(no subject) plus dockables
15 of 15 messages available
(no subject) oliver@first.in-berlin.de 26 Aug 19:50
  (no subject) plus dockables gg@catking.net 26 Aug 21:11
   (no subject) plus dockables Sven Neumann 26 Aug 21:19
    (no subject) plus dockables Martin Nordholts 27 Aug 07:25
     (no subject) plus dockables yahvuu 27 Aug 12:39
      (no subject) plus dockables gg@catking.net 27 Aug 13:23
      (no subject) plus dockables Martin Nordholts 28 Aug 07:08
       (no subject) plus dockables gg@catking.net 28 Aug 08:20
        (no subject) plus dockables Olivier 28 Aug 08:27
      (no subject) plus dockables Sven Neumann 28 Aug 20:17
     (no subject) plus dockables Sven Neumann 28 Aug 20:13
      (no subject) plus dockables yahvuu 01 Sep 12:45
       (no subject) plus dockables Martin Nordholts 09 Sep 08:59
   (no subject) plus dockables oliver@first.in-berlin.de 26 Aug 22:05
    (no subject) plus dockables Sven Neumann 26 Aug 22:17
2010-08-26 19:50:26 UTC (over 14 years ago)
(no subject)
Bcc:
Subject: Re: [Gimp-developer] scanner support should be File->Acquire Reply-To:
In-Reply-To:
On Thu, Aug 26, 2010 at 12:54:38PM -0400, Christopher Curtis wrote:
On Wed, Aug 25, 2010 at 2:55 PM, Sven Neumann wrote:
"somewhere else" is not a very intuitive place either. We've had a longer discussion when these items were moved to File->Create and no one came up with a better solution.
I find the 'Create' label non-obvious as well. It makes sense for the logo scripts, but I'd suggest considering:
The problem is, that file->create as well as file->new do not really create a file.
A file is created, when it's written to disk.
It's an image that is created.
And getting data from a scanner is importing data to make an image out of it, which maybe later will be saved to a file (or thrown away/deleted).
It's the "we are used to misnomed menues since decades" as a heritage of M$-Windows, which sucks again and again, and will not stop. So... no wonder those discussions will come up again and again.
The only creative GUI that I've ever seen is that of Blender.
You need time to learn it, because it's so different, but it's good.
There are other things in the Gimp-GUI that slows down the workflow, for example in layer menue and in image menue, transformation tools are at different vertical positions. So you always have to switch in mind, or look up it again and again, which is time consuming.
It would be a good idea, IMHO to have same functionality at same vertical position, so that it doesn't matter if you want to rotate your image or your layer: the transformation will always be at the same height in the menue.
To achieve same vertical position, for menue-fields that are not used one could add an empty field.
This at first might seem strange, because other programs don't do it that way. But after people will be used to it, it will make the work with Gimp easier and faster. (Learn from Blender!)
Ciao, Oliver
gg@catking.net
2010-08-26 21:11:25 UTC (over 14 years ago)
On 26/08/10 19:50, oliver@first.in-berlin.de wrote:
Bcc:
In-Reply-To:
Ciao, Oliver
I agree, I also find the file-create-screenshot *-scanner options rather forced and I have to do a double take to make sure it really says what I think it says and I have not misread something.
File - Create - Xsane: device dialog seems particularly contorted.
I don't really see the need for File - New to be on it's own. The amount of work that is done after this action makes one more selection irrelevant. File - New - Image would be fine.
File - New -Scan ; *-From clipboard ; *-screenshot would make more sense than the "create" paradigm.
File - Create - button , *-logo et al. seem more natural and are fine.
Since the subject here is "(no subject)" I will add a related comments on some similar oddities in the menu system
I want to comment on how hard/illogical it is to find the "layers dockable dialogue" without knowing what gimp calls it and knowing that "dockable dialogues" are found on the windows menu.
This is a recurrent problem that indicates that this is counter-intuitive for me. I go several times round the loop and sometimes just give up not having found what I know is there in the GUI - somewhere.
Some comments:
If I want to operate on layers , the most logical place to look is on the layers menu. No go.
Having done the tour , I may expect to find something about layers in Windows menu. Nope.
So now I'm reduced to scanning every submenu to see if I can spot something about layers that is not on the layers menu. As well as going minutely through the layers menu since I have presumably carelessly missed what MUST be there. Finally, I have to know it's called a dockable dialogue before I'm likely to find it
There are similar inconsistencies in several areas . The colour picker "dockable" is not on the Colours menu.
This would seem to be another case of organisation by programming implementation , not by USER work requirements.
These are all tucked out of the way , two layers down in the hierarchy because they are programmed as "dockables", not put where they need to be in terms of function.
If I want a colour , I should find it on the colour menu . If I want to select layers I should fine the necessary interface elements on the layer menu.
regards.
2010-08-26 21:19:45 UTC (over 14 years ago)
Sounds reasonable. We could duplicate the menu items from the Dockables menu that raise/create those dialogs in the places where they belong. So we would have "Layers dialog" in the "Image/Layers" menu and the like. That's as simple as editing the XML files in the menus sub-directory. Perhaps someone wants to come up with a patch...
2010-08-26 22:05:42 UTC (over 14 years ago)
On Thu, Aug 26, 2010 at 09:11:25PM +0200, gg@catking.net wrote: [...]
Sorry, I was too tried, it was "Re: [Gimp-developer] scanner support should be File->Acquire" before; I made a typo in editing... with mutt I can use my editor to directly change the mailheader - and also do some nasty stuff.
It should be in the same thread as "the "scanner support"-thread.
There are many things like that.
I'm not long enough on this list to know all the old discussions, but AFAIK Sven Neumann once (some years ago) was interviewed by the Cahos Radio, and mentioned there, that one person did a complete usability anylsis.
I don't know idf this work has already been finished and published.
Would be interesting to see at the recommendations. I mean: not necessarily adopt all such things (maybe thera ara also other concepts and ideas), but at least it could be something for a discussion.
Thanks for your comments on GUI inconsitencies.
Ciao, Oliver
2010-08-26 22:17:45 UTC (over 14 years ago)
On Thu, 2010-08-26 at 22:05 +0200, oliver@first.in-berlin.de wrote:
I'm not long enough on this list to know all the old discussions, but AFAIK Sven Neumann once (some years ago) was interviewed by the Chaos Radio, and mentioned there, that one person did a complete usability anylsis.
This is all documented at http://gui.gimp.org/ and for some years now we are changing the UI based on input from the GIMP UI team.
Martin Nordholts
2010-08-27 07:25:02 UTC (over 14 years ago)
I don't think we should duplicate any menu items. Having things in two places tends to cause unnecessary confusion. A user will have to answer questions like "Why is this menu item in two places? Is it the same menu item? Does it do the same thing? Which one should I use now?" Having just one place to do things avoids such ambiguity and mental friction.
If people have troubles finding the Layers dockable, we should instead look into making it more discoverable, like adding a 'Dockables' top menu or moving them directly under 'Windows' instead of having a sub menu.
/ Martin
yahvuu
2010-08-27 12:39:10 UTC (over 14 years ago)
What about naming it the 'Dialogs' menu?
-- 'Dockables' sounds like implementation slang to me. And the 'Windows' menu becomes confusing in single-window-mode.
Making the Layers dialog discoverable under the 'Layers' menu and color dialogs below the 'Colors' menu etc.. makes a lot of sense, but IMHO that's the job of a 3.0 redesign -- there is a whole lot more to do than just releasing the dockables from their current hiding place and distributing them over the menu structure. (E.g. what use is in displaying the brushes dockable while the gradient tool is active? etc..)
regards, yahvuu
gg@catking.net
2010-08-27 13:23:02 UTC (over 14 years ago)
Well dockable is a adjective so it begs the question: dockable what?
I agree this is implementation terminology that probably should not be on the GUI.
I find calling these dialogs to be part of the confusion (as well as being buried) . A dialogue suggest some kind of direct one-off interaction, like entering image scaling information and pressing OK, not a utility window I put on one side to be used from time to time.
Since they are indeed windows , I don't see much wrong with that term.
/gg
regards, yahvuu
Martin Nordholts
2010-08-28 07:08:40 UTC (over 14 years ago)
Yes 'Dialogs' is better than 'Dockables'. 'Dockable Dialogs' is even better except it's too long.
But won't that be a problem? Instead of having all dockable dialogs in a single place, a user would have to go hunt for the one he wants.
Regards, Martin
gg@catking.net
2010-08-28 08:20:17 UTC (over 14 years ago)
Regards, Martin
I think this is the logical error here from usage point of view. It is not the fact that they are "dockable" which means they should be grouped together. They should be grouped according to function.
If I want to hide a layer I should not need to think : "last time I did this what did it look like, what sort of GUI element was it that allowed me to hide a layer, was it dockable, where are dockables hidden?"
If I want to hide a layer , I go to the layers menu.
I find it strange anyone would argue against that.
/gg
Olivier
2010-08-28 08:27:37 UTC (over 14 years ago)
Just the simple point of a basic user:
2010/8/28
The layers (dockable) dialog should never be hidden, every GIMP user guide says that. Thus for anybody following this idea, the real question is "If I want to hide a layer, I go to the layers dialog." Otherwise, it would be necessary to copy in the layers menu all the functionalities of the layers dialog, which means a lot.
Is this argument so strange?
2010-08-28 20:13:29 UTC (over 14 years ago)
We do that for a few menu items already and I don't think it has ever caused any problems. Some examples are (and there are many more):
Edit->Undo History
View->Navigation Window
Select->Selection Editor
Colors->Info->Histogram
Actually I think it's just an oversight that the Layers dialog is missing from the Layers menu. IMO all dialogs should be accessible from the menus where they belong to functionally. The "Dockables" menu is just a place to list all the available dialogs. It should be secondary.
2010-08-28 20:17:59 UTC (over 14 years ago)
"Dialogs" is even more special than "Windows" and in single-window-mode it is at least as wrong as using the term "Windows". The "Windows" menu name on the other hand is pretty much default and used in many applications as a place to list all currently open windows. And that's the main use of it in GIMP as well. With the exception that we also list the dockables since we consider them something like sub-windows.
As I pointed out in another mail, most dialogs are already available in their respective menus. Completing this is not a major overhaul, it's a bug-fix.
yahvuu
2010-09-01 12:45:15 UTC (over 14 years ago)
O Peter, Where Art Thou?
This is getting nasty quickly.
Edit->Undo History View->Navigation Window
Another thing to note is that the 'Add Tab' entry from the dockable context menu provides a list of available dockables as well. I think i can explain why this additional option for dockable creation does not create much mental friction:
When i'm browsing the 'Layer' menu, i'm thinking of what can be done with layers. Here is the place to discover the layers dialog -- i can find it here even if i do not have prior knowledge that a layers dialog exists at all.
On the other hand, when adding a tab to an existing docbook using the 'Add Tab' menu, i'm configuring my workspace to better suit the task at hand -- that's a different kind of process than browsing for layer functionality.
Windows->Dockable Dialogs is literally in the middle of these two choices. Perhaps we can weasel out by proclaiming that this isn't a 'menu' but just a list of available dialogs and thus no decision has to be made about which menu to use... That is, paraphrasing what Sven said.
Also, interesting to note how differently the word 'dialog' gets perceived.
bye, yahvuu
Martin Nordholts
2010-09-09 08:59:18 UTC (over 14 years ago)
Your explanation makes sense, my reasoning was broken. I will try fix this for 2.8 (unless, of course, someone does it before me)
/ Martin
