Two patches for the vala binding.
Two patches for the vala binding. Damien de Lemeny-Makedone 21 May 11:00
  Two patches for the vala binding. Damien de Lemeny-Makedone 21 May 13:18
2010-05-21 11:00:54 UTC (almost 15 years ago)
bindings/vala: Fix deprecated syntax * s/weak/unowned in gegl-0.0.vapi, babl-0.0.vapi 2 files changed, 41 insertions(+), 41 deletions(-)
bindings/vala/gegl-0.0.vapi: Add Path, Buffer.linear_open, Buffer.linear_close
1 files changed, 38 insertions(+), 0 deletions(-)
I also join a vala version of the gegl-paint example.
gegl-paint: gegl-paint-source gcc -o gegl-paint gegl-paint.c gegl-view.c `pkg-config --libs --cflags gegl` `pkg-config --libs --cflags gtk+-2.0`
gegl-paint-source: gegl-paint.vala gegl-view.vala valac -C gegl-paint.vala gegl-view.vala --pkg=gtk+-2.0 --vapidir=../vapi --pkg=gegl-0.1 --pkg=babl-0.1 --thread
Regards.
Damien
2010-05-21 13:18:38 UTC (almost 15 years ago)
I'd also suggest to rename .vapi files against pkg-config files (no version number),
valac --pkg option makes use of pkg-config names to link to the correct libraries.
babl-0.0.vapi -> babl.vapi gegl-0.0.vapi -> gegl.vapi
Crap, I didn't triple-check this. Replace 0.1 with 0.0 and use path to gegl/bindings/vala as vapidir :
valac -C gegl-paint.vala gegl-view.vala --pkg=gtk+-2.0 --vapidir=/gegl/bindings/vala --pkg=gegl-0.0 --pkg=babl-0.0 --thread
Damien
