dirty tracks left by painting tools
dirty tracks left by painting tools Olivier 06 Oct 20:23
  dirty tracks left by painting tools Michael Natterer 06 Oct 21:07
  dirty tracks left by painting tools Martin Nordholts 07 Oct 17:39
Olivier
2010-10-06 20:23:10 UTC (over 14 years ago)
From one nightly tarball to another, the behavior change, in the sense that
the painting tools that leave a dirty track are not the same, and it depends on different brushes. Anyway, the problem has been there for several days, and it makes GIMP almost impossible to use.
Michael Natterer
2010-10-06 21:07:43 UTC (over 14 years ago)
That's simply work-in-progress which you agree to experience by using the development version ;)
It will be fixed.
--Mitch
Martin Nordholts
2010-10-07 17:39:43 UTC (over 14 years ago)
that the painting tools that leave a dirty track are not the same, and it depends on different brushes. Anyway, the problem has been there for several days, and it makes GIMP almost impossible to use.
I've created a bug report you can subscribe to to get a notification when it's fixed:
Bug 631619 - Drawing artifacts spread by paintbrush outline on canvas https://bugzilla.gnome.org/show_bug.cgi?id=631619
/ Martin
