Healing Tool with Sample Merge
Healing Tool with Sample Merge Mathias Lindner 06 Dec 08:36
Mathias Lindner
2010-12-06 08:36:58 UTC (over 14 years ago)
we recently had a discussion about the healing tool and how much the sample merge option makes sense...
The perfect workflow for healing (and cloning as well) would be to work on a transparent layer. This would reduce the file size and keep the non-healed areas untouched (almost non-destructive editing).
As far as we understood the sample merge option is used for such cases. Checking the box the source of healing and cloning is taken from the visible stuff, not only from the active layer. But if you want to heal by "painting" on a transparent layer it doesn't work because is has no basic information that the heal tool needs. Now the question is: couldn't the "interpolation" code of this tool use the visible stuff as well? What sense does it make to take the source from visible but to not calculate the result based on all visible?
Or, if there are cases, might is make sense to add another checkbox to the tool options of the healing tool - so to say a 'sample merge' for the interpolation process? Call the first one 'Source Sample Merge', the second one 'Surrounding Sample Merge' (or whatever). Then, choosing both options would allow to heal on a transparent layer. Deselecting both options would allow to work regularly.
The whole discussion we had can be read here: http://forum.meetthegimp.org/index.php/topic,1193.0.html
Thanks for your opinions! Mathias
