMP coder can hack up a usable menu search in one day. Hardly a GSoC project that would keep a new GIMP hacker busy for longer than two weeks.
Tumbs down from here.
As to creating menus by scripting, I really don't see what would be the purpose of that. The way we construct menus is completely to GTK+ standards, with some GIMP specific additions. Overriding menus from scripts feels like over-configurability to me and hardly like a way to foster usability.
ciao, --mitch
Michael Grosberg
2011-02-13 08:26:01 UTC (about 14 years ago)
LightningIsMyName gmail.com> writes:
Automatic layer Boundary management. In essence just let the program deal with layer boundary - expand it whenever a layer is moved so that you can ALWAYS paint on any area you wish. If there's some memory or files size issue, perhaps add some automatic layer cropping on save. I want to stress that such a feature is really, really, useful. I believe there are some cases (scripts, maybe?) in which manual layer boundary management is necessary, so it should be just an option or something that can be deactivated temporarily.
2011-02-13 15:57:23 UTC (about 14 years ago)
On Sat, Feb 12, 2011 at 11:31 PM, Liam R E Quin wrote:
On Sun, 2011-02-13 at 01:04 +0200, LightningIsMyName wrote: Integrate vector layers with gegl
GEGL already has all the support for rendering vector layers, so it is a case of adding the code to deal with as part of the nodes in the projection. Thus doing work on this would not really be possible until compositing the layers using GEGL is the default (or only) way this is done by GIMP.
Through gsoc last year, GEGL already has operations to combine multiple exposures into a
HDR image as well as operations for tonemapping HDR images to standard dynamic range. Thus this is a task mostly about integrating UI bits with GIMP, once the drawables in GIMP are (and are backed by) GeglBuffers.
/Øyvind K.
                                                 -- William Gibson
http://pippin.gimp.org/                            http://ffii.org/
Gimp-developer mailing list
2011-02-13 17:34:39 UTC (about 14 years ago)
On 2/13/11, LightningIsMyName wrote:
Slicing tool
Oh come on, just port Slice tool from gimp-sharp to GIMP. All it takes is rewriting from C# to C + cairofication. *Then*, additionally, someone could rewrite it to work on canvas and save the slicing info in XCF. That's all, really.
As already stated in #gimp, it's an awesome idea. You only forgot to link to the paper :)
http://www.cs.huji.ac.il/~danix/mvclone/
Martin Nordholts
2011-02-13 17:55:27 UTC (about 14 years ago)
Thanks for a good start on this Barak
I would like to add:
Port UI code to a non-low level language
Hacking UI code in C is a resource eater for us, we should use C for quick and efficient pixel processing but not for creating buttons. It would be interesting to make changes to the GIMP codebase that would allow us for example write the Pointer Information Dialog in JavaScript.
/ Martin
Liam R E Quin
2011-02-13 17:56:48 UTC (about 14 years ago)
Or is _a_ way available even if not the default.
So it would make a good project, and fits within the Grand Vision.
Liam
On the Internet no-one can touch your feet.
2011-02-15 23:01:58 UTC (about 14 years ago)
We (or actually you) added support for defining plug-in dialog UIs using GtkBuilder some time ago. But there has been no progress on this since then. As far as I can see there is still no support for using GIMP specific widgets from GtkBuilder and no other plug-ins have been ported yet. Perhaps that would be an area that should get some attention from a GSoC developer.
Definitely sounds more useful to me than introducing Javascript to GIMP. I somewhat doubt that we would get more developers hacking on the core if we added JS as another entry barrier.
Liam R E Quin
2011-02-16 01:18:53 UTC (about 14 years ago)
Note, when I suggested that gimp should always start with a blank canvas, ready to paint on, people said it was impossible because they didn't know how big to make the default document. Why it couldn't be an option (e.g. if you normally work on indexed or greyscale images) or a template, I couldn't figure out, but this would remove that objection at least.
Liam
Bogdan Szczurek
2011-02-25 01:30:38 UTC (about 14 years ago)
Great thing to bring this up!
Oh yeah, thumbs up for that! :)
How about a new type of widget “SizeArea” or somethin' that would remeber value along with entered measurement unit? I know this is a long shot and thing more feasible in vector editing app but still I've been in a couple of situations when I'd love to have such thing. Currently all I can have is widgets that get value and mercilessly convert it to default units no matter what. I think it would be cute if such widget could hold equation leading to some answer e.g. “2 * .25 in + 6 in”. It would display then “6.5 in” but it would allow to correct equation if clicked upon. “.25” could be for example bleeds.
Slicing tool
Am I the only one who feels that current notion of slices is well… a bit retarded? I'm often in a position when I've got to make slices that are overlapping or take only some selected layers into account when producing output images. In such cases slices like shown and widely implemented are nothing short of being useless. Agreed: the slices type presented make producing “WYSIWYG” sites easy but I don't think they're much use for HTML writers. So, long story short I propose making slices that could look something like that:
The biggest would be e.g. background, next (in the terms of size) would be menu and the smallest would be some icon.
And let me throw in another thing. It's been in my head for some time but now I think it's good to show it to the world. Just in the matter of shear curiosity: I'd like to see some conceptual work/code/working example/whatever about automatically configurable grid processing. It may be more of GEGL project than GIMP one, but I believe still beneficial in the end. Since 3D rendering engines do that, maybe it would work nice in 2D world too. Of course a metric and some kind of benchmark would be needed to decide if sending some part of work over network to another node is beneficial. Anyway I think it have chances to make things snappy even on slow machines. I see it as a something between freakin' fat workstations, thin clients with some heavy “mother goose” and mighty cluster. It would (hopefully ;)) help to use what is at hand more optimally.
Best regards! thebodzio
2011-02-25 10:32:47 UTC (about 14 years ago)
GEGL is designed to be able to split up the rendering requests from the public part of it's API internally and to distribute it among threads/processes/hosts without needing changes to the application using GEGL. At the moment there is only experimental support for using threads in this fashion, but the architecture has been made with distributed processing in mind. This also applies to the GeglBuffers for which there a few years ago already was done experiments with doing multi process/user concurrent manipulation of the same buffers.
/Øyvind K.
                                                 -- William Gibson
Bogdan Szczurek
2011-02-26 17:38:41 UTC (about 14 years ago)
All of which makes a great opportunity to go from “some experiments” to “actual application” :). Agreed such project would fit GEGL better but some GUI to control GEGL behaviour in that matter would be required nevertheless. Besides… design with delegating processing to multiple threads in mind is one thing and “making it just work” over net is another. That's why I think some (at least conceptual) work is needed to make such thing automatically configurable (avahi shouting about such service available maybe, some metric to decide if letting a node to take part of work is beneficial).
LightningIsMyName
2011-03-01 21:52:02 UTC (about 14 years ago)
The nearly finalised project list for GSoC 2011 is available at the wiki: http://gimp-wiki.who.ee/index.php/Hacking:GSoC_2011/Ideas
Users who have a comment on the list should raise it now. The ideas list was divided in to two parts, as discussed on IRC. Developers who wish to make small corrections should feel free to do so, but please do not move projects between the lists / add/remove projects or do any other major change without a discussion first.
GIMP on! ~LightningIsMyName
Kevin Cozens
2011-03-01 22:19:55 UTC (about 14 years ago)
I did mention one possible GSoC idea was a rewrite of gimp-perl. The binding seems to be a bit of a mess and could stand some clean up. I may squeeze in a bit more time to make sure it at least works with 2.6 and git master but I won't attempt a rewrite until after I do some of the planned work for TinyFu version 2.
Bogdan Szczurek
2011-03-02 00:20:29 UTC (about 14 years ago)
Great to have such list! :)
I've got a word about slicing tools. I think it would be even nicer if slices as that:
didn't have to be considered as nested. If they'd be treated as independent entities it would be easy to have e.g.:
Each slice could have, as one of properties, list of layers brought into account when generating final slice image. That way one would be able to easily “cut” some slice for background, even if the background is overlayed with some content.
Furthermore, slices could have been able to create “stacks” of graphics exported as one image. I mean a situation when “idle” for of menu is on one layer, “hover” on another and finally “clicked” on third. So: one slice is created, “stack” for that slice is defined in such a way that first layer is topmost part of exported graphics, second layer is the middle and so on. It would give from single slice final image of:
----------------------- | idle |
| hover |
| clicked |
Vertical alignment is choosen purely for the example's sake. Heck! One could even make some tool to visually place such images from different slices. Details remain to be discussed :). I think that gain from such solution is great. This way one could easily create not only menus but also sets of icons cropped from source image with css. And to do it without creating another image or layer on page layout project with icons packed accordingly, but “cut” them directly from layout. Elements could be then placed only once, so possibility of making a mistake while exporting them would lower considerably.
That's just a couple of simple things that “traditional” slices make somewhat horrid to achieve :). I'd love to see something like that in GIMP! :D
Best regards!
thebodzio
2011-03-02 07:06:13 UTC (about 14 years ago)
I can remember there was an intention to rewrite iwarp plug-in as a tool...
With respect,
Tobias Jakobs
2011-03-02 07:59:03 UTC (about 14 years ago)
Sven had some time ago the idea of a PDB to D-Bus bridge. Wouldn't that a nice GSoC project?
Regards, Tobias
2011-03-02 13:56:29 UTC (about 14 years ago)
It's doable on top of the gegl op that powers Cage transform tool. That op "only" :) has to be tought working outside of the cage. Sounds like a good GSoC project to me.
Bill Skaggs
2011-03-02 17:52:27 UTC (about 14 years ago)
On Tue, Mar 1, 2011 at 1:52 PM, LightningIsMyName < lightningismyname@gmail.com> wrote:
Bill Skaggs
2011-03-02 17:58:14 UTC (about 14 years ago)
For some reason my text disappeared when I hit send for the previous message -- sorry! Here
is what I wrote:
It is very important to make sure that each project in the list has a developer who is prepared
to sign up to mentor it. There are two reasons for this. First, because it is a waste of time
and effort for students to apply for a project that nobody is prepared to mentor. Second,
because I am afraid that some of the proposals are actually ill-conceived, and that will become
apparent because no developer will be willing to mentor them in the form as written.
-- Bill
2011-03-08 18:21:14 UTC (about 14 years ago)
In 2009 and 2010 guiguru did GIMP related usability workshops that haven't resulted in a spec yet (the 2008 one has), but some useful material presumably is available:
- vector layers and drawing geometric primitives [1] - unification of selection tools (no reports from it, IIRC)
[1] http://blog.mmiworks.net/2009_07_01_archive.html
Could those be GSoC projects as well? At least unification of selection tools could become a project to povide infrastructure for gegl based selection tools (or am I missing an existing one?).
Another idea was, IIRC, an on-canvas iWarp implementation on top of improved gegl op implemented last GSoC for cage transform so that it worked out of cage.
Tobias Oelgarte
2011-03-08 18:40:39 UTC (about 14 years ago)
I could think of fully hardware accelerated rendering. Most modern hardware provides accelerated rendering and many tools could be speed up significantly. The CPU just doesn't scale well when it comes to current image resolutions and some brush types (smooth, smear, etc.). Also the performance to display multiple layers or adjusting them could be much faster.
Just remembering my last work (a drawing), that i barely could finish, since it got very slow over time.
Am 08.03.2011 19:21, schrieb Alexandre Prokoudine:
Bogdan Szczurek
2011-03-08 18:56:13 UTC (about 14 years ago)
I think it would be more of a wish for GEGL as the GIMP's engine of tomorrow ;).
My best!
thebodzio
Bogdan Szczurek
2011-03-08 19:23:24 UTC (about 14 years ago)
I'm not convinced of the notion of vector layers. Sure they can be nice addition but I fear they'll end up being quite frustrating. I think so because to make them as ellastic and usable as in vector graphics editors one'd have to double such editor in GIMP. If one won't do that then there's a danger of whole tool being not much more than a toy. I'm not generally enemy of the idea, but I've got my fears and doubts if it hase to be done that way.
I've got a dream about visual editing program consisting of different components, each taking care of one of presentation aspects with one underlaying rendering engine (target aware angine—I don't like cairo's “I don't care what's on the end” attitude ;)). Such program would load dynamically a set of editing tools if needed and only the needed. So if one's editing vector there'll be full blown toolset for that–no compromises, no implementation doubling. If one's to typeset a book, there would be loaded typesetting engine loaded with all controls available and so on. But I digress :).
I think that could do some good :).
I like that :).
2011-03-08 19:24:29 UTC (about 14 years ago)
"Awww, well, come on over, baby, step into my time machine." (c) GFR
http://git.gnome.org/browse/gegl/log/?h=gsoc2009-gpu
2011-03-08 19:35:14 UTC (about 14 years ago)
There are, in fact, different proposal, if you read the page. Each of the three groups came up with a different idea. So there is not *one* way, but actually three ways for you to have fears and doubts about :)
It's what we, utter geeks, call a framework :)
Deneba/ACD Canvas was an attempt to create such one, but it was done on top of software started in mid 80s. Sometimes a whole week passes when I don't wake up in cold sweat seeing it in my dreams.
Tobias Oelgarte
2011-03-08 19:35:44 UTC (about 14 years ago)
I really miss some basic vector functionality in Gimp. In my last works i used Inkscape and Gimp together. Drawing sharp outlines in Inkscape, exporting them to PNG and imported them into Gimp again, to work with brushes and colors. Basically i used Inkscape to create Alpha-Layers for accurate strokes. The exporting and importing was some kind of pain. Just the ability to create basic shapes (Bezier contours), would be a great improvement. It doesn't need to provide anything. But it should be as simple as the Polygon-Tool and the Node-Tool from Inkscape. That would basically all i would need. Opening Inkscape, drawing a simple Shape (outline), exporting it, importing it and then fill it in Gimp is not a comfortable way.
Am 08.03.2011 20:23, schrieb Bogdan Szczurek:
I like that :).
Bogdan Szczurek
2011-03-08 19:49:52 UTC (about 14 years ago)
buehhehehehe :D
Best!
thebodzio
Bogdan Szczurek
2011-03-08 20:00:38 UTC (about 14 years ago)
Oh dear! ;)
That adds +10 to "coolness" but don't let everybody know ;)
Funny stuff… :). But seriously, sometimes it's good for somebody to try a thing that didn't work out last time. Because of that stubborness we're able to fly by airplanes nowadays ;).
I consider idea of one flexible uberapp much more sensible and appealing than implementing wee bit of “alien world” in different apps—just seems half-solution for me.
Best! thebodzio
Bogdan Szczurek
2011-03-08 20:07:42 UTC (about 14 years ago)
Skippping back and forth from Inkscape to GIMP doesn't sound good to me either, but wasn't existing “path” tool sufficient in your case? Don't get me wrong, I'm just trying to understand the task you were up to do.
My best! thebodzio
2011-03-08 20:20:20 UTC (about 14 years ago)
So do I,. and a "framework" that can make something like that happen is called GEGL ;)
http://pippin.gimp.org/tmp/gegl-foo/
Buried in history of the GEGL repo is a GTK+ based UI with at various revisions both freehand painting with simple dynamics, as well as.. node based both bezier and spiro curve editing bits, integrated with generic layer filters and more.. it is/was not really that much code, but it was sloppy code thrown together with left-over pieces from a video editor.
I am from time to time toying with resurrecting that project as a minimal thing show-casing what is possible to achieve. If I do get around to do that I would probably avoid doing it with C though, so it would be a complete rewrite and not really a resurrection.
                                                 -- William Gibson
Bogdan Szczurek
2011-03-08 20:30:06 UTC (about 14 years ago)
I'm happy to hear that! :)
Best regards!
thebodzio
Tobias Oelgarte
2011-03-08 20:31:05 UTC (about 14 years ago)
Am 08.03.2011 21:07, schrieb Bogdan Szczurek:
My best! thebodzio
At first i have to note, that the usage of the current path tool in Gimp is a pain. Its really hard, needlessly complicated to work with. The behavior of Inkscape is way superior, even if it is not perfect. Also it is hard to manage multiple paths at once. I won't say that Gimp is missing a feature you could use for the same things, but i just don't want to use it, since it takes me longer to work with it as Skipping back and forth between Inkscape and Gimp... (not a good sign for useability)
