Fwd: Drawing per Script
7 of 8 messages available
Drawing per Script oliver@first.in-berlin.de 12 Sep 13:58
  Drawing per Script Sven Neumann 13 Sep 20:15
AANLkTimEQFdgKHr3hpof_+-3=Q... 07 Oct 20:28
  Fwd: Drawing per Script Joao S. O. Bueno 13 Sep 22:21
   Fwd: Drawing per Script Simon Budig 14 Sep 01:54
   Fwd: Drawing per Script oliver@first.in-berlin.de 14 Sep 01:56
    Fwd: Drawing per Script David Gowers 14 Sep 04:02
    Fwd: Drawing per Script Joao S. O. Bueno 14 Sep 05:44
2010-09-12 13:58:48 UTC (over 14 years ago)
Drawing per Script
I tried drawing per Script. I'm using Python.
I can already use vectors for drawing circles, and set single points.
I did not found a way to create rectangles, or lines.
Aren't there pdb-functions that draw a line?
Do I have to create it pixelwise? In a loop?
When using the circle drawing with vectors I would expect that this technique can do it's work fast. But it's very slow (using a loop to set paths in those vectors). (In OpenGL for example there are Vertex Arrays that can be used to speed up drawing. Something like that in GIMP, and available for scripting would be nice.)
(I also saw, that what on the GUI are Paths internally are called vectors. To make things better undesrstandable, it would make sense to give things the same name... but maybe there is more to vectors and I don't see it so far. Why are there different names?)
How can I speed up my drawings without switching to C? With my Python script I need about 3 or 4 seconds just for drawing 2072 circles.
This seems very slow to me.
If I also would need to write pixels of a line pixel-wise, I would also await to have very slow scripts. Special functions for drawing lines from within Python-plugins, that use C-speed would be fine.
Gruß, Oliver
2010-09-13 20:15:29 UTC (over 14 years ago)
Drawing per Script
Probably the easiest method is to have your script generate SVG and use gimp_vectors_import_from_string(). You can of course also create vector strokes using the gimp_vectors_bezier_stroke method.
How do you draw your circles now?
Joao S. O. Bueno
2010-09-13 22:21:09 UTC (over 14 years ago)
On Sun, Sep 12, 2010 at 8:58 AM,   wrote:
Hi
I'm using Python.
You are probablu using pdb_gimp_vectors_bezier_stroke_new_ellipse to draw circles, right?
What does prevent you from using the calls for gimp_vectors_bezier_stroke_new_moveto and gimp_vectors_bezier_stroke_lineto to draw lines? (Don't  forget to alias then in your code to shorter names, last you have really undereadable stuff)
Still, creating a vectors object from stroking is one way of painting with scripts in GIMP (the recomended one to draw curves and circles, though) - for stragiht lines you can use pdb.gimp_paintbrush instead.
As I stated above, there are calls to draw lines. Are you even using the procedure browser? (Help menu - > Procedure browser) -
In Python you can access the image data directly, using calls to get the pixel regions if you want to as well (that is about 100x  faster than gimp_drawable_set_pixel  due to the function calls involved for each pixel change)
Sorry to tell you that - tehre is some slowdown in using the PDB, but this is more or less as fast as it gets using GIMP to draw yiu stroken circles. You probably coukd get some speed-u dealing straight with the image data if you don't need the stroking engines from GIMP - i.e. - no need to use different brushes, gradients, dynamics and so on) If so you can get some significant speed-up using C, or maybe even python if you get an efficient way to draw your circles using pixel data.
(A suggestion would be to cache different pixel data for the circles with the radii you want, as gimp-buffers, and paste then on the desred places on teh image - that shoul be much  faster than creating/stroking paths)
 will leave that up to Simon :-)
So, besides my hints above: when I need speed on a PDB using script (which includes python scripts),
I found out that GIMP's undo system is the cause for a significant slow down. Creating an Undo group does not help - you have to disbale the undo with pdb.gimp_image_undo_disable
This can give you a 3x to 4x times improvement when you have many small operations going on (like drawing thousands of circles) . Unfortunatelly this spoins the undo system for you rimage -even after a call to "undo_enable".
If you are editing the image interactvely I suggest you make your script to: - copy the drawable you are interested to a new image - disable the undo system on the new image - perform your painting operations
 - copy the drawable back to the original image (and destroy the newly created image, of course)
If you weant 1 pixel thick straight lines, use the pencil tool and the "pixel" brush.
 js
Gruß,
  Oliver
Simon Budig
2010-09-14 01:54:08 UTC (over 14 years ago)
There already is an internal API that uses the "gimp-path"-prefix and I wanted to avoid confusion. The new shiny "vectors" API should have its own namespace, to clearly separate it from the old pesky "gimp-path-*"-API :-)
Also, the vectors infrastructure was designed to allow future extensions that go beyond simple paths. The goal was to have a "vectors" object as a container for strokes (i.e. connected bezier segments) or circles/ellipses or contrast-following-segments. So it theoretically could contain other stuff as well, going beyond plain "paths".
That aspect has never been fleshed out, mostly due to UI-confusion-considerations.
Bye, Simon
2010-09-14 01:56:24 UTC (over 14 years ago)
Hi
I'm using Python.
I use:
pdb.gimp_vectors_bezier_stroke_new_ellipse
So I think it's what you are talking about, just the absolute name is different.
I looked for "draw" and did not find functions that do it. So, in short words: I did not found thos functions.
If it does not eat up too much ressources in Python...
...you mean using def for creating a function that just calls the other one? or are "alias"es what Python offers as a separate feature?
I use the procedure browser.
But it does not help me, if I look for names that aren't there.... ...if I look for "draw" I got nothing. The circle-drawing function via bezier I found by accident/chance.
How can I access the pixel data directly?
That would be very interesting to me, especially for some other scripts, where I think about even more intensive work.
OK, I will try that.
Thanks for all that hints. :)
Ciao, Oliver
David Gowers
2010-09-14 04:02:11 UTC (over 14 years ago)
Neither of the above.
Functions are values, in Python. Therefore
lineto = pdb.gimp_vectors_bezier_stroke_lineto
is all that you need, so that you can call lineto instead of calling pdb.gimp_vectors_bezier_stroke_lineto (and having to type all that out :)
Joao S. O. Bueno
2010-09-14 05:44:22 UTC (over 14 years ago)
Hi
I'm using Python.
I use:
Your way is the correct - mine was just a typo - a thing I excel in.
yes-- the procedure broswer has this downside -- you have to keep looking with related words if you don't find something at first.
It does not.
What is delaying the execution is much more the nature of the PDB and the Undo system than python.
With "aliasing" I mea just attributing the pdb functions to a local variable - with lines like these at the start of your function (or even at the start of your module):
lineto = pdb.gimp_vectors_bezier_stroke_new_lineto ellipse = pdb.gimp_vectors_bezier_stroke_new_ellipse
From then on you can jsut type "ellipse( ...) " instead of the long name designed to avoid namespace clash. This does not create new functions - you call the very same function, just using another name.
If you type "vectors" you will see all teh vector related functions. Howeer to paint straight without using a path, you have to look for the tool name:
"pencil", "paintbrush", etc...
px = drawable.get_pixel_rgn(top, left, width, height) px [:, :] = "\xff\x00\x00" * drawable.width * drawable.height() drawable.update(top, left, width, height)
The "get_pixel_region" and "update" are methods of GIMP drawable objects.
The item assignment to set/reset pixels is a bit aukward - the example above paints the whole drawable in red (if it is a 3BPP RGB channel, else you willget an
error telling the setting string is of the wrong size)
For serious work with pixel regions you might prefer to copy the pixel data to a Numpy array - ther eyou can work with numbers from 0 to 2545 instead of having to convert all data to string prior to setting the pixels.
Ciao,   Oliver
