Enhancement requests on color-management, glossary, and other pages
Enhancement requests on color-management, glossary, and other pages RyōTa SimaMoto 11 Jan 17:27
RyōTa SimaMoto
2011-01-11 17:27:53 UTC (over 14 years ago)
Hi all!
YAMAKAWA Yoshinori, the current developer of Separate+ plug-in package for GIMP, gives us some important notices.
concepts/color-management.xml: 169..171 and 174..176 (Display Calibration and Profiling) | In addition there are further adjustments that are loaded into the video | card memory ...
| Probably under Windows XP or Mac OS, the operating system loads this | information (LUT) in the video card in the process of starting your | computer.
Is the result of 'adjustments' identical with 'this information (LUT)'? If so, please specify relation of them.
And in the same paragraph (line 171..173) | This information is stored in the monitor profile in the so-called vgct tag. would be more preferable when it goes: | This information is stored in the monitor profile as vcgt tag. Note that vcgt stands for "Video Card Gamma Table". (This signature should be written in lower letters, and we can't use tags that capitalize all letters between them.)
concepts/plugins.xml: 264 (Installing New Plugins / Apple Mac OS X) | or darwinports,
and appendix/glossary.xml: 255..261
| DARWINORTS
| Darwin Ports Package Manager for OS X |
| http://darwinports.org
should be:
| or macports,
and
| MACPORTS
| MacPorts Package Manager for OS X |
Because this project changes its name. If you access darwinports.org, it redirects itself to www.macports.org.
glossary/glossary.xml: 1428..1430 (glossterm=PDF) | As with PostScript, GIMP's support of the PDF format | is through the free Ghostscript libraries. should be removed, because PDF files are loaded by the file-pdf plug-in, which runs with help by Poppler library, without Ghostscript. A PDF file can be also read by the file-ps plug-in which still requires help of Ghostscript, but GIMP lets the file-pdf plug-in to take precedence over the file-ps plug-in on this task.
And I think Yamakawa's project should be linked on the GIMP Documentation, rather than the older project Separate plug-in that is introduced at the glossary page as an experimental service of CMYK support for GIMP. We may update this introduction to include description about Separate+, (of course this is not experimental), though Alastair M. Robinson, the original developer of the former suspended project, gives a direct pointer to the newer project on his home page with an honest message "you are strongly urged to use his(:Yamakawa's) version instead of mine!", so that users from the GIMP Documentation can easily access the newest plug-in package.
Separate+ project is here: http://cue.yellowmagic.info/softwares/separate.html
With cheers to the new year of GIMP's upgrade, -=-=-=-=-=
SimaMoto,RyōTa
http://code.google.com/p/gimp-doc-ja/
