Dialogs
Dialogs Ignacio 25 Dec 16:53
  Dialogs Ulf-D. Ehlert 26 Dec 11:34
Ignacio
2010-12-25 16:53:21 UTC (over 14 years ago)
Dialogs
Hello
I found this:
dialogs.pot: ID 76
from the Tab menu in any dockable dialog by clicking on and selecting Add TabSample
Points.
that come from this path: src/dialogs/sample-points.xml:50
and selecting
Add Tab
Sample Points
The same in these others: src/dialogs/pointer-dialog.xml:58 -> dialogs.pot: ID 132 src/dialogs/navigation-dialog.xml:56 -> dialogs.pot: ID 418
Salutos and Feliz Navidad Ignacio
Ulf-D. Ehlert
2010-12-26 11:34:15 UTC (over 14 years ago)
Dialogs
Ignacio (Saturday, 25. December 2010)
Hello
I found this:
dialogs.pot: ID 76
TabSample
Points.
and selecting
Add Tab
Sample Points
That's ok. Placeholder tags are a xml2po feature. Just translate the string as usual and make sure that you place the (verbatim) placeholder tag at its proper position.
We are using a patched version of xml2po, where some placheholder tags (especially those representing text inside of text) are removed, which hopefully simplifies translating po files. But in this case the placeholder *is* useful IMHO, because it makes the msgid smaller and easier to read and translate -- the placholder represents no translatable text. (It should better be named"", though.)
Ulf
Prediger absoluter Wahrheiten sind immer absolute Lügner.
		-- Karlheinz Deschner
