2.7.3 Performance
21 of 21 messages available
2.7.3 Performance ProphetofDoom 10 Aug 10:17
  2.7.3 Performance Alexia Death 10 Aug 11:11
  2.7.3 Performance Alexia Death 10 Aug 11:14
  2.7.3 Performance Liam R E Quin 10 Aug 14:12
2.7.3 Performance Dave 10 Aug 18:55
  2.7.3 Performance Alexandre Prokoudine 10 Aug 19:05
2.7.3 Performance Dave 10 Aug 21:47
  2.7.3 Performance Jernej Simon?i? 10 Aug 22:27
   2.7.3 Performance SorinN 10 Aug 22:37
   2.7.3 Performance GSR - FR 10 Aug 22:50
  2.7.3 Performance Alexia Death 10 Aug 22:48
   2.7.3 Performance Jernej Simon?i? 10 Aug 23:00
2.7.3 Performance Dave 11 Aug 00:27
  2.7.3 Performance Alexia Death 11 Aug 00:53
  2.7.3 Performance David Gowers 11 Aug 01:58
   2.7.3 Performance Alexia Death 11 Aug 02:21
   2.7.3 Performance GSR - FR 11 Aug 02:55
    2.7.3 Performance David Gowers 11 Aug 04:42
     2.7.3 Performance David Gowers 11 Aug 05:04
      2.7.3 Performance Alexia Death 11 Aug 23:54
       2.7.3 Performance David Gowers 12 Aug 01:06
2010-08-10 10:17:49 UTC (over 14 years ago)
2.7.3 Performance
I tried out 2.7.3 from the 'matthaeus123' PPA for Ubuntu. I like the new features but noted some performance issues. I don't have a particularly powerful PC (stats below) but I've run 2.6 on even lower specced PCs with no issue, therefore 2.7 must be introducing some significant additional resource demands?
I experienced lag on brush strokes with CPU utilization maxing out at 100% (it was always high even with 2.6) but is bad enough that I've reverted back to 2.6.10. Single or multi window interface didn't make much difference so I suspect the new brush engine?
I haven't seen anything on the forum about this, is it a known issue? But since the performance difference between 2.6 and 2.7 is significant enough to render 2.7 unusable (on low spec PCs) I thought it was worth a mention.
My PC stats AMD 2800+ 2.08Mhz processor, 1.5Gb memory, ATI Radeon 9200SE, ubuntu 10.4
Alexia Death
2010-08-10 11:11:36 UTC (over 14 years ago)
2.7.3 Performance
There are two aspects to this, namely wether transforms are on or not, but in general basic brush performance with transforming turned off is actually expected to be better than 2.6 series , because there is at least the outline drawing optimization in place.
Can you please describe your setup in more detail?
Alexia Death
2010-08-10 11:14:07 UTC (over 14 years ago)
2.7.3 Performance
-- --Alexia
P.S Please register to the list. Using this forum front-end is... Well, I feel its somewhat rude.
Liam R E Quin
2010-08-10 14:12:19 UTC (over 14 years ago)
2.7.3 Performance
Do you have compositing on? (e.g. do windows have a drop shadow round them?)
Turning that off helps a lot on my laptop.
Liam
Dave
2010-08-10 18:55:26 UTC (over 14 years ago)
2.7.3 Performance
Apologies to Alexia for being 'rude'. I simply found a forum and used it. :(
I'm not sure I understand what you mean by transforms being on or off. How/ where do I set this?
What more can I tell you about my set up that would help?
I use Ubuntu 10.4, with Gnome and compiz switched on. I use a wacom intuos 3 with pressure sensitivity switched on in gimp.
I've reinstalled 2.7.2 (not 2.7.3 as in the title). I don't like the tapering effect of the 'Basic Dynamics' brush setting so I've created my own that sets opacity only so as to emulate what I would typically use in 2.6. However irrespective of the brush dynamic the brush lags during use. The lag is unnoticeable with a small 1600x1200 single layer file, but very noticeable on one that is 1521X2807 with 10 layers. I typically work on files double that size in 2.6 without issue.
Switching compiz off possibly improves this marginally but it still lags.
Other than that the Gimp set up is pretty much 'out of the box' standard.
2010-08-10 19:05:15 UTC (over 14 years ago)
2.7.3 Performance
And typical brush size would be...?
Dave
2010-08-10 21:47:08 UTC (over 14 years ago)
2.7.3 Performance
I only use the brush tool, mostly with hard round brushes any size typically up to about 25 pixel radius, spacing 10. opacity on. no other brush dynamics set. Smaller the brush the better the performance is.
Jernej Simon?i?
2010-08-10 22:27:15 UTC (over 14 years ago)
2.7.3 Performance
Can you please fix your e-mail client so that it: - doesn't remove the References and In-Reply-To headers to enable proper threading of your messages
- quotes the message you're replying to - doesn't send HTML when it's completely unnecessary
(also, where did you find GIMP 2.7.3? The latest 2.7 release is 2.7.1)
SorinN
2010-08-10 22:37:21 UTC (over 14 years ago)
2.7.3 Performance
probably he compile the a devel version - my previous compilation reported itself as 2.7.3 but the newest is 2.7.2 ;)
2010/8/11 Jernej Simon?i? :
-- < Jernej Simon?i? ><><><><>< http://eternallybored.org/ >
Problems worthy of attack prove their worth by hitting back.       -- Hein's Law
Alexia Death
2010-08-10 22:48:33 UTC (over 14 years ago)
2.7.3 Performance
Do you use a tablet?
There are really no changes in GIMP that should degrade performance for larger brushes. There is a little more interpolation, but that should affect all brush sizes either equally or larger brushes less.
Also, what GTK is the build you have using?
Im sorry, If I seemed unfriendly. I just find putting a mailing list behind a forum front end with posting option to be of poor taste... Not really your fault.
He cant. He was using the "forum" client gimpusers has. He probably does not have any mail to reply too...
theres an ubuntu PPA with shifted versioning. It should be GIT nightly build AFAIK.
GSR - FR
2010-08-10 22:50:43 UTC (over 14 years ago)
2.7.3 Performance
jernej@ena.si (2010-08-10 at 2227.15 +0200):
Unofficial "releases" claiming "random" numbers. Some even claim things like:
"... An update: actually, the version of the currently installed unstable GIMP is 2.7.3-2010022601, even if it says 2.7.1 in the Info window."
GSR
Jernej Simon?i?
2010-08-10 23:00:52 UTC (over 14 years ago)
2.7.3 Performance
In that case gimpusers should fix their forum client. I'm not that bothered by the HTML, but having neither threads, nor quotes makes getting a message context practically impossible.
Dave
2010-08-11 00:27:48 UTC (over 14 years ago)
2.7.3 Performance
Wow, guys, If you want to use the mailing list that's fine. but lets remove the forum front end or make it read only so that we have a standard. Don't beat me up over it.
I used the ubuntu ppa found here:
https://launchpad.net/~matthaeus123/+archive/mrw-gimp-svn
The version keeps changing. Previous time I tried it, it quoted 2.7.3, now it says 2.7.2
Yes I use a wacom intuos3 with pressure sensitivity switched on in gimp.
I'm aware I havent given you anything other than my unscientific empirical experience here and I would be amazed if anyone could diagnose anything from that. It could be the PPA build is dodgy. It could be my config. Who knows. I was hoping someone would just jump up and say yes we know its work in progress. And if it isn't I'm not too upset because I'm upgrading my PC soon anyway so for me this issue is likely to go away. I just wanted to flag it since others with low spec PC's enjoying 2.6 might have similar issues moving to 2.7.
Maybe there should be a call for more peoples experiences to try and build a bigger picture....
Alexia Death
2010-08-11 00:53:50 UTC (over 14 years ago)
2.7.3 Performance
We dont have control over what gimpusers have on their site as its a 3rd party site. Sorry again, if I have been beating you up over it.
Ah, corrected the error then.
I have the same setup then.
Your problem is interesting, because its contrary to what I would expect and experience myself. For me GIT version performs about twice as good as 2.6, especially with large brushes, and thats with compositing on. To get the 25px round brush to lag at all I have to move lightningfast. and then it usually catches up in under 2 seconds. My hardware configuration is admittedly slightly better than yours... But 25px brushes really shouldnt be a problem anywhere.
Yes. perhaps. but experiences dont help me fix the problem if there is one. Someone who can build gimp themselves and use a profiler and has this issue would really help.
-- Alexia
David Gowers
2010-08-11 01:58:56 UTC (over 14 years ago)
2.7.3 Performance
In view of what Alexia just said:
Your problem is interesting, because its contrary to what I >would expect and experience myself. For me GIT version performs about twice >as good as 2.6, especially with large brushes, and thats with compositing on. >To get the 25px round brush to lag at all I have to move lightningfast. and >then it usually catches up in under 2 seconds. My hardware configuration is >admittedly slightly better than yours... But 25px brushes really shouldnt be a >problem anywhere.
I am suspecting your Xorg server version, config, or video hardware has changed as well as your GIMP version. I found myself, that redraws in paint programs were intolerably slow until I added the
Option "AccelMethod" "XAA"
to the video card config in my xorg.conf. (EXA is the default, and makes 3d performance much better, but unfortunately seems to cripple 2d painting performance on my card. XAA might effect compositing (as in WM compositing) speed significantly instead.)
Perhaps you could try the above option and see if it makes any difference.
FYI, I have an ATI Radeon 9800 or thereabouts. I've read that this problem does not occur on NVidia cards and newer ATI cards.
[incidentally, 2.7 uses Cairo more for display related things (not for rendering brushes IIRC, but of course in order to see the rendered brush strokes, the area must be displayed). It's possible that this impacts your system significantly while using the default EXA acceleration. So it could be a combination of a change in GIMP and annoying hardware/driver misconfiguration.]
HTH,
another Dave :)
Alexia Death
2010-08-11 02:21:19 UTC (over 14 years ago)
2.7.3 Performance
There is a change there that puts a little more pressure on the graphics card to keep up, the event fill. It should not be an issue for properly functioning graphics hardware, the optimizations elsewhere make up the tiny slowdown it introduced with large surplus, but in combination with GPU not taking its share of the display update load, it can can theoretically perform worse than 2.6.
And now Im remembering that years ago I had a 9800SE radeon card and I actually needed to change that option too to have any performance in painting apps.
GSR - FR
2010-08-11 02:55:54 UTC (over 14 years ago)
2.7.3 Performance
00ai99@gmail.com (2010-08-11 at 0928.56 +0930):
Here it was general. GIMP's interface took a couple of seconds to redraw, but so did FF while scrolling (slideshowing would describe it better).
Other thing to try is keeping EXA but with: Option "MigrationHeuristic" "greedy"
GSR
David Gowers
2010-08-11 04:42:28 UTC (over 14 years ago)
2.7.3 Performance
I've just tried this and it works for me. MyPaint becomes is just as responsive as with XAA, except for the panning. GIMP is a jerk (I get cases where I draw a curve and the middle of it gets flattened into a straight line); But I haven't been painting anything with GIMP recently so I don't know whether it's also a jerk with XAA. 3d performance in Blender is fairly poor (but noticably better than with XAA)
Panning in both MyPaint and GIMP (and Firefox) is still noticably slower. Fast smooth panning is important to me, so I will switch back to XAA.
David Gowers
2010-08-11 05:04:36 UTC (over 14 years ago)
2.7.3 Performance
On Wed, Aug 11, 2010 at 12:12 PM, David Gowers wrote:
On Wed, Aug 11, 2010 at 10:25 AM, GSR - FR wrote: GIMP is a jerk (I get
It is. Looks like I have a bug to file.
Alexia Death
2010-08-11 23:54:50 UTC (over 14 years ago)
2.7.3 Performance
Not with GIMP. Its a bug in the wacom driver. Top end of the pressure scale ends up with pressure 0. And I have a vague memory thats fixed somewhere in development pipeline.
-- Alexia.
David Gowers
2010-08-12 01:06:24 UTC (over 14 years ago)
2.7.3 Performance
I have the fixed version already.(0.10.8)
Believe me, after experiencing THAT problem, I would know about it. Generally that problem resulted in the stroke ending and no more drawing until I eased off on the pressure.
This is a different bug (and, MyPaint also uses the GTK+ input code and does NOT experience this bug at all no matter how fast I move)
