Rotational Motion Blur
| Rotational Motion Blur | Kostas Tigkos | 18 Aug 00:10 |
| Rotational Motion Blur | Bill Skaggs | 18 Aug 01:20 |
| Rotational Motion Blur | gg@catking.net | 18 Aug 08:47 |
| Rotational Motion Blur | Tor Lillqvist | 18 Aug 11:07 |
| Rotational Motion Blur | gg@catking.net | 18 Aug 12:50 |
| Rotational Motion Blur | oliver@first.in-berlin.de | 18 Aug 18:11 |
| Rotational Motion Blur | yahvuu | 18 Aug 19:09 |
| Rotational Motion Blur | Rob Antonishen | 18 Aug 19:55 |
| Rotational Motion Blur | yahvuu | 18 Aug 20:12 |
| Rotational Motion Blur | gg@catking.net | 21 Aug 15:52 |
| Rotational Motion Blur | Kostas Tigkos | 18 Aug 19:25 |
I would like to ask for some insight concerning the algorithm used for the Rotational Motion Blur filter if possible. I would be very grateful if someone could post the idea behind the implemenation of this filter either by a mathematical algorithm or pseudocode.
Thanks in advance.
Kostas
I just looked over the code -- if I understand it correctly, it creates an
arc of the specified angle
passing through each point of the image, generates a set of points equally
spaced along the arc,
uses interpolation to get the color for each of these points, and then
averages all the colors together,
with equal weighting. The number of points is proportional to the length of
the arc, with adjustments
if it is too large or too small. If you need more detail, please ask.
-- Bill
On 08/18/10 01:20, Bill Skaggs wrote:
I just looked over the code -- if I understand it correctly, it creates an arc of the specified angle
passing through each point of the image, generates a set of points equally spaced along the arc,
uses interpolation to get the color for each of these points, and then averages all the colors together,
with equal weighting. The number of points is proportional to the length of the arc, with adjustments
if it is too large or too small. If you need more detail, please ask.-- Bill
I'm sure you are right in reading the code, so this feature seems more like a rotation blur than motion blur.
A motion blur is a retinal effect that has a time dependence. This does not seem to be what is done. The equal weighting is wrong.
The retinal retention of the image fades with time (my guess would be exponentially if we're going to be rigorous). This means the weighting of each point should be diminished as we work back along the arc. This reduction should be angular and at least a linear reduction of weight w.r.t. the angular coord would probably be a decent approximation. Otherwise a lookup table of exponential decay would mean very little overhead in doing a fairly rigorous model of the real effect.
This effect will vary dependant on speed of the movement (as everyone knows intuitively) so this parameter needs to be adjustable in the tool UI.
I assume the same points could be made about the motion blur , though I have not looked at the code.
I'd don't have the time to get into coding an improvement but thought it worth noting the apparent shortcomings of the "motion" blur and how it could be improved.
regards.
Is "motion blur" actually something people perceive with their eyes and brain, or something that only exists in physical artefacts? (Either intentionally created by an artist to give the impression of motion, or as an direct result of the method the still or motion picture was created.) And we have been so used to it that we "know" what it means, even if it doesn't correspond to what we actually see?
(But yeah, gg's arguments make sense.)
--tml
--tml
Good point, the equal weighting probably is close to what a silver nitrate film camera would record, which is probably what this was intended to model.
/gg
--tml
The human eye has sharpness only in the middle of sight. Things that move forward and can't be focussed, obviously willo be unsharp. and translation and rotation therefore will also give unsharpness in the human eye/brain. So this is not only what a camera would record.
Ciao, Oliver
--tml
I think so, too. Consider the star trails in a long-time exposure of a night sky: there is no decay visible. However, and whatever the motivation, it's an interesting idea, so here's a quick comparison for a linear motion blur: http://yahvuu.files.wordpress.com/2009/08/blurtest.png
Regretably, the mathmap convolve function introduces some artifacts, but i think it can be seen that 'decaying' (or 'soft'?) motion blur is an option of artistical relevance.
Tongue in cheek, i shurely wouldn't oppose if someone wanted to get code providing this functionality included into GIMP .->>>
regards, yahvuu
Thanks for the insight and ideas. I didn't mention I am working on a
numerical algorithm
for deblurring images that have been blurred by non-accelerated circular
motion around
any possible axis so it was nice to get some ideas however the
applications for which it is
intended require more accuracy. I also noticed that this particular
filter is quite slow.
I have been experimenting with deforming the image into polar
coordinates using interpolation
schemes to get a good resolution and then applying regular, linear
motion blur horizontally or
vertically which would correspond to the "zoom" blur or "rotational"
motion blur effects. Then
the image must be deformed back to cartesian coordinates using again
some sort of interpolation.
So far it looks right if resolution is taken care of and it's quite
fast. Haven't tried the cases where
the image plane is not perpendicular to the axis of rotation and the
debluring algorithm still needs
to be developed. In any case all this is in prototype form (Matlab) and
if all goes well it could be
perhaps ported to GIMP when everything has been worked out.
To complete the set, here is a non-Gaussian blur with an x blur of 40 px and a y blur of 0.
http://www.majhost.com/gallery/ffaat/gimp/more2/gb.png
-Rob A>
thank you, new URL is
http://yahvuu.files.wordpress.com/2009/08/blurtest2.png
regards, yahvuu
--tml
http://yahvuu.files.wordpress.com/2009/08/blurtest.pngRegretably, the mathmap convolve function introduces some artifacts, but i think it can be seen that 'decaying' (or 'soft'?) motion blur is an option of artistical relevance.
regards, yahvuu
The blurtest.png is interesting. The example with the decaying kernel is the only one that suggests movement to me , it definitely has direction. All the others look, well, blurred.
Despite the artifacts of the implementation, this suggests some sort of progressive blur may be interesting and may suggest movement better than current photographic blur.
/gg
