section history
10 of 13 messages available
section history Ulf-D. Ehlert 01 Jun 20:23
  section history Marco Ciampa 02 Jun 13:50
   section history Kolbjørn Stuestøl 02 Jun 17:11
  section history jhardlin 02 Jun 21:03
   section history Marco Ciampa 02 Jun 21:28
    section history jhardlin 03 Jun 06:49
     201006041312.13554.ude88@we... Ulf-D. Ehlert 04 Jun 13:12
      section history jhardlin 04 Jun 21:18
       201006071333.06044.ude88@we... Ulf-D. Ehlert 07 Jun 13:33
        section history jhardlin 08 Jun 09:23
         section history jhardlin 09 Jun 06:40
         201006142036.15271.ude88@we... Ulf-D. Ehlert 14 Jun 20:36
          section history jhardlin 18 Jun 07:47
Ulf-D. Ehlert
2010-06-01 20:23:03 UTC (almost 15 years ago)
section history
our XML files still contain section history comments like
IMO these comments are obsolete and useless, and we could remove them (whenever we edit XML files).
What do you think?
Ulf
Marco Ciampa
2010-06-02 13:50:52 UTC (almost 15 years ago)
section history
What do you think?
Ulf
Please do!
Many thanks Ulf!
Kolbjørn Stuestøl
2010-06-02 17:11:49 UTC (almost 15 years ago)
section history
Marco Ciampa skreiv:
What do you think?
Ulf
Please do!
Many thanks Ulf!
Yes, do it. No use of these comments anymore. Kolbjoern
jhardlin
2010-06-02 21:03:32 UTC (almost 15 years ago)
section history
Anonymous xml files is not a good idea
I think the history must be reserved for creation and adding new features. So, we can delete all what is about translation or fixing typos.
Julien
Marco Ciampa
2010-06-02 21:28:08 UTC (almost 15 years ago)
section history
So git log are for what? Please avoid redundant data.
jhardlin
2010-06-03 06:49:07 UTC (almost 15 years ago)
section history
Rather complicated. When working on xml files, better to have this information at once.
jhardlin
2010-06-04 21:18:11 UTC (almost 15 years ago)
section history
Which information do you really need? Most info (including creation date or new features) you can get by "git log" - if we provide good commit messages - or "git blame".
And, of course, you can still add comments to the XML source.
In git log, file history is scattered and difficult to find. Every po file is signed. Why not xml? History tag exists in the xml language. Why not use it?
Sure, history is not necessary to work on a xml file. Young people generally are not interested in history : I am not young, and I find pleasant to have all the history of the file summarized at the beginning without needing to browse all the log over.
Julien
jhardlin
2010-06-08 09:23:02 UTC (almost 15 years ago)
section history
What do mean with "signed"? The header?
At the end of every po file :
#. Put one translator per line, in the form of NAME , YEAR1, YEAR2 #: src/concepts/basic-setup.xml:0(None) msgid "translator-credits"
msgstr ""
"Daniel Egger\n"
"Roman Joost\n"
"Axel Wernicke\n"
"Ulf-D. Ehlert"
Adding s again and using them according to the examples in "DocBook: The Definitive Guide" may be better than using our selfmade "section history" comments (we should suppress the output to HTML, IMHO). But isn't one for every XML file an overkill?
I agree with you. As they are now, "section history" are outdated. But I still think that they are interesting. We must only use them for creation and new features, not for typo corrections, changes in xml structure...(translation is no longer topical). is not convenient:
- it will give a long and tedious list in the xml file - it will appear in html and that is not useful
Unless there is another way to make xml files NOT anonymous, I think that our short and overall "section history" comments are the simplest way.
Julien
jhardlin
2010-06-09 06:40:24 UTC (almost 15 years ago)
section history
msgstr ""
"Daniel Egger\n"
"Roman Joost\n"
"Axel Wernicke\n"
"Ulf-D. Ehlert"
Julien
jhardlin
2010-06-18 07:47:01 UTC (almost 15 years ago)
section history
msgstr ""
"Daniel Egger\n"
"Roman Joost\n"
"Axel Wernicke\n"
"Ulf-D. Ehlert"
Hmm, is this a really useful information?
Not "useful", but responsible.
So which "events" are worth to be noted down, and which are not? Let's have a look at some sample section history entries:
2007-06-16 Added Spanish translation by AntI 2006-01-18 en;fr reviewed by j.h
2005/11/11 split of from layer-mask.xml by axel.wernicke 2008-12-29 j.h: rev. v2.6
2007-10-17 ude: moved here from menus/layer-white-balance.xml 2006-08-08: created by scb; example by j.h 2005-12-07 replaced by by lexa
2008-01-31 j.h: created
2008-12-29 j.h: link to File-references to be fixed 2007-10-17 j.h: updated to v2.4 (comment) 2006-09-19 lexa: minor change (link enabled) 2006-07-03 changed the note en;fr by j.h 2006-06-17 added a para en;fr for default image size by j.h 2007-05-09 ude: removed filters-artistic-cubism.png 2007-05-28 Fixed Auto Follow Active Image by j.h 2007-04-21 lexa: fixed bug #420007
2010-04-18 ude: changed help-id: old -> new 2007-09-05 ude: renamed to "Lens Flare"
We should keep information for creation, modifications in description, update to new release (because when checking xml files for a new release, we must see immediately whether a file has been updated without reading it). So, in your list, we should keep:
2007-04-21 lexa: fixed bug #420007 2007-05-28 Fixed Auto Follow Active Image by j.h 2006-06-17 added a para en;fr for default image size by j.h 2006-07-03 changed the note by j.h
2008-12-29 j.h: link to File-references to be fixed 2007-10-17 j.h: updated to v2.4 (comment) 2006-08-08: created by scb; example by j.h 2008-12-29 j.h: rev. v2.6
(Sorry, I am mentioned all along because I used "section history" already in that way.).
So, we have a date and we can refer to the log for details easily.
HTML output cat be suppressed with a simple template:
If is not used for html, you will have useless tags in xml files. What is better, (or worse), "section history" or ?
Bye,
Julien
