Dummy Layer with particular dynamic
Sorry but i don't understand if this possible new feature (adjustment layer) is interesting or not?
I would try to do an implementation, but if is useless or not interesting i will do other.
What do you think?
This is original message:
Message: 1
Date: Sat, 28 Aug 2010 02:05:47 +0200
Subject: [Gimp-developer] Dummy Layer with particular dynamic effect
To: gimp-developer@lists.XCF.Berkeley.EDU
Message-ID:
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
i think that would be very useful a dummy layer that can contains a particular
effect/operation like curves in order to change parameters in future without
any problems and eventually using a particular mask for handle particular zone
where i don't want this.
In this case is possible to activate or deactivate effects and change that
parameters dynamically without any duplicate image layers with static effects.
The problem may be in a user-defined plugins but for standard operation like levels or
curves there isn't or i'm missing somethings?
If i write an effect plugin would be perfect to associate that with this kind of dummy layer in order to change parameters/enable/disable/masking/unmasking that whenever i want.
Sorry for my english :),i'm not a mother language...
Jack
