layer modes - open questions
layer modes - open questions Rupert Weber 15 Aug 21:16
  layer modes - open questions David Gowers 16 Aug 02:33
Rupert Weber
2010-08-15 21:16:11 UTC (almost 15 years ago)
There are still some issues that I either blissfully ignored or took the least-cost route on:
(1) enums and gimp-composite While the values of legacy layer mode enums are preserved, gimp-composite.h has its own GIMP_COMPOSITE_* enums which append some modes to the layer mode list. (GIMP_COMPOSITE_BLEND, _SHADE, _SWAP,...).
Those additional enums have their values changed. Is that a problem? (I can't even find any place they are used)
(2) file import/export For import of psp, psd and xjt I simply assumed the new modes would be more appropriate than the old ones.
For exporting, I just mapped the new modes along with the old ones. But I don't know what would be correct for those file formats/programs.
(3) paint-funcs layer modes Is the layer mode code in app/paint-funcs ever used? If so, the code would have to be amended accordingly. Right now, I just mapped the new modes to the old functions.
I think that's about it.
Regards
Rupert
David Gowers
2010-08-16 02:33:42 UTC (almost 15 years ago)
grepping the entire codebase only lists paint-funcs.c as a user of dissolve_pixels() and of layer_*_mode() [therefore *_pixels() are dependencies too]
AFAICS the code in paint_funcs.c which depends on the layer-modes.c code is used indirectly by:
* the merge-down code [app/core/gimpimage-merge.c] * the projection code [app/core/gimplayer-project.c] * the fade code [app/core/gimpdrawable-combine.c]
