behavior of Shift+digit
behavior of Shift+digit Olivier 12 Sep 11:13
Olivier
2010-09-12 11:13:25 UTC (over 14 years ago)
In the Image -> View menu, the Zoom sub-menu contains entries for 1:2, 1:4, 1:8, and 1:16 zooming factors. They are supposed to be associated with shortcuts Shift+2, Shift+3, Shift+4, and Shift+5.
With the current git version and Ubuntu 10.04, I get a different behavior:
- Shift+ a digit on the main keyboard does not have any effect.
- If the auxiliary keyboard is num unlocked, no effect at all, with or without Shift.
- If it is num locked, Shift+2 divides by two the current zooming factor, Shift+8 doubles it, Shift+3 sets the zooming factor to 1:8, and Shift+9 to 8:1. Other digits are inoperant, as well as all digits when they are typed without Shift.
If this is what is intended, it does not work as documented in the Zoom menu. At least the auxiliary keyboard should be mentioned. In the documentation, there is nothing about this.
