Bug Bug 568150 With 'Resize window on zoom', zoom focus does not work when window is of maximum size
xianghang liu
2010-07-26 12:27:52 UTC (over 14 years ago)
I think this bug can be fixed by the attached patch. The function gimp_display_shell_scale () is modified so that when the window if of the maximum size, zoom in will be processed in the same way as the situation that "Resize window on zoom" is not selected.
I have checked Photoshop CS5 and found it has a similar behavior.
This patch is just the illustration of the idea. I am happy to make any modification to it if there are any mistakes.
Cheers, Xianghang
peter sikking
2010-07-26 12:53:48 UTC (over 14 years ago)
great. I trust that the solution is the right thing because Martin pointed out in the bug what should happen and where to repair it.
uhm, can I (without drama) say that that proves exactly nothing for us?
in general, a the right UI solution for us is:
- good UI design in general - fits the context of GIMP (metaphors, models, legacy)
on both counts ps can be pointing in exactly the wrong direction.
--ps
xianghang liu
2010-07-27 13:39:28 UTC (over 14 years ago)
Then what I need to do to get this patch applied to the git version of GIMP.
Thanks,
lxh
Tobias Jakobs
2010-07-27 14:01:04 UTC (over 14 years ago)
I'm not a GIMP developer, but usually it's a good idea to attach patches to the bugreport, so they don't get lost.
Regards, Tobias
xianghang liu
2010-07-28 15:02:38 UTC (over 14 years ago)
Thanks a lot. I will do this.
Cheers, lxh
