Detecting "closure" of selection
Detecting "closure" of selection Ofnuts 09 Oct 21:17
  Detecting "closure" of selection Owen 09 Oct 21:24
  Detecting "closure" of selection David Gowers (kampu) 09 Oct 22:22
  Detecting "closure" of selection saulgoode@flashingtwelve.brickfilms.com 10 Oct 02:01
2010-10-09 21:17:03 UTC (over 14 years ago)
Assume I have a selection on small area (for instance a 20px circle), and I invert it. Now, if I grow the selection by a sufficient amount (10px in this case), everything gets selected.
Is there a practical, fast way, to detect this case, i.e, that the selection covers the whole layer (or image?) and that no pixels remain unselected? I assume that inverting the selection again and testing for empty would work, but that would be two selection inversions in the normal case and that may be a bit costly.
Owen
2010-10-09 21:24:46 UTC (over 14 years ago)
Select->all?
2010-10-09 22:22:07 UTC (over 14 years ago)
On Sun, Oct 10, 2010 at 7:47 AM, Ofnuts wrote:
?Assume I have a selection on small area (for instance a 20px circle), and I invert it. Now, if I grow the selection by a sufficient amount (10px in this case), everything gets selected.
Testing for empty and for full are the same operation (an empty sel is equivalent to a full one)
HTH
Gimp-developer mailing list
2010-10-10 02:01:14 UTC (over 14 years ago)
Quoting Ofnuts :
The following appears to be about twice as fast as the two inversion approach.
(let ((count (cdddr (gimp-histogram (car (gimp-image-get-selection image)) HISTOGRAM-VALUE 255 255)))) (= (car count) (cadr count)) ; compare num of all pixels to all white pixels )
