How to edit context menu?
9 of 9 messages available
How to edit context menu? Bear 19 Jun 14:29
  How to edit context menu? Michael Natterer 19 Jun 17:05
  How to edit context menu? Bill Skaggs 20 Jun 00:02
How to edit context menu? Bear 19 Jun 17:49
  How to edit context menu? Sven Neumann 19 Jun 22:31
How to edit context menu? Bear 21 Jun 02:46
How to edit context menu? Bear 21 Jun 02:49
  How to edit context menu? Bill Skaggs 22 Jun 00:45
How to edit context menu? Bear 26 Jun 16:52
Bear
2010-06-19 14:29:37 UTC (over 15 years ago)
hi,
I wanna edit my GIMP's context menu. Now the context menu is as seems as the menu bar. I wanna use my customized context menu to replace the original one. I found some clue in
app/widgets/gimpuimanager.c:573
which say:
void
gimp_ui_manager_ui_popup (GimpUIManager *manager, const gchar *ui_path, GtkWidget *parent, GimpMenuPositionFunc position_func, gpointer position_data, GDestroyNotify popdown_func, gpointer popdown_data)
but how to do next? thx!!
-------------- Bear
2010-06-19
Michael Natterer
2010-06-19 17:05:50 UTC (over 15 years ago)
On Sat, 2010-06-19 at 20:29 +0800, Bear wrote:
hi,
which say:
void
edit menus/image-menu.xml.in, there is no need to change anything in the source.
ciao,
--mitch
Bear
2010-06-19 17:49:58 UTC (over 15 years ago)
hi,
Er... but my work is to make it popup something like a new window instead the original context menu... Could you help me? thx!
------------------ Bear
2010-06-19
Send Date:2010-06-19 23:05:54
To:Bear
CC:gimp-developer
Subject:Re: [Gimp-developer] How to edit context menu?
hi,
which say:
void
ciao,
--mitch
2010-06-19 22:31:41 UTC (over 15 years ago)
On Sat, 2010-06-19 at 23:49 +0800, Bear wrote:
hi,
Are you familiar with GTK+? If not, please read the documentation and tutorials before you ask here. We can certainly help you with GIMP specific questions, but I get the impression that you are lacking some fundamental GTK+ knowledge that is absolutely essential for what you are trying to achieve.
Bill Skaggs
2010-06-20 00:02:24 UTC (over 15 years ago)
If you want to do this for your new tool, you might benefit from looking at gimptexttool.c --
the function gimp_text_tool_get_popup is what sets up the context menu for the text
tool. It is invoked in the gimp_text_tool_class_init function, in the line that reads
tool_class->get_popup = gimp_text_tool_get_popup;
The code is pretty hard to understand without deep knowledge of the Gtk menu system,
though.
The actual contents of the context menu are where Mitch pointed you.
-- Bill
Bear
2010-06-21 02:46:15 UTC (over 15 years ago)
hi,
Maybe my poor english made you confused about my task? I have some knowledge on gtk+. My task is to response the right-click message on canvas. Is this clear? The original responding is to popup a menu which as same as the menubar. I wanna modify it. For example, to popup a message box or new window and so on.
2010-06-21
Send Date:2010-06-20 04:31:11
To:Bear
CC:gimp-developer
hi,
Bear
2010-06-21 02:49:09 UTC (over 15 years ago)
hi,
thx for your help!!!
I will read the code you referred. Thx a lot. But it seems like that gimp_text_tool_get_popup is very complex...
2010-06-21
Send Date:2010-06-20 06:02:25
To:Bear
CC:gimp-developer
though.
-- Bill
Bill Skaggs
2010-06-22 00:45:50 UTC (over 15 years ago)
It isn't as bad as it looks. The im_menu stuff all relates to a special submenu, and
you can discard it. The rest you can replicate as is (with the obvious changes).
Here is a quick summary of how to create a context menu for a tool:
1) Create a get_popup handler similar to gimp_text_tool_get_popup.
2) Create menu actions by creating a file similar to app/actions/text-tool-actions.c.
3) Create menu commands by creating a file similar to app/actions/text-tool-commands.c.
4) Define the menu structure by creating a file similar to menus/text-tool-menu.xml.
It should be possible to do most of this without a very deep understanding of the code.
-- Bill
Bear
2010-06-26 16:52:59 UTC (over 15 years ago)
hi,
I am very very thankful for your help!!! After 3 days working, I already done this job! Without your help, I wont finish it. Thx so much!
2010-06-26
Send Date:2010-06-22 06:45:50
To:Bear
CC:gimp-developer
Subject:Re: Re: [Gimp-developer] How to edit context menu?
-- Bill
