LAB in Info Window
10 of 10 messages available
LAB in Info Window jacekpoplawski@gmail.com 21 Oct 19:10
  LAB in Info Window enselic@gmail.com 21 Oct 19:26
   LAB in Info Window sven@gimp.org 21 Oct 21:03
    LAB in Info Window pippin@gimp.org 21 Oct 22:37
LAB in Info Window sven@gimp.org 21 Oct 21:30
  LAB in Info Window enselic@gmail.com 21 Oct 21:56
  LAB in Info Window graeme2@argyllcms.com 22 Oct 00:15
   LAB in Info Window jcupitt@gmail.com 22 Oct 08:03
    LAB in Info Window alexandre.prokoudine@gmail.com 22 Oct 19:27
   LAB in Info Window sven@gimp.org 23 Oct 10:59
2010-10-21 19:10:59 UTC (over 14 years ago)
LAB in Info Window
Few days ago I asked about LAB/CMYK plans in Gimp, I am not sure what's the current status is, so maybe I will try another question.
In Gimp one can use "Color Picker Tool", set "use info window" and will see "Color Picker information" with color values. There are 4 types of colorspace to choose: 1) Pixel
2) RGB
3) HSV
4) CMYK
I want to add LAB version, and after that, I want to fix (or just add new) CMYK version - cyan is almost always 0% now.
It doesn't look very complicated, there is already gimp_rgb_to_cmyk and gimp_rgb_to_hsv and inside decompose.c there is full code of gimp_rgb_to_lab, just not placed in separate function. Then I will need to add it to gimpcolorframe.c and it should work :)
The question is - can I do it? Can I submit a patch somewhere and it could be commited into development branch?
PS. I use gimp-git
enselic@gmail.com
2010-10-21 19:26:39 UTC (over 14 years ago)
LAB in Info Window
Of course you can!
I suggest you create a patch and attach it to a new bug report filed at bugs.gimp.org. Don't forget to take the active color profile into account.
Regards, Martin
sven@gimp.org
2010-10-21 21:03:20 UTC (over 14 years ago)
LAB in Info Window
Of course you can!
You can't really take the active color profile into account unless we decide to add a dependency on littlecms to the core. The whole color management system would basically need to be rewritten. This has the potential to allow some important improvements all over the place. But we really need someone willing and capable to finish this work if we want to open this can of worms.
sven@gimp.org
2010-10-21 21:30:04 UTC (over 14 years ago)
LAB in Info Window
The experiment doesn't need to take place in git master though, we can create an experimental branch if we get a set of interesting patches. So it doesn't matter if it gets finished or not, we either abandon or merge that experimental branch depending on the outcome.
If someone starts experimenting with this, I suggest making littlecms one of potentially backends, so that we can compile against the native color management library of a platform when available.
That is what the current color management infrastructure does. So far no one has ever expressed any interest in implementing a native backend though. So I guess we better abandon that idea and just use lcms for all platforms. Would be a lot easier if lcms could be used in the core and if we wouldn't have to create some sort of abstraction layer that fits all color management backends.
But then we might run into trouble when cairo gets color management capabilities. Currently display color management is totally broken in trunk, so we need to find a way out of this anway...
enselic@gmail.com
2010-10-21 21:56:35 UTC (over 14 years ago)
LAB in Info Window
I guess you're right. It won't be hard to retrofit an abstraction on top of littlecms if the need arises anyway.
/ Martin
pippin@gimp.org
2010-10-21 22:37:48 UTC (over 14 years ago)
LAB in Info Window
Of course you can!
Shedding some light on this can of worms from my perspective babl and GEGL perspective:
I think the best thing for now is to not take the color profile into account, and make that assumption that GIMP is working on sRGB data...
The responsibility for color management in GEGL is distributed among the operations. Raster Buffers passed around are tagged with a BablFormat describing the pixel format (color space, bit depth and component permutations).
When files with ICC profiles are loaded they should either be converted upon load to a predefined BablFormat, or a BablFormat depending on lcms should be dynamically constructed referencing the ICC profile.
Operations are performed in whatever is their preferred working space, some natural spaces here are RGBA float, RaGaBaA float, CIE Lab float and Y float. The meaning of these formats is well defined thus the behaviour of operations will be predictable and fully color managed.
The "active profile" is the final transformation to be applied to the color data after it leaves GEGL/gets saved (within GEGL data is most likely mostly stored as RaGaBaA float). User interface elements showing color triplets or quadruplets like the color picker would use babl to transform single pixels of data to and from CIE Lab, R'G'B'A u8 and similar. When using an output target profile lcms should either be used directly or indirectly through babl. The profile of your display as well as soft proofing and rendering intents is not
relevant for these bits.
2010-10-22 00:15:19 UTC (over 14 years ago)
LAB in Info Window
This is unlikely. For one thing, what is cairo likely to use ? - lcms. For another, you don't have to use other underlying CMM's, as long as the underlying device colorspaces are exposed. It can help to have access to system configuration information (ie. an association between devices and their color profiles), and for this some platform independent wrapper is desirable, but in the first instance you can ignore all of that and have the user select the profiles manually. Retrieving the display profiles automatically would be nice though, and there is code around to do this on various platforms (I've certainly written some under GPL for MSWin, OS X and Linux).
Graeme Gill.
jcupitt@gmail.com
2010-10-22 08:03:47 UTC (over 14 years ago)
LAB in Info Window
The native CMS is often horribly unreliable and incomplete. The one that ships with XP, for example, is almost unusable. I think this component has been replaced now, but the new version is still missing support for more recent profiles (hope I have that right). Gimp would need to make at least three Windows binaries: LCMs, XP and Vista+. They'd produce subtly different results in hard to explain ways.
Photoshop gets around this by having it's own cms and using that on all platforms. This helps make save files work between platforms too. I think it would be quite reasonable for GIMP to do the same.
John
2010-10-22 19:27:36 UTC (over 14 years ago)
LAB in Info Window
What would be the point of that, when one could implement abstraction layer for pluggable CMMs and LittleCMS as default CMM? It's what Scribus team was working on last summer.
sven@gimp.org
2010-10-23 10:59:27 UTC (over 14 years ago)
LAB in Info Window
Code for retrieving the display color profile from the operating system is already in place in GIMP for X11 and Mac OS.
