gimp-item-transform-scale vs gimp-drawable-transform-scale
12 of 12 messages available
gimp-item-transform-scale vs gimp-drawable-transform-scale Alexander Rabtchevich 11 Feb 09:31
  gimp-item-transform-scale vs gimp-drawable-transform-scale Michael Natterer 11 Feb 11:05
   gimp-item-transform-scale vs gimp-drawable-transform-scale Alexander Rabtchevich 11 Feb 11:26
    gimp-item-transform-scale vs gimp-drawable-transform-scale Michael Natterer 11 Feb 11:43
     gimp-item-transform-scale vs gimp-drawable-transform-scale Alexander Rabtchevich 11 Feb 12:02
      gimp-item-transform-scale vs gimp-drawable-transform-scale Ofnuts 11 Feb 13:13
       gimp-item-transform-scale vs gimp-drawable-transform-scale Joao S. O. Bueno 11 Feb 13:23
       gimp-item-transform-scale vs gimp-drawable-transform-scale " 11 Feb 14:41
        gimp-item-transform-scale vs gimp-drawable-transform-scale Joao S. O. Bueno 11 Feb 15:20
      gimp-item-transform-scale vs gimp-drawable-transform-scale Michael Natterer 11 Feb 14:57
       gimp-item-transform-scale vs gimp-drawable-transform-scale Alexander Rabtchevich 11 Feb 15:34
      gimp-item-transform-scale vs gimp-drawable-transform-scale Michael Natterer 11 Feb 14:58
2011-02-11 09:31:54 UTC (about 14 years ago)
Hello
I compiled current git and found gimp-drawable-transform-scale became deprecated although it works. The proposed replacement doesn't take scaling algorithm as a parameter. Is it a way to a user to select scaling algorithm anymore?
With respect, Alexander Rabtchevich
Michael Natterer
2011-02-11 11:05:13 UTC (about 14 years ago)
On Fri, 2011-02-11 at 11:31 +0200, Alexander Rabtchevich wrote:
Hello
It's all documented.
regards, --mitch
2011-02-11 11:26:08 UTC (about 14 years ago)
Hello
regards, --mitch
Sorry, but procedure browser only says: This procedure scales the specified item. If a selection exists and the item is a drawable, the portion of the drawable which lies under the selection is cut from the drawable and made into a floating selection which is then scaled by the specified amount. The return value is the ID of the scaled item. If there was no selection or the item is not a drawable, this will be equal to the item ID supplied as input. Otherwise, this will be the newly created and scaled drawable.
Michael Natterer
2011-02-11 11:43:42 UTC (about 14 years ago)
Hello
regards, --mitch
I apologize, you are right. I apparently only added links to the new context functions from the new selection API.
It's the new context API, e.g. gimp_context_set_interpolation(). Will add the docs after work today.
sorry, --mitch
2011-02-11 12:02:19 UTC (about 14 years ago)
No needs to apologize, it's a work in progress
Another question here - is there a plugin conversion guide somewhere? I tried to run wavelet-sharpen plugin, compiled for 2.7, but it fails with 2 messages:
Could not execute plug-in "wavelet-sharpen" (/opt/gimp-2.7/lib/gimp/2.0/plug-ins/wavelet-sharpen) because it uses an obsolete version of the plug-in protocol.
And
gimp_plug_in_handle_proc_run: ERROR
Is there an easy way to convert a source from old notation to the new one? I mean a list of procedures and so on that have been changed...
Hello
regards, --mitch
sorry, --mitch
With respect,
2011-02-11 13:13:20 UTC (about 14 years ago)
Hmmm. What proportion of existing plug-ins working in 2.6 will have to be rewritten for 2.8? In my neck of the IT woods, within the same version backward compatibility is implied... And if a rewrite is necessary we will have to support both versions for quite some time (some people fall in love with some plug-ins and won't upgrade Gimp until there is a new version of their beloved plug-in). And do it again when 3.0 shows up...
Joao S. O. Bueno
2011-02-11 13:23:18 UTC (about 14 years ago)
Most existing plug-ins will just work in gimp 2.8 - at least in non-layer group using images (and
most plug-ins don't care about more than the current layer/drawable, so these will work anyway, just
not on the group, but on individual layers).
The fact that some procedures are marked as " deprecated" does not mean they will
stop working in gimp-2.8: they are still there. New plug-ins are however expected not to use
these calls (an expectation that is strongly enforced by the fact that the deprecated procedures have their documentation replaced by a stub)
When the time comes to GIMP 3.0, that is another history - - chanigng in the major version number
also means it is time to break backwards compatibility, and remove deprecated functions. But that is not the case for 2.8.
js
2011-02-11 14:41:43 UTC (about 14 years ago)
But the rewriting needed for 3.0, porting to be GEGL ops, can be done already now, and I would strongly encourage GIMP to make use of GEGL ops more on an equal footing to GIMP plug-ins (and not be hidden in an own menu under the GEGL tool like it is now) so that freshly developed plug-ins can be done as GEGL ops already now and be more future proof.
/Øyvind K.
                                                 -- William Gibson
http://pippin.gimp.org/                     http://gegl.org/contribute.html
Michael Natterer
2011-02-11 14:57:38 UTC (about 14 years ago)
All plugins are binary-compatible within the 2.x series, the error you are seeing is because your plugin still links to an old libgimp version installed somewhere, and libgimp and the gimp app can only work together within one protocol version.
Make sure your plugins find the right libgimp and everything will be fine.
ciao, --mitch
Michael Natterer
2011-02-11 14:58:36 UTC (about 14 years ago)
And no, the new API is still in flux, but there will be an undeprecation guide for 2.8
ciao, --mitch
Joao S. O. Bueno
2011-02-11 15:20:39 UTC (about 14 years ago)
For example, people usually marvel at the GEGL c2g filter - and it is completly hidden
under tools->GEGL operations.
Maybe it could be somewhat more exposed as an option in Colors->desaturate, or filters->artistic?
js ->
/Øyvind K.
«The future is already here. It's just not very evenly distributed»                                                  -- William Gibson http://pippin.gimp.org/                     http://gegl.org/contribute.html _______________________________________________ Gimp-developer mailing list
2011-02-11 15:34:39 UTC (about 14 years ago)
Thank you, making a script with export helped to solve it.
ciao, --mitch
With respect,
