[PATCH] Fix for memory and file descriptor leaks
[PATCH] Fix for memory and file descriptor leaks Nelson A. de Oliveira 09 Nov 18:20
  [PATCH] Fix for memory and file descriptor leaks Sven Neumann 12 Nov 20:58
2010-11-09 18:20:12 UTC (about 15 years ago)
Hi!
Can somebody review two patches that (hopefully) fix some memory and file descriptor leaks, please?
The first one is basically g_free()s and fclose()s: http://people.debian.org/~naoliv/misc/gimp/patches/0001-Fix-memory-and-descriptor-leaks.patch
For the second one, instead including a fclose(fp) for every block with a "return FALSE;" in it I just moved it below (since it was not being used before).
http://people.debian.org/~naoliv/misc/gimp/patches/0002-Move-file-opening-block-to-after-some-tests.patch
Is there something wrong with them, please?
Thank you!
Best regards, Nelson
2010-11-12 20:58:00 UTC (about 15 years ago)
I have pushed both patches to master. Thanks for your contribution.
