make fails after git pull
7 of 7 messages available
make fails after git pull Patrick Horgan 21 Sep 06:18
  make fails after git pull Danny Robson 21 Sep 07:18
   make fails after git pull Patrick Horgan 21 Sep 08:45
   make fails after git pull Patrick Horgan 21 Sep 08:46
   make fails after git pull Patrick Horgan 21 Sep 10:46
    make fails after git pull Sven Neumann 22 Sep 23:16
     make fails after git pull Patrick Horgan 23 Sep 01:48
Patrick Horgan
2010-09-21 06:18:08 UTC (about 15 years ago)
I'm using:
gcc (Ubuntu 4.4.3-4ubuntu5) 4.4.3
on:
Linux dell 2.6.32-24-generic #42-Ubuntu SMP Fri Aug 20 14:24:04 UTC 2010 i686 GNU/Linux
I was going to rebuild gimp from git and thought it would be smart to do a git pull in gegl and rebuild it first. After doing the git pull and a fresh successful configure, the make fails like this:
patrick@dell$ make make all-recursive
make[1]: Entering directory `/usr/local/geglbuild' Making all in gegl
make[2]: Entering directory `/usr/local/geglbuild/gegl' Making all in buffer
make[3]: Entering directory `/usr/local/geglbuild/gegl/buffer' CC gegl-tile-backend-tiledir.lo CC gegl-buffer.lo
CC gegl-buffer-access.lo
CC gegl-buffer-share.lo
CC gegl-buffer-iterator.lo
CC gegl-buffer-linear.lo
CC gegl-buffer-save.lo
CC gegl-buffer-load.lo
CC gegl-cache.lo
CC gegl-sampler.lo
CC gegl-sampler-cubic.lo
CC gegl-sampler-lanczos.lo
CC gegl-sampler-linear.lo
../../../gegl/gegl/buffer/gegl-sampler-linear.c:65: error: expected ‘;’, ‘,’ or ‘)’ before ‘self’
../../../gegl/gegl/buffer/gegl-sampler-linear.c: In function ‘gegl_sampler_linear_class_init’:
../../../gegl/gegl/buffer/gegl-sampler-linear.c:91: error: ‘gegl_sampler_linear_get’ undeclared (first use in this function) ../../../gegl/gegl/buffer/gegl-sampler-linear.c:91: error: (Each undeclared identifier is reported only once ../../../gegl/gegl/buffer/gegl-sampler-linear.c:91: error: for each function it appears in.)
../../../gegl/gegl/buffer/gegl-sampler-linear.c: At top level: ../../../gegl/gegl/buffer/gegl-sampler-linear.c:105: error: expected ‘;’, ‘,’ or ‘)’ before ‘self’
make[3]: *** [gegl-sampler-linear.lo] Error 1 make[3]: Leaving directory `/usr/local/geglbuild/gegl/buffer' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/usr/local/geglbuild/gegl' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/local/geglbuild' make: *** [all] Error 2
The line that fails first (gegl-sampler-linear.c:65 is: static void gegl_sampler_linear_get (GeglSampler* restrict self, const gdouble x, const gdouble y, void* restrict output); and it seems that gcc is not recognizing the restrict keyword. Does anyone have a clue of how I can resolve it?
Patrick
Danny Robson
2010-09-21 07:18:27 UTC (about 15 years ago)
configure should be defining an appropriate representation for restrict (through the use of AC_C_RESTRICT in configure.ac).
Can you confirm that config.h contains an appropriately generated define for restrict? Perhaps you need to rerun autogen.sh to rebuild configure?
- Danny
Patrick Horgan
2010-09-21 08:45:29 UTC (about 15 years ago)
You were right. It was not defined in config.h and running autogen.sh fixed the problem. Thank you, Danny.
Patrick
Patrick Horgan
2010-09-21 08:46:31 UTC (about 15 years ago)
You were right. It was not defined in config.h and running autogen.sh fixed the problem. Thank you Danny.
Patrick
Patrick Horgan
2010-09-21 10:46:36 UTC (about 15 years ago)
Well, running autogen.sh got me further, but I still have problems:
make[4]: Entering directory `/usr/local/geglbuild/docs/gallery' --[Updating sample compositions]--
../../../gegl/docs/gallery/clones.xml ** Message: Module '../../operations/external/.libs/ff-load.so' load error: ../../operations/external/.libs/ff-load.so: undefined symbol: avcodec_decode_video2
my libavcodec has an avcodec_decode_video, but no avcodec_decode_video2
(lt-gegl:15616): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'.
../../../gegl/docs/gallery/OpenRaster-00.xml ** Message: Module '../../operations/external/.libs/ff-load.so' load error: ../../operations/external/.libs/ff-load.so: undefined symbol: avcodec_decode_video2
(lt-gegl:15649): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'.
../../../gegl/docs/gallery/OpenRaster-01.xml ** Message: Module '../../operations/external/.libs/ff-load.so' load error: ../../operations/external/.libs/ff-load.so: undefined symbol: avcodec_decode_video2
(lt-gegl:15677): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'.
../../../gegl/docs/gallery/OpenRaster-04.xml ** Message: Module '../../operations/external/.libs/ff-load.so' load error: ../../operations/external/.libs/ff-load.so: undefined symbol: avcodec_decode_video2
(lt-gegl:15705): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'.
make[4]: Leaving directory `/usr/local/geglbuild/docs/gallery' make[3]: Leaving directory `/usr/local/geglbuild/docs/gallery' make[3]: Entering directory `/usr/local/geglbuild/docs' GEGL_SWAP=RAM GEGL_PATH=../operations \ ../tools/operation_reference --ops-html > operations.html ** Message: Module '../operations/external/.libs/ff-load.so' load error: ../operations/external/.libs/ff-load.so: undefined symbol: avcodec_decode_video2
(lt-operation_reference:15797): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'. make[3]: *** No rule to make target `../../gegl/gegl/gegl-version.h', needed by `api.html'. Stop.
make[3]: Leaving directory `/usr/local/geglbuild/docs' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/usr/local/geglbuild/docs' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/local/geglbuild' make: *** [all] Error 2
2010-09-22 23:16:34 UTC (about 15 years ago)
The ffmpeg library is (in)famous for changing their APIs frequently and releasing seldom. That's why pretty much every distribution ends up using development snapshots, which are incompatible to each other.
Your best bet is to configure gegl with the --without-libavformat option.
Patrick Horgan
2010-09-23 01:48:02 UTC (about 15 years ago)
Thanks, Sven. That got me past that one, but there still the complaint about two plugins trying to register the same thing:
(lt-gegl:6412): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'.
(lt-gegl:6445): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'.
(lt-gegl:6473): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'.
(lt-gegl:6501): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'.
(lt-operation_reference:6593): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglChantover_c'. make[3]: *** No rule to make target `../../gegl/gegl/gegl-version.h', needed by `api.html'. Stop.
And ideas on that?
Patrick
