Question regarding ToolInfo and Gimp Context
Question regarding ToolInfo and Gimp Context Filip Krynicki 04 Jan 21:48
Filip Krynicki
2011-01-04 21:48:10 UTC (almost 15 years ago)
I took a stab at explaining what I'm doing in the IRC channel, but I think I did a poor job, so here goes nothing. In short, I am working with a University lab in making an adaptation of Gimp. While most of our code does not interact with Gimp directly, we do make need to activate tools/actions at particular times.
Currently I am running into a problem. We use GimpContext.set_tool(ToolInfo) to set the currently active tool. In our interface this is always called by a button in the toolbox. While this works for most tools and actions, some specific tools have issues. For example, trying to active Hue/Saturation from the toolbox requires that an image be selected before the Hue/Saturation window appears. My understanding is that this is because the tool is set for that window's context, and does not actually execute until the window has focus again (though I could be completely wrong on this).
I was hoping someone here with an understanding of the tools architecture could explain to me whether or not I am right, and whether or not the approach I am considering - determining the last active window and giving it focus before activating tools - is in spirit with the existing engine, or if there is a better solution. The stroke selection tool does not seem to have the same limitation as the Hue/Saturation tool, which leads me to believe there may be a better option.
Thanks.
