Where can I help?
7 of 7 messages available
Where can I help? Stephen Greenwalt 25 Jan 08:40
  Where can I help? " 26 Jan 11:09
   Where can I help? Patrick Horgan 07 Feb 03:48
    Where can I help? Martin Nordholts 07 Feb 06:52
     Where can I help? Patrick Horgan 07 Feb 12:33
      Where can I help? Martin Nordholts 07 Feb 17:03
       Where can I help? Patrick Horgan 13 Feb 23:53
Stephen Greenwalt
2011-01-25 08:40:39 UTC (almost 15 years ago)
Where can I help?
Where can I help? Here's an ultra-short overview of my background:
* 18 years overall development experience including software engineering, team leader, and senior IT management.
* Expert-level C, C++, C#, etc. knowledge.
* Extensive 3D design and development knowledge (texture mapping, 3D scene rendering, lighting, etc).
* Decent knowledge of file format specs for most common image file formats, as well as some experience writing apps that make in-memory (on the fly) changes to image data.
* Have tried my hand at various self-invented strategies for pattern recognition within image data.
* Now working, oddly enough, in unrelated areas dealing with Lean Manufacturing, Quality Systems, etc.
* Have been using GIMP for certain things for about 3 years or so.
* Have some extra time I could devote . . . but will wait to quantify that until I hear where you need help.
* Well, there's more . . .
Let me know.
Thanks,
Steve Greenwalt Layton, Utah
2011-01-26 11:09:23 UTC (almost 15 years ago)
Where can I help?
On Tue, Jan 25, 2011 at 8:40 AM, Stephen Greenwalt wrote:
Where can I help? Here's an ultra-short overview of my background: * Have some extra time I could devote . . . but will wait to quantify that until I hear where you need help.
This happens from time to time, sometimes people actually have the time and capability to help, quite often they ask for help - consume time to get up to speed, and then nothing happens. To avoid wasting more time on a reply to this email as well as other requests via mail, IRC and other places I have started writing up a list of pointers about the current state of GIMPs refactoring to use GEGL and where help would be appreciated.
See http://gegl.org/contribute.html for this list.
/Øyvind Kolås.
                                                 -- William Gibson
http://pippin.gimp.org/                            http://ffii.org/
Gimp-developer mailing list
Patrick Horgan
2011-02-07 03:48:03 UTC (almost 15 years ago)
Where can I help?
I'm trying to come up to speed on gegl and built the hello-world.c example from the examples directory. The text from that example doesn't show up on the output, although the mandelbrot zoom works wonderfully. Is there anything I can do to figure it out? Can someone point me toward something to read to understand where things are going on?
Patrick
Martin Nordholts
2011-02-07 06:52:26 UTC (almost 15 years ago)
Where can I help?
One thing you can do is to run with the env var GEGL_DEBUG set to "process". That will give some output on how things are processed in the graph. Does the output for the text node look weird?
/ Martin
Patrick Horgan
2011-02-07 12:33:01 UTC (almost 15 years ago)
Where can I help?
/ Martin
btw, forgot to say this is on Ubuntu using gegl and babl from git trunk and gcc 4.6
Could it be where it says:
Using cache for pad 'output' on "gegl:text 0x9017e90"
Here's one time through the loop:
For "gegl:fractal-explorer 0x905a000" have_rect = 0,0 512×384 For "gegl:fractal-explorer 0x905a000" have_rect = 0,0 512×384 For "gegl:fractal-explorer 0x905a000" have_rect = 0,0 512×384 For "gegl:fractal-explorer 0x905a000" have_rect = 0,0 512×384 For "gegl:text 0x9017f38" have_rect = 0,0 130×13 For "gegl:fractal-explorer 0x905a000" have_rect = 0,0 512×384 For "gegl:nop 'proxynop-input' 0x90179f8" have_rect = 0,0 512×384 For "gegl:text 0x9017e90" have_rect = 0,0 135×13 For "gegl:scale 0x9017d40" have_rect = 0,0 135×13 For "gegl:opacity 0x9017de8" have_rect = 0,0 135×13 For "gegl:translate 0x9017c98" have_rect = 1,1 137×15 For "gegl:over 0x9017bf0" have_rect = 0,0 512×384 For "gegl:nop 'proxynop-output' 0x9017b48" have_rect = 0,0 512×384 gegl_processor_set_rectangle() node = gegl:display 0x90178a8 rectangle = 0, 0 512×384
For "gegl:fractal-explorer 0x905a000" have_rect = 0,0 512×384 For "gegl:nop 'proxynop-input' 0x90179f8" have_rect = 0,0 512×384 For "gegl:text 0x9017e90" have_rect = 0,0 135×13 For "gegl:scale 0x9017d40" have_rect = 0,0 135×13 For "gegl:opacity 0x9017de8" have_rect = 0,0 135×13 For "gegl:translate 0x9017c98" have_rect = 1,1 137×15 For "gegl:over 0x9017bf0" have_rect = 0,0 512×384 For "gegl:nop 'proxynop-output' 0x9017b48" have_rect = 0,0 512×384 For "gegl:nop 'proxynop-output' 0x9017b48" have_rect = 0, 0 512×384 need_rect = 0, 0 512×384 result_rect = 0, 0 512×384 For "gegl:over 0x9017bf0" have_rect = 0, 0 512×384 need_rect = 0, 0 512×384 result_rect = 0, 0 512×384
For "gegl:nop 'proxynop-input' 0x90179f8" have_rect = 0, 0 512×384 need_rect = 0, 0 512×384 result_rect = 0, 0 512×384 For "gegl:translate 0x9017c98" have_rect = 1, 1 137×15 need_rect = 1, 1 137×15 result_rect = 1, 1 137×15
For "gegl:fractal-explorer 0x905a000" have_rect = 0, 0 512×384 need_rect = 0, 0 512×384 result_rect = 0, 0 512×384 For "gegl:opacity 0x9017de8" have_rect = 0, 0 135×13 need_rect = 0, 0 135×13 result_rect = 0, 0 135×13
For "gegl:scale 0x9017d40" have_rect = 0, 0 135×13 need_rect = 0, 0 135×13 result_rect = 0, 0 135×13
For "gegl:text 0x9017e90" have_rect = 0, 0 135×13 need_rect = 0, 0 0×0 result_rect = 0, 0 135×13
Using cache for pad 'output' on "gegl:text 0x9017e90" For "output" processing pad 'gegl:scale 0x9017d40' result_rect = 0, 0 135×13 For "output" processing pad 'gegl:opacity 0x9017de8' result_rect = 0, 0 135×13
For "output" processing pad 'gegl:translate 0x9017c98' result_rect = 1, 1 137×15
For "output" processing pad 'gegl:fractal-explorer 0x905a000' result_rect = 0, 0 512×384
For "output" processing pad 'gegl:nop 'proxynop-input' 0x90179f8' result_rect = 0, 0 512×384
For "output" processing pad 'gegl:over 0x9017bf0' result_rect = 0, 0 512×384 For "output" processing pad 'gegl:nop 'proxynop-output' 0x9017b48' result_rect = 0, 0 512×384
Martin Nordholts
2011-02-07 17:03:13 UTC (almost 15 years ago)
Where can I help?
/ Martin
Yes maybe, caches don't always work like they should. If you disable that code, does it become better? You can also set a breakpoint in process() for text and see that the thread of execution looks reasonable when you single-step through the code.
/ Martin
Patrick Horgan
2011-02-13 23:53:01 UTC (almost 15 years ago)
Where can I help?
/ Martin
I haven't figured it out, but have found that if I switch this:
gegl_node_link_many (mandelbrot, layer, display, NULL); gegl_node_connect_to (text, "output", layer, "aux");
to
gegl_node_link_many (text, layer, display, NULL); gegl_node_connect_to (mandelbrot, "output", layer, "aux"); g_printf("layer has aux pad: %d\n", gegl_node_has_pad(layer,"aux"));
I get the text, but not the mandelbrot, and the g_printf reports that layer does have the aux pad (of course it would have printed something on its own to tell me if the pad wasn't there).
Patrick
