setting up for docbook etc
setting up for docbook etc Ulf-D. Ehlert 24 Nov 19:36
  setting up for docbook etc David 10 Dec 22:15
   setting up for docbook etc Ulf-D. Ehlert 15 Dec 20:14
    setting up for docbook etc David 16 Dec 00:24
Ulf-D. Ehlert
2010-11-24 19:36:13 UTC (almost 15 years ago)
David King (Wednesday, 24. November 2010)
It appears that xsltproc is already installed in my Ubuntu. So, I now want to generate the English html files for myself to make sure I can - what do I type on the command line?
There are two ways to work/start:
1) The standard way is using autotools (automake, autoconf, etc.); you should start with
$ ./autogen.sh ALL_LINGUAS=en
which does some checks and runs automake, autoconf and configure. If everything is ok you will then have a Makefile and can do everything using the "make" command, e.g. $ make help
$ make html-en
$ make html # only if you cofigured with 'ALL_LINGUAS=en' # otherwise all html's are built $ make validate-en # is it still valid DocBook?
2) IMHO the autotools are a) bloated and b) overkill for our project, so I created a Makefile that should "just work"; all you have to do is to type
$ make -f Makefile.GNU ... LINGUAS=en or
$ make -f Makefile.GNU ... # for targets ending with '-en' instead of "make ...".
If some required program is not installed, this "make" will just fail...
If you add "VERBOSE=2" to your 'make' command you will see which commands are executed by 'make'.
Then, if that works, I *think* I need to create a branch so that I can safely work on the re-structure. What do I type on the command line?
Most important command:
$ git help branch
Creating a new branch is not really necessary, but it's a clean way, especially for major changes, and it's cheap (and easy): $ git branch name_of_your_new_branch You'll have to checkout ("git help checkout") that new brach, that is to "change to this new branch":
$ git checkout name_of_your_new_branch You can also combine both steps:
$ git checkout -b name_of_your_new_branch
By the way, did it occur to anyone that having a help system that needs a programmer to change it rather limits the people who will help to... programmers - whereas what you really need to write help is authors ;). There's a huge barrier - still in front of me - before I can even begin to edit. I don't need to understand the inner workings - sure with enough effort I could, but what a waste of my time!
We used to have an INSTALL file, but it seems that it's gone. :-(
Bye Ulf
PS: Do you see the contradiction:
Ah, right, I can give you some examples... ;) [...]
vs.
... having a help system that needs a programmer ...
Beten heißt den Himmel melken wollen.
		-- Karlheinz Deschner
David
2010-12-10 22:15:36 UTC (almost 15 years ago)
Hello Ulf
I'm afraid neither approach "just works" (both complain cryptically). Over the past couple of weeks I've not been able to justify spending more time on the technology, when what I want to do is help with the documentation - and it looks as if it will stay that way for the foreseeable future. I'm no less busy than anyone else here ;).
So regretably my ability to contribute is on hold. I am finding GIMP a very useful tool though.
Thanks for your help.
David
Ulf-D. Ehlert
2010-12-15 20:14:22 UTC (almost 15 years ago)
David (Friday, 10. December 2010)
Hmm, both worked for me. Using Makefile.GNU complains about missing dep files (xml/*/.deps.mk), but you can ignore these messages.
Which error messages did you get?
Welcome to the club. ;-)
Bye, Ulf
Die Heiligenlegenden entlarvte Luther als Märchen. An den Bibellegenden
hielt er fest; am Teufelsglauben auch; am Hexenwahn auch; an der
Ketzervertilgung auch; am Antisemitismus auch; am Kriegsdienst, an der
Leibeigenschaft, den Fürsten. Man nennt es: Reformation.
David
2010-12-16 00:24:24 UTC (almost 15 years ago)
Hi Ulf
Can't remember exactly. One was from xslt, moaning it couldn't find something. To solve it, I'd have to dig into the technology, and I just can't justify the time to do that at the moment.
D
