distributing gimp with another program
19 of 19 messages available
distributing gimp with another program ash oakenfold 21 Nov 07:48
  distributing gimp with another program Daniel Hornung 21 Nov 10:34
   distributing gimp with another program Graeme Gill 21 Nov 13:03
    distributing gimp with another program Ofnuts 21 Nov 13:28
     distributing gimp with another program Graeme Gill 21 Nov 21:29
    distributing gimp with another program Christopher Curtis 21 Nov 14:27
     distributing gimp with another program Christopher Curtis 21 Nov 15:02
     distributing gimp with another program Graeme Gill 21 Nov 21:26
      distributing gimp with another program Christopher Curtis 21 Nov 21:49
       distributing gimp with another program Graeme Gill 21 Nov 22:12
        distributing gimp with another program Christopher Curtis 22 Nov 00:42
         distributing gimp with another program ash oakenfold 22 Nov 04:27
          distributing gimp with another program Christopher Curtis 22 Nov 05:32
         GIMP & GNU GPLv3/LGPLv3 in general (was: Re: distributing gimp with another program) Michael Schumacher 22 Nov 10:04
          GIMP & GNU GPLv3/LGPLv3 in general (was: Re: distributing gimp with another program) Joao S. O. Bueno 22 Nov 10:45
          GIMP & GNU GPLv3/LGPLv3 in general gg@catking.net 22 Nov 10:57
          GIMP & GNU GPLv3/LGPLv3 in general (was: Re: distributing gimp with another program) saulgoode@flashingtwelve.brickfilms.com 22 Nov 17:39
  distributing gimp with another program saulgoode@flashingtwelve.brickfilms.com 21 Nov 18:06
distributing gimp with another program gg@catking.net 21 Nov 23:54
ash oakenfold
2010-11-21 07:48:47 UTC (about 15 years ago)
Hi all,
I'm using gimp for some image post-processing (via script-fu and the command line) and I'd like to include it in the distribution of my Flash application.
I read the GPL and it says:
*"Activities other than copying, distribution and modification are not **covered by this License; they are outside its scope.**"*
And on wikipedia it says:
*"The mere act of communicating with other programs does not, by itself, require all software to be GPL; nor does distributing GPL software with non-GPL software."*
So, just to be clear, can I distribute gimp and use it to make a batch call from my program? Or does this violate the GPL?
Daniel Hornung
2010-11-21 10:34:27 UTC (about 15 years ago)
On Sunday 21 November 2010 08:48:47 ash oakenfold wrote:
Hi all,
Hi Ash,
I am not a lawyer but I think that distributing GIMP along with other non-free programs should be ok if those other programs just use it through the command line. Of course you will still have to distribute GIMP under the GPL, which means that you will have to inform the recipients about the license and their right, and you will have to make sure (as stated in the GPL) that they can get the source code in an appropriate way.
HTH, Daniel
Graeme Gill
2010-11-21 13:03:00 UTC (about 15 years ago)
Hmm. What's the command line got to do with it ? If a distribution ("package") has functionality that depends on GPL code, then that package is derived from GPL code, so must meet the GPL licensing conditions. The mechanism is irrelevant, the dependence is what counts. A non-GPL program that invokes a GPL program via any mechanism sounds a lot like is has some dependence on the GPL code. If there is functional dependence, then the "mere aggregation on the same media" escape clause wouldn't seem to apply.
Graeme Gill.
2010-11-21 13:28:52 UTC (about 15 years ago)
Then everything written for Linux would have to be GPL because it has functional dependence on GPL code?
Christopher Curtis
2010-11-21 14:27:51 UTC (about 15 years ago)
Christopher Curtis
2010-11-21 15:02:19 UTC (about 15 years ago)
Let me try to clarify one thing:
On Sun, Nov 21, 2010 at 9:27 AM, Christopher Curtis wrote:
terms of the GPL.
2010-11-21 18:06:29 UTC (about 15 years ago)
Quoting ash oakenfold :
The provisions of the explicit exemption stated in the LICENSE file[1] strongly suggest that your use case would not violate the terms of GIMP's licensing. If interfacing through either libgimp or the Script-fu server mechanisms doesn't mandate GPL licensing of your code, then why should command line invocation of that same functionality demand it?
I would offer the following recommendations to further ensure compliance:
* Your program should still work -- and provide significant functionality -- even if GIMP is not available.
* The GIMP supplied by you needs to be provided separately from your software. Specifically, the recipient needs to be able to use, make, and share copies of GIMP even though they may not be permitted to do so with your software (do not supply GIMP plus your software within the same ZIP file or tarball).
* The GIMP supplied by you needs to be fully functional as a standalone application.
* Ideally, provide an _unmodified_ version of GIMP. If you do make modifications to the GIMP you provide, your modifications should not be exclusively useful to your project (please consider submitting your improvements upstream).
* The user needs to be able to substitute their own version of GIMP for the one provided by you. If you are providing a modified version of GIMP, your program's use of GIMP must not rely upon the modifications you've made.
* You must, of course, satisfy all distribution terms required by the GPL for the GIMP software you are providing. It is important that you ensure the source code is available upon request, and that recipients are apprised of this availability.
Finally, keep in mind that this advice (in addition to bearing no legal authority) is not necessarily applicable to other GPLed projects. GIMP's explicit exemption provision would be considered by many people to be an exception to the normal interpretation of the GPL's scope, not merely a clarification of an amibiguity. The GIMP project is within their rights to provide such an exception, but one should not conclude that other GPLed projects offer the same type of exception.
[1] http://git.gnome.org/browse/gimp/tree/LICENSE
Graeme Gill
2010-11-21 21:26:30 UTC (about 15 years ago)
The command line delineates program boundaries. If your application makes a call to another program, then your application and the application being called are separate entities. As they are separate entities, one is not derived from the other.
And I didn't say that one was derived from the other. Go back and re-read what I said.
It is dependent on it, yes, but dependence is not derivation.
The distribution/package that contains the GPL code is (by default) derived from it. The package contains it, so the package is derived from it.
If the program dynamically links plug-ins, but the communication between them is limited to invoking the
Graeme Gill
2010-11-21 21:29:12 UTC (about 15 years ago)
IMI, only if it is shipped as a package, and doesn't fall into the Linux exception clause. (The Linux exception clause draws a line between kernel and user processes.)
Graeme Gill.
Christopher Curtis
2010-11-21 21:49:59 UTC (about 15 years ago)
Graeme Gill
2010-11-21 22:12:04 UTC (about 15 years ago)
[...] (and the non
GPL code having functionality that is dependent on GPL code seems a pretty strong hint I think, that this is not mere aggregation),
The GNU project is very explicit that your interpretation does not match theirs:
http://www.gnu.org/licenses/gpl-faq.html#MereAggregation
I think it does reasonably well, and the passage you quote is deliberately evasive about technical details. I think all the talk about the technical mechanisms is irrelevant. What counts is dependence. If I take your package and remove the GPL code, does the package still perform the primary function that is claimed for it ? If the answer is no, then the package is (IMO) clearly derived from the GPL code, and therefore must meet the GPL licensing conditions. (This is ignoring GPL code with extra exception clauses, like Linux etc.)
Graeme Gill.
gg@catking.net
2010-11-21 23:54:08 UTC (about 15 years ago)
I don't see where you get this part from. Anyone is free to make any modifications as long as they release them under a compatible licence and provide full source code etc.
If their other code works with the modified gimp in a GPL way where do you see the requirement to make if function with some / any other version of gimp that may be available previously , now or in the future. This does not seem to make sense.
This would be equivalent of saying no one (including the gimp project) could make a script that only worked with recent gimp features.
I'm not aware that GPL gives the project special rights to modify the source above the rights of anyone else.
Please clarify if I've missed something.
/gg/
Christopher Curtis
2010-11-22 00:42:18 UTC (about 15 years ago)
On Sun, Nov 21, 2010 at 5:12 PM, Graeme Gill wrote:
What counts
is dependence.
I think all of your arguments are wrong, but on this point you may be right. I didn't realize that the GIMP is GPLv3 now, which is a very different license. GPLv3 is very fuzzy about linking. The appropriate FAQ then is this:
----- The difference between this [communicating at arm's length] and
ash oakenfold
2010-11-22 04:27:57 UTC (about 15 years ago)
Thx for all the feedback!
My application can function without gimp. I only use gimp to stitch together and save a larger image as an optional last step. I think I'll drop gimp and handle it myself, so I can have a single package for distribution - in addition to open sourcing the whole thing.
Once again, thx for all the feedback, and if anyone is interested, here are some screenshots from my drawing app: http://www.conceptualinertia.net/aoakenfo/flash-drawing
Cheers, Ash
What counts
is dependence.
----- The difference between this [communicating at arm's length] and “incorporating” the GPL-covered software is partly a matter of substance and partly form. The substantive part is this: if the two programs are combined so that they become effectively two parts of one program, then you can't treat them as two separate programs. So the GPL has to cover the whole thing.
Section 5 of the GPLv3 states only:
----- A compilation of a covered work with other separate and independent works, which are not by their nature extensions of the covered work, and which are not combined with it such as to form a larger program, in or on a volume of a storage or distribution medium, is called an “aggregate” [...]
So our legal situation appears to be "not an extension of the work and not combined to make a larger program" -- the significance of this being under 'Section 5: Modified Source' instead of 'Section 4: Verbatim Copies' is not entirely clear to me.
However, the GIMP LICENSE file states:
--- * If you create a program which invokes (or provides) methods within (or for) the GPL GIMP application core through the medium of libgimp or another implementation of the 'procedural database' (pdb) serial protocol, then the GIMP developers' position is that this is a 'mere aggregation' of the program invoking the method and the program implementing the method as per section 2 of the GNU General Public License.
This does not talk about running the GIMP from the command line specifically but does state that you can call into the GIMP core via libgimp or any other PDB interface and that is considered by the GIMP team as a 'mere aggregation'. Whether the command line is considered an 'implementation of the PDB' is not explicitly stated.
*** (Sven, Mitch) ***
This LICENSE text should probably be updated as 'Section 2' of GPLv3 doesn't talk about aggregations - it's been moved into section 5. It might also be useful to address this issue directly as the GPLv2 is generally well understood to allow command line usage as an 'aggregation', but GPLv3 seems to muddy this distinction.
NAL, Chris
Christopher Curtis
2010-11-22 05:32:55 UTC (about 15 years ago)
If your needs really are this simple, ImageMagick is a pretty powerful tool released under a BSD-like license that may suit your needs.
You may also want to consider using GEGL for your application. There is a plan afoot to use GEGL as the backend for GIMP compositing, and I'm sure everyone would appreciate as much 'real-world' testing of this library as possible - assuming flash allows that level of integration.
Chris
2010-11-22 10:04:31 UTC (about 15 years ago)
Von: Christopher Curtis
At the moment I'm not even sure if GIMP should be licensed under GPLv3 without a much better understanding of the license. For example, the fact that it is now impossible to use GPLv2-only libraries in plug-in wasn't considered at all. It's not such much the fact that we can't use them anymore, rather the problem of no one even thinking about it when we changed the license version to v3.
I have contacted the Freedom Task Force of the FSF in order to get help, and they requested more details. Unfortunately my spare time (or the lack thereof) didn't allow me to write a reply yet.
I'd be glad to learn about any additional side-effects of a GPLv3-licensed GIMP (note that libgimp* is licensed under LGPLv3) that may surprise us - but please base them on actual FSF information and not mere speculation.
Regards, Michael
Joao S. O. Bueno
2010-11-22 10:45:03 UTC (about 15 years ago)
Since a long time ago, we had an exception of the license for plug-ins in a sense that GIMP plug-ins can be non GPL. If you as much as take a look at the LICENSE file provided in the tree, it is at the second and third paragraphs.
Therefore, there should be no problem in suiong GPLv2 or any other license for libraries linking to plug-ins.
js ->
Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief! Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail _______________________________________________ Gimp-developer mailing list
gg@catking.net
2010-11-22 10:57:04 UTC (about 15 years ago)
Regards, Michael
I did suggest caution when the licence upgrade issue was raised originally. It seems a bit late to start considering whether it has any "side-effects" now. Maybe someone should have read it.
/gg
2010-11-22 17:39:29 UTC (about 15 years ago)
Quoting Michael Schumacher :
If a plug-in were to link to a GPLv2-only library, that plug-in (having to be licensed as GPLv2-only) would not have been acceptable for incorporation into the GIMP project. To my understanding, it has always been (at least since GIMP 0.56) required that code contributed to GIMP be licensed in a manner compatible with "GPLv2 (or later)" licensing terms. If GIMP had included GPLv2-only code then GIMP would no longer have been distributable under "GPLv2 (or later)" terms.
At the time the licensing change to GPLv3 was originally proposed, I spent a couple of hours inspecting the GIMP source for any instances of GPLv2-only licensing and could not find any. As one should expect, all GPLed code in GIMP offered the option to use a later version. If any such code were present, or if GIMP had any GPLv2-only dependencies, there would have already existed a licensing conflict with GIMP's "GPLv2 (or later)" licensing, independent any consideration of GPLv3.
Since GPLv2-only plug-ins have never been an option for inclusion in the GIMP project -- and since third-party plug-ins are permitted to be licensed under GPLv2-only terms (and thus link with GPLv2-only libraries) -- I do not see that GIMP switching to GPLv3 poses any new problems in this regard.
