X copy-paste in text tool
X copy-paste in text tool gg@catking.net 01 Oct 09:12
  X copy-paste in text tool Sven Neumann 02 Oct 00:17
   X copy-paste in text tool Xavier Araque A.|Rendergraf 02 Oct 14:15
    X copy-paste in text tool Xavier Araque A.|Rendergraf 02 Oct 14:18
gg@catking.net
2010-10-01 09:12:13 UTC (over 14 years ago)
noticed a defect in the text entry tool.
I was preparing a few lines of text on top of an image using the small edit window of the text tool. If I select a text segment with the mouse and do middle button to paste the text cursor does not move.
This may not be too important in itself but has knock on effects and other related issues since to move the cursor to the new location requires a second click , which in turn clears the buffer, losing the text I had selected.
X-window copy paste is so much more efficient than messing with context menus or dropping the mouse twice to use cntl-c cntl-v . This ought to be fairly easy to fix. So I'd like to dig into it.
I suspect this may be a bug inherited from gtk , if so can anyone point me in the right direction? Any other tips that may save some time getting into it?
thanks.
2010-10-02 00:17:58 UTC (over 14 years ago)
If you are using the "small edit window of the text tool", then I assume you are talking about the 2.6 text tool here, right? This edit window is a standard GtkTextView. So if there's misbehavior when pasting to this window, then please report this to GTK+.
2010-10-02 14:15:35 UTC (over 14 years ago)
Greetings to everyone.
I made this video with the intention of applying Vibrance Color in Gimp
I wonder if any of you could develop a tool for a new dialogue, along with brightness and contrast, curves, etc.
Video Gimp=> http://vimeo.com/15474981 Video Sample Photoshop => http://vimeo.com/7863255
Thanks
2010-10-02 14:18:18 UTC (over 14 years ago)
Sorry I'm wrong on topic, I will send a new one
:S
2010/10/2 Xavier Araque A.|Rendergraf :
Thanks
-- -Xavier-
La paciencia es una virtud, La constancia nos lleva al éxito - Patience is a Virtue, Perseverance leads to success.
Las cosas más importantes no son la mayoría de las cosas.
3D Character Development, Graphic Designer and Web Engineer
http://linuxtachira.org http://rendergraf.wordpress.com
Telf.: +58 416 1027262
Linux counter: 292510
