help:how to use GIMP to Parse PSD
help:how to use GIMP to Parse PSD Hades 30 Apr 09:17
  help:how to use GIMP to Parse PSD Michael Schumacher 30 Apr 09:45
  help:how to use GIMP to Parse PSD Alexandre Prokoudine 02 May 07:45
Hades
2010-04-30 09:17:51 UTC (almost 15 years ago)
Dear
If I want use GIMP to parse psd file(photoshop file format) in my program(C++ or Java),how should I do?
And I Have to read which part of GIMP SourceCode?
Thanks
best wishes
Hades 2010-04-30
2010-04-30 09:45:28 UTC (almost 15 years ago)
Von: "Hades"
PSD support in GIMP is based on an old version of the PSD format specification (the current one is locked away in the Adobe Photoshop SDK and can't be used with Free software, in my opinion).
There's also a number of known bugs in regard to PSD support, i.e. do not expect that any program will be able to read some PSD files written by GIMP.
http://git.gnome.org/browse/gimp/tree/plug-ins/file-psd
When reusing code from there, pay attention to the license:
the GNU General Public License Version 3 is what grants you permission to use the code in the first places, but also enforces the rules you'll have to follow. See http://www.gnu.org/licenses/quick-guide-gplv3.html for an introduction.
Regards, Michael
2010-05-02 07:45:57 UTC (almost 15 years ago)
On 4/30/10, Hades wrote:
Dear
Hello dear,
Apart from using GIMP's code you might like investigating other possibilities like libpsd and code.goole.com projects [2].
[1] http://sourceforge.net/projects/libpsd/ [2] http://code.google.com/hosting/search?q=psd&projectsearch=Search+projects
Alexandre
