GIMP is useless without a usable installable help.
12 of 12 messages available
GIMP is useless without a usable installable help. jackkessler 13 Jun 18:38
  GIMP is useless without a usable installable help. Michael Schumacher 13 Jun 19:31
   GIMP is useless without a usable installable help. Kolbjørn Stuestøl 13 Jun 23:33
    GIMP is useless without a usable installable help. Kolbjørn Stuestøl 13 Jun 23:41
    GIMP is useless without a usable installable help. Alexandre Prokoudine 14 Jun 07:57
    GIMP is useless without a usable installable help. Michael Schumacher 14 Jun 09:11
     GIMP is useless without a usable installable help. Kolbjørn Stuestøl 14 Jun 20:36
      GIMP is useless without a usable installable help. Michael Schumacher 14 Jun 21:00
       GIMP is useless without a usable installable help. Kolbjørn Stuestøl 14 Jun 23:37
        GIMP is useless without a usable installable help. Kolbjørn Stuestøl 14 Jun 23:42
        GIMP is useless without a usable installable help. Michael Schumacher 14 Jun 23:52
        GIMP is useless without a usable installable help. Sven Neumann 14 Jun 23:56
2010-06-13 18:38:36 UTC (over 15 years ago)
What possible value could there be to further developing the GIMP application when ordinary users cannot use it because the HELP documentation cannot be made to install and then work in Windows?
2010-06-13 19:31:07 UTC (over 15 years ago)
Huh? As far as I know, the help is installable on Windows and works fine.
Kolbjørn Stuestøl
2010-06-13 23:33:28 UTC (over 15 years ago)
Michael Schumacher skreiv:
Yes, but unlike most Windows applications, you have to do the installation yourself. The proses is a bit unusual to Windows users, quite common to Linux users.
Download the wanted help file to your computer from ftp://ftp.gimp.org/pub/gimp/help/. The .bz2 file is a zipped file. Unzip it using your zip program.
In the GIMP folder share/gimp/2.0 create a folder named help. Copy the two letters language folder in the unzipped catalog to the help folder. (The other files is of no use in this case). In my version of Windows the full path in my computer is .../share/gimp/2.0/help/nn.
BTW: Somebody know why is the help files in http://www.gimp.org/docs/ are not updated? The Norwegian help files is still pointing to http://www.gimp.org/docs/2.6/no which is not updated anymore and do not exist in the git.gnome.org/gimp-help-2 repository. Instead it should be pointing to .../2.6/nn which exists in the repository. Kolbjoern
Kolbjørn Stuestøl
2010-06-13 23:41:01 UTC (over 15 years ago)
Kolbjørn Stuestøl skreiv:
I forgot: Neither the ftp://ftp.gimp.org/pub/gimp/help/ is updated for any language.
Kolbjoern
2010-06-14 07:57:34 UTC (over 15 years ago)
Unlike most Windows applications full size of GIMP Help installer is far over 100MB, and Windows applications like GIMP are anyway usually sold in boxes on CDs or DVDs.
This has already been discussed in gimp-developer@. One of the solutions is to create such an installer of GIMP that will ask what help package(s) a user needs, download it/them and install.
2010-06-14 09:11:56 UTC (over 15 years ago)
Von: "Kolbjørn Stuestøl"
Well yes, it is another installer, but provided on the same page as the GIMP installers: http://gimp-win.sourceforge.net/stable.html
HTH, Michael
Kolbjørn Stuestøl
2010-06-14 20:36:46 UTC (over 15 years ago)
HTH, Michael
Yes, you are right. Even simpler as this help files is contributed in an installer (and are using the correct language code for "nn"). But these files too are outdated. (October the 1st 2009). Where do the average user find the updated files?
Kolbjoern
2010-06-14 21:00:07 UTC (over 15 years ago)
They find them in new installers created for newer releases of the GIMP user manual. At the moment, 2.6.0 is the most current release available from ftp://ftp.gimp.org/pub/gimp/help
If you want more up-to-date docs, make sure that there is a more up-to-date release (FTP space should be less of an issue soon).
HTH, Michael
Kolbjørn Stuestøl
2010-06-14 23:37:37 UTC (over 15 years ago)
HTH, Michael
These files too are the same outdated ones. (October the 1st & 2nd 2009) So the question is: When will they be updated?
Kolbjoern
Kolbjørn Stuestøl
2010-06-14 23:42:43 UTC (over 15 years ago)
HTH, Michael
Kolbjoern
A few seconds after sending my mail, Sven's mail popped up. Think this is the answer to my question.
Sorry Sven, I am not able to do the job. Lack of knowledge and capacity on my internet connection.
Kolbjoern
2010-06-14 23:52:40 UTC (over 15 years ago)
Yes, because this is the same 2.6.0 release.
Is there a 2.6.1 release of the help files?
Regards, Michael
2010-06-14 23:56:52 UTC (over 15 years ago)
HTH, Michael
Just read the mail from Michael again. If you want your changes to be turned into easily installable packages, then your team needs to make releases more frequently. No-one is going to package the documentation from a git snapshot. You need to decide when the git tree is in a good shape and roll out a gimp-help release. Then the packagers will pick it up and deliver it to the users.
