Invalid XML for a few languages
10 of 12 messages available
Invalid XML for a few languages Roman Joost 11 May 04:08
  201005112025.41081.ude88@we... Ulf-D. Ehlert 11 May 20:25
   Invalid XML for a few languages Roman Joost 13 May 11:18
    201005131849.49082.ude88@we... Ulf-D. Ehlert 13 May 18:49
     Invalid XML for a few languages Roman Joost 17 May 02:16
    Invalid XML for a few languages Kolbjørn Stuestøl 13 May 18:52
     Invalid XML for a few languages Roman Joost 14 May 03:23
      Invalid XML for a few languages Kolbjørn Stuestøl 14 May 21:40
       Invalid XML for a few languages Michael Schumacher 14 May 22:25
        Invalid XML for a few languages Kolbjørn Stuestøl 15 May 10:35
         Invalid XML for a few languages Michael Schumacher 17 May 20:17
          Invalid XML for a few languages Kolbjørn Stuestøl 18 May 18:27
Roman Joost
2010-05-11 04:08:48 UTC (almost 15 years ago)
I've tried to built the HTML again for all languages and stumbled over a few error messages. It looks like the system creates invalid XML for a few languages which leads to errors. Esp unmaintained languages are affected (sv, es, zh_CN).
It seems to me, that there is no easy way anymore to validate XML?
If the errors occur only because of unmaintained languages, I would suggest to remove them from building HTML.
Cheers,
Roman Joost
2010-05-13 11:18:54 UTC (almost 15 years ago)
Hi Ulf,
On Tue, May 11, 2010 at 08:25:21PM +0200, Ulf-D. Ehlert wrote:
Roman Joost (Tuesday, 11. May 2010)
Do you want to release new HTML packages?
I'm currently only updating docs.gimp.org sporadically.
Please try again when I have pushed the bugfixes.
cheers! I will!
That's IMHO a good idea even if you can successfully build these HTML packages.
Yeh well. Because the content doesn't change, I think it's not necessary to rebuild the same content again. I assume that somehow the content will become deprecated if no one updates it anyways ...
Cheers,
Kolbjørn Stuestøl
2010-05-13 18:52:54 UTC (almost 15 years ago)
Roman Joost skreiv:
Hi Ulf,
cheers! I will!
The http://docs.gimp.org/2.6/no/ is not updated and should be deleted. The language code "no" is not "legal" anymore. Instead http://docs.gimp.org/2.6/nn/ should be created from the "nn" po files which by the time of writing is 100% translated. ("nn" is the official language code used for Norwegian Nynorsk, "Norsk, nynorsk" in Norwegian).
Kolbjoern
Roman Joost
2010-05-14 03:23:09 UTC (almost 15 years ago)
Hi Kolbjoern,
I've updated the instance and the website. This should be solved ...
Cheers,
Kolbjørn Stuestøl
2010-05-14 21:40:29 UTC (almost 15 years ago)
Roman Joost skreiv:
Hi Kolbjoern,
Cheers,
Thank you Roman.
But http://www.gimp.org/docs/ is still linking to .../2.6/no/ instead of .../2.6/nn/.
To get tthe link text like the others on this side, the "nn" text should be "Norwegian (Norsk, nynorsk)".
How to fix these?
In my opinion this is not a new release or something like this, but an error correction.
Kolbjoern
2010-05-14 22:25:52 UTC (almost 15 years ago)
How to fix these?
By changing the docs/index.htrw file in the gimp-web module:
commit 09571f9c0c8162d3569ace213e808b837ac3a1c5 Author: Michael Schumacher
Date: Fri May 14 22:22:34 2010 +0200
Change Norwegian docs link from 'no' to 'nn'
HTH, Michael
Kolbjørn Stuestøl
2010-05-15 10:35:15 UTC (almost 15 years ago)
Michael Schumacher skreiv:
How to fix these?
HTH, Michael
Thank you, Michael.
Further works?
http://git.gnome.org/browse/gimp-web/commit/ (and others) says you have committed the correction 12 hours ago, but no changes in gimp.org/docs/. Kolbjoern
Roman Joost
2010-05-17 02:16:04 UTC (almost 15 years ago)
Hi Ulf,
On Thu, May 13, 2010 at 06:49:48PM +0200, Ulf-D. Ehlert wrote:
If you give us a warning a few days before you update, we get the chance to push any missing translations. :-)
Ah well, not ignoring your request, but usually I've updated the online documentation every day or week or so. I would like to do that more often, which also means that the online documentation can have a few errors. It is the current snapshot of the ongoing translation/development.
So... for me it would be much easier if people let me know if something weird happens on docs.gimp.org. I'll try to check first before/after updating the online docs to avoid any major trouble.
I would have liked some kind of a buildbot approach, to make automated builds/updates after each push (or nightly whatever). But unfortunately the server is not going to make it, as far as I know.
Cheers,
2010-05-17 20:17:47 UTC (almost 15 years ago)
On 15.05.2010 10:35, Kolbjørn Stuestøl wrote:
Further works?
No. Now we'll wait.
The website always updates when you least expect it.
Regards, Michael
Kolbjørn Stuestøl
2010-05-18 18:27:59 UTC (almost 15 years ago)
Further works?
No. Now we'll wait.
Regards, Michael
Thank you, Michael.
I'll wait. Perhaps checking the site from time to time. Kolbjoern
