window of extenral editor, or just external window ?
window of extenral editor, or just external window ? (translation related) Cristian Secar? 30 Jul 17:13
  window of extenral editor, or just external window ? (translation related) Alexandre Prokoudine 30 Jul 17:17
   window of extenral editor, or just external window ? (translation related) Cristian Secar? 30 Jul 17:26
    window of extenral editor, or just external window ? Jernej Simon?i? 30 Jul 20:40
     window of extenral editor, or just external window ? Cristian Secar? 30 Jul 21:29
Cristian Secar?
2010-07-30 17:13:43 UTC (over 14 years ago)
How should I read this string ?
#: ../app/tools/gimptextoptions.c:186 msgid "Use an external editor window for text entry, instead of direct-on-canvas editing"
1. Use an editor that is already available in the system, which will open in external window.
2. Use a GIMP built-in editor, only that it will open in an external window instead of writing directly on canvas.
Thank you, Cristi
2010-07-30 17:17:11 UTC (over 14 years ago)
It will open the dialog you can see in 2.6.x stable versions when you choose Text tool and click on canvas. Why not just try it? :)
Cristian Secar?
2010-07-30 17:26:14 UTC (over 14 years ago)
Ok.
Because GIMP 2.7.1 crashes whenever I try to write any text :p
Cristi
Jernej Simon?i?
2010-07-30 20:40:48 UTC (over 14 years ago)
If you're on Windows, the workaround is to delete Program Files\GIMP 2.7\etc\gtk-2.0\gtkrc.
Cristian Secar?
2010-07-30 21:29:17 UTC (over 14 years ago)
Yes, that worked. Thank you.
In fact, another workaround is to delete line 45 (engine "wimp") in the file C:\Program Files\GIMP 2.7\share\themes\MS-Windows\gtk-2.0\gtkrc
Cristi
