small Wishlist regarding Guides
small Wishlist regarding Guides oliver@first.in-berlin.de 01 Aug 16:25
  small Wishlist regarding Guides LightningIsMyName 01 Aug 17:42
   small Wishlist regarding Guides Martin Nordholts 01 Aug 23:07
   small Wishlist regarding Guides oliver@first.in-berlin.de 18 Aug 12:19
    small Wishlist regarding Guides Chris Mohler 18 Aug 17:17
2010-08-01 16:25:30 UTC (over 14 years ago)
I have a small wishlist regarding Guides.
- non-rectangle-bound guides: Guides that can be enabled to have any angle, which means that they do not have to be restricted to be 0 degrees or 90 degrees (being parallel to the window).
This feature can be helpful, e.g. when correcting pictures, or for drawing parallels that do not fit the 0/90/180/270/360 degree orientation.
It would be good, to enable/disable this behaviour via toggle box, so that normal behaviour will be available and guides can be restricted to classical window-parallel behaviour.
- boundary guides, instead of middle.guides: Guides, where the outer boundary of a drawing tool snaps to the guide (instead the middle of the drawing tool snapping to the guide).
This would be helpful for drawing in general, and correcting pictures: the color will not pass this line of the guide, which means, you can be sure no color enters a certain region.
- Adding Multiple Guides (there is a Script for this on www.meetthegimp.org, but native would be nice)
This feature is good for some repetitive tasks, where a lot of Guides will be needed, something like a guide-grid.
Ciao, Oliver
LightningIsMyName
2010-08-01 17:42:00 UTC (over 14 years ago)
Hello
I think we have seen this request already several times and I definitely agree it could be useful. Your request made me take a look at the code (app/display/gimpdisplayshell-draw.c, app/core/gimpimage-guides.c, /app/core/gimpguide.c) and it actually seems possible. I'll add it to my to-try list for when I have some more time.
This does not seem trivial to code - in fact with how I remember the paint core works, this is going to be one very hard hack... Also, I think that if the purpose is just to stay inside of the lines you can use a selection (create it using the guides and freeform selection) and stroke it on a new layer with a mask which is exactly the selection - I do this all the time. Stroking a selection is usually faster than me painting it by hand, and it's probably more accurate.
Can you give a direct link to the script? I definitely agree this sounds useful - it's worth checking if we can simply include this script with GIMP (or at least if you give us a link to it, we'll be able to write something similar with extra features if needed).
~LightningIsMyName
Martin Nordholts
2010-08-01 23:07:13 UTC (over 14 years ago)
On 08/01/2010 05:42 PM, LightningIsMyName wrote:
Hello
FYI, here's a bug report with a non-finished patch: https://bugzilla.gnome.org/show_bug.cgi?id=344109
/ Martin
2010-08-18 12:19:34 UTC (over 14 years ago)
On Sun, Aug 01, 2010 at 06:42:00PM +0300, LightningIsMyName wrote: [...]
From this thread:
http://forum.meetthegimp.org/index.php/topic,735.0.html
There are Links to some versions of that script. Pick the last one. ;)
Ciao,
Oliver
Chris Mohler
2010-08-18 17:17:50 UTC (over 14 years ago)
There is also a grid of guides script here: http://registry.gimp.org/node/12003
Chris
