"X" stuck on to start of all libtool options...
8 of 8 messages available
"X" stuck on to start of all libtool options... David Gowers (kampu) 09 Jan 07:40
  "X" stuck on to start of all libtool options... David Gowers (kampu) 09 Jan 22:58
   "X" stuck on to start of all libtool options... David Gowers (kampu) 09 Jan 23:04
    "X" stuck on to start of all libtool options... David Gowers (kampu) 09 Jan 23:29
     "X" stuck on to start of all libtool options... Liam R E Quin 10 Jan 00:14
      "X" stuck on to start of all libtool options... David Gowers (kampu) 10 Jan 03:04
       "X" stuck on to start of all libtool options... David Gowers (kampu) 10 Jan 07:40
        "X" stuck on to start of all libtool options... David Gowers (kampu) 12 Jan 01:14
2011-01-09 07:40:51 UTC (over 14 years ago)
After running
'./autogen.sh --prefix=/usr' then './configure --prefix=/usr', when I run 'make' on git HEAD (7057487...), the libtool options/execution seem to get mangled in a strange way:
make all-recursive make[1]: Entering directory `/home/ion/dihinai/st/xra/gimp' Making all in m4macros
make[2]: Entering directory `/home/ion/dihinai/st/xra/gimp/m4macros' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/ion/dihinai/st/xra/gimp/m4macros' Making all in tools
make[2]: Entering directory `/home/ion/dihinai/st/xra/gimp/tools' make[3]: Entering directory `/home/ion/dihinai/st/xra/gimp/tools' /bin/sh ../libtool --tag=CC --mode=link gcc -Os -Wall -Wdeclaration-after-statement -Wmissing-prototypes -Wstrict-prototypes -Wmissing-declarations -Winit-self -Wpointer-arith -Wold-style-definition -Wmissing-format-attribute -Wformat-security -o gimptool-2.0 gimptool.o -pthread -lgtk-x11-2.0 -lgdk-x11-2.0 -latk-1.0 -lgio-2.0 -lpangoft2-1.0 -lpangocairo-1.0 -lgdk_pixbuf-2.0 -lm -lcairo -lpng14 -lpango-1.0 -lfreetype -lfontconfig -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lrt -lglib-2.0 ../libtool: line 869: X--tag=CC: command not found ../libtool: line 902: libtool: ignoring unknown tag : command not found ../libtool: line 869: X--mode=link: command not found ../libtool: line 1036: *** Warning: inferring the mode of operation is deprecated.: command not found
../libtool: line 1037: *** Future versions of Libtool will require --mode=MODE be specified.: command not found ../libtool: line 2281: X-Os: command not found ../libtool: line 2281: X-Wall: command not found ../libtool: line 2281: X-Wdeclaration-after-statement: command not found ../libtool: line 2281: X-Wmissing-prototypes: command not found ../libtool: line 2281: X-Wstrict-prototypes: command not found ../libtool: line 2281: X-Wmissing-declarations: command not found ../libtool: line 2281: X-Winit-self: command not found ../libtool: line 2281: X-Wpointer-arith: command not found ../libtool: line 2281: X-Wold-style-definition: command not found ../libtool: line 2281: X-Wmissing-format-attribute: command not found ../libtool: line 2281: X-Wformat-security: command not found ../libtool: line 2450: Xgimptool-2.0: command not found
Fatal server error: Server is already active for display 0 If this server is no longer running, remove /tmp/.X0-lock and start again.
Please consult the The X.Org Foundation support at http://wiki.x.org
for help.
(it continues compiling if I instead run 'sudo make'. I expect the end result would be wrong or strange, though) ..
another strange message:
../libtool: line 5228: Xgcc "" "" "" "" "" "" "" "" "" "" "" -o @OUTPUT@ test-clipboard.o -pthread -lgtk-x11-2.0 -lgdk-x11-2.0 -latk-1.0 -lgio-2.0 -lpangoft2-1.0 -lpangocairo-1.0 -lgdk_pixbuf-2.0 -lm -lcairo -lpng14 -lpango-1.0 -lfreetype -lfontconfig -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lrt -lglib-2.0: command not found
Has anyone else here encountered this ??
2011-01-09 22:58:21 UTC (over 14 years ago)
Looks like this is the actual issue:
After removing 'configure', it's apparent that 'autogen.sh' doesn't regenerate it, instead giving ambiguous errors/warnings..
For anyone else's reference, this occurs with
autoconf 2.68 automake 1.9.6 + 1.11.1
glib 2.26.1
gtk 2.22.1
output log of './autogen.sh --prefix=/usr' follows:
WARNING: aclocal's directory is /usr/local/share/aclocal, but... no file /usr/local/share/aclocal/glib-2.0.m4 You may see fatal macro warnings below. If these files are installed in /some/dir, set the ACLOCAL_FLAGS environment variable to "-I /some/dir" or install /usr/local/share/aclocal/glib-2.0.m4.
[... (repeats x 4)]
aclocal:configure.ac:425: warning: macro `AM_GLIB_GNU_GETTEXT' not found in library
aclocal:configure.ac:450: warning: macro `AM_PATH_GLIB_2_0' not found in library aclocal:configure.ac:479: warning: macro `AM_PATH_GTK_2_0' not found in library configure.ac:157: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
../../lib/autoconf/lang.m4:194: AC_LANG_CONFTEST is expanded from... ../../lib/autoconf/general.m4:2662: _AC_LINK_IFELSE is expanded from... ../../lib/autoconf/general.m4:2679: AC_LINK_IFELSE is expanded from... /usr/local/share/aclocal/libtool.m4:363: _LT_AC_SYS_LIBPATH_AIX is expanded from...
/usr/local/share/aclocal/libtool.m4:5560: AC_LIBTOOL_PROG_LD_SHLIBS is expanded from...
/usr/local/share/aclocal/libtool.m4:2783: _LT_AC_LANG_C_CONFIG is expanded from...
/usr/local/share/aclocal/libtool.m4:2782: AC_LIBTOOL_LANG_C_CONFIG is expanded from...
/usr/local/share/aclocal/libtool.m4:80: AC_LIBTOOL_SETUP is expanded from... /usr/local/share/aclocal/libtool.m4:60: _AC_PROG_LIBTOOL is expanded from... /usr/local/share/aclocal/libtool.m4:25: AC_PROG_LIBTOOL is expanded from... /usr/local/share/aclocal/libtool.m4:6548: AM_PROG_LIBTOOL is expanded from... configure.ac:157: the top level
/usr/local/share/aclocal/libtool.m4:2864: _LT_AC_LANG_CXX_CONFIG is expanded from...
/usr/local/share/aclocal/libtool.m4:2863: AC_LIBTOOL_LANG_CXX_CONFIG is expanded from...
/usr/local/share/aclocal/libtool.m4:1908: _LT_AC_TAGCONFIG is expanded from... /usr/local/share/aclocal/libtool.m4:80: AC_LIBTOOL_SETUP is expanded from... /usr/local/share/aclocal/libtool.m4:60: _AC_PROG_LIBTOOL is expanded from... /usr/local/share/aclocal/libtool.m4:25: AC_PROG_LIBTOOL is expanded from... /usr/local/share/aclocal/libtool.m4:6548: AM_PROG_LIBTOOL is expanded from... configure.ac:157: the top level
/usr/local/share/aclocal/libtool.m4:4177: _LT_AC_LANG_GCJ_CONFIG is expanded from...
/usr/local/share/aclocal/libtool.m4:4176: AC_LIBTOOL_LANG_GCJ_CONFIG is expanded from...
../../lib/autoconf/lang.m4:194: AC_LANG_CONFTEST is expanded from... ../../lib/autoconf/general.m4:2662: _AC_LINK_IFELSE is expanded from... ../../lib/autoconf/general.m4:2679: AC_LINK_IFELSE is expanded from... aclocal.m4:369: _LT_AC_SYS_LIBPATH_AIX is expanded from... aclocal.m4:5554: AC_LIBTOOL_PROG_LD_SHLIBS is expanded from... aclocal.m4:2789: _LT_AC_LANG_C_CONFIG is expanded from... aclocal.m4:2788: AC_LIBTOOL_LANG_C_CONFIG is expanded from... aclocal.m4:86: AC_LIBTOOL_SETUP is expanded from... aclocal.m4:66: _AC_PROG_LIBTOOL is expanded from... aclocal.m4:31: AC_PROG_LIBTOOL is expanded from... aclocal.m4:6542: AM_PROG_LIBTOOL is expanded from... configure.ac:157: the top level
../../lib/autoconf/lang.m4:194: AC_LANG_CONFTEST is expanded from... ../../lib/autoconf/general.m4:2662: _AC_LINK_IFELSE is expanded from... ../../lib/autoconf/general.m4:2679: AC_LINK_IFELSE is expanded from... aclocal.m4:369: _LT_AC_SYS_LIBPATH_AIX is expanded from... aclocal.m4:2866: _LT_AC_LANG_CXX_CONFIG is expanded from... aclocal.m4:2865: AC_LIBTOOL_LANG_CXX_CONFIG is expanded from... aclocal.m4:1914: _LT_AC_TAGCONFIG is expanded from... aclocal.m4:86: AC_LIBTOOL_SETUP is expanded from... aclocal.m4:66: _AC_PROG_LIBTOOL is expanded from... aclocal.m4:31: AC_PROG_LIBTOOL is expanded from... aclocal.m4:6542: AM_PROG_LIBTOOL is expanded from... configure.ac:157: the top level
../../lib/autoconf/lang.m4:194: AC_LANG_CONFTEST is expanded from... ../../lib/autoconf/general.m4:2662: _AC_LINK_IFELSE is expanded from... ../../lib/autoconf/general.m4:2679: AC_LINK_IFELSE is expanded from... aclocal.m4:369: _LT_AC_SYS_LIBPATH_AIX is expanded from... aclocal.m4:5554: AC_LIBTOOL_PROG_LD_SHLIBS is expanded from... aclocal.m4:4175: _LT_AC_LANG_GCJ_CONFIG is expanded from... aclocal.m4:4174: AC_LIBTOOL_LANG_GCJ_CONFIG is expanded from... aclocal.m4:1914: _LT_AC_TAGCONFIG is expanded from... aclocal.m4:86: AC_LIBTOOL_SETUP is expanded from... aclocal.m4:66: _AC_PROG_LIBTOOL is expanded from... aclocal.m4:31: AC_PROG_LIBTOOL is expanded from... aclocal.m4:6542: AM_PROG_LIBTOOL is expanded from... configure.ac:157: the top level
Useless use of /d modifier in transliteration operator at /usr/local/share/automake-1.9/Automake/Wrap.pm line 60. configure.ac:157: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/app/Makefile.am:117: `gtk-doc.make' included from here gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/libgimp/Makefile.am:64: `gtk-doc.make' included from here gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/libgimpbase/Makefile.am:52: `gtk-doc.make' included from here gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/libgimpcolor/Makefile.am:46: `gtk-doc.make' included from here gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/libgimpconfig/Makefile.am:57: `gtk-doc.make' included from here gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/libgimpmath/Makefile.am:46: `gtk-doc.make' included from here gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/libgimpmodule/Makefile.am:53: `gtk-doc.make' included from here gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/libgimpthumb/Makefile.am:54: `gtk-doc.make' included from here gtk-doc.make:7: GTK_DOC_USE_LIBTOOL does not appear in AM_CONDITIONAL devel-docs/libgimpwidgets/Makefile.am:66: `gtk-doc.make' included from here
2011-01-09 23:04:21 UTC (over 14 years ago)
'export ACLOCAL_FLAGS=-I\ /usr/share/aclocal'
before running the './autogen.sh --prefix=/usr', solves the problem.
2011-01-09 23:29:13 UTC (over 14 years ago)
actually no, it only allows the autogen to complete successfully, silliness like:
for help.
still happens.
Haven't found a solution, yet.
Liam R E Quin
2011-01-10 00:14:30 UTC (over 14 years ago)
http://openmoko-public-mailinglists.1958.n2.nabble.com/quot-X-tag-CC-command-not-found-quot-td1577166.html suggests, [[
It turns out that this
happens if the directory containing the sources already has files generated by previous build processes. ]]
and also a possible libtool version mismatch.
THey were on ubuntu, if you're on OSX it might be unrelated.
Liam
2011-01-10 03:04:09 UTC (over 14 years ago)
Thanks for that tip Liam, I've tried 'make clean;./autogen.sh --prefix=/usr', it seems to make no difference, so I will look into libtool..
(I'm running Arch Linux, FWIW)
libtool 2.4 is installed (since a few months ago). Gimp reports 1.5.26 (?) I'm trying 2.2.10 now... running 'make clean;git clean -xf;./autogen.sh --prefix=/usr'..
no, same problem as before.. I'll try reinstalling 1.5.26
2011-01-10 07:40:56 UTC (over 14 years ago)
I've just tried compiling BABL, with similar results.
compiling GLib says, point blank,
You must have libtool >= 2.2 installed to compile GLib. Install the appropriate package for your distribution, or get the source tarball at http://ftp.gnu.org/gnu/libtool/
so, it looks like recent Arch Linux libtool setup is somehow FUBARed (In a way I can't fix by recompiling+installing the official source over the top.)
2011-01-12 01:14:34 UTC (over 14 years ago)
Conclusion:
The issue was, I had somehow managed to install a copy of the various autotools in /usr/local/
and they were being used instead of the ones in /usr/.
My solution was simply to delete those binaries. GIMP is now happily compiling :)
