where is this string in practice (from quick-mask-commands.c)
where is this string in practice (from quick-mask-commands.c) Cristian Secară 25 Oct 16:03
  where is this string in practice (from quick-mask-commands.c) Alexandre Prokoudine 25 Oct 16:37
  where is this string in practice (from quick-mask-commands.c) Sven Neumann 25 Oct 16:57
Cristian Secară
2010-10-25 16:03:17 UTC (over 14 years ago)
I like to know where (or how) can I see this string in practice:
#: ../app/actions/quick-mask-commands.c:105 msgid "Quick Mask Attributes"
#: ../app/actions/quick-mask-commands.c:108 msgid "Edit Quick Mask Attributes"
#: ../app/actions/quick-mask-commands.c:110 msgid "Edit Quick Mask Color"
#: ../app/actions/quick-mask-commands.c:111 msgid "_Mask opacity:"
Thank you, Cristi
2010-10-25 16:37:46 UTC (over 14 years ago)
1. Open an image
2. Use Shift+Q to create Quick mask
3. Go to Channels dialog
4. Right-click on "QUick mask" channel 5. Choose topmost menu item
2010-10-25 16:57:25 UTC (over 14 years ago)
There's a button in the lower left of the image window between the ruler and the scroll-bar. It has a right-click menu that allows to open a dialog to configure the Quick Mask attributes. I believe that's where these strings are being used.
