square brushes
square brushes Alexandre Prokoudine 24 Apr 17:29
  square brushes Joao S. O. Bueno 26 Apr 03:17
   square brushes Liam R E Quin 26 Apr 04:59
2010-04-24 17:29:36 UTC (almost 15 years ago)
square brushes
An interesting issue was brought up by a user. It really isn't easy defining a square brush with a particular length of a side. For example, creating a square brush with a side exactly 2px large.
Could anything sensible be done about that? (Apart from telling users they don't really need 2px large square brushes, that is :))
Alexandre
Joao S. O. Bueno
2010-04-26 03:17:23 UTC (almost 15 years ago)
square brushes
Hi Prokoudine --
Right now, I am afraid it would not be easy - and I don't see how someone could go and work on change the measurement on "radius" for generated brushes to "side" when the shape is square.
However, a way to create a 2px square brush would be to make a 2x2px selection in agrayscale image, , copy it and edit-> paste as -> brush...
It would be easy to have that as a plug-in, but I can't think of a way such a plug-in would not clutter the menus.
However, now that I mentioned it, ther is a File -> create[...] action that create a brush. (create brush from phrase)
Maybe we could come along with some more 2 or 3 ideas to populate a file->create->brush... submenu. There an "Exact square brush..." could easily fit.
Let's see whatthe maintainers and Peter have to say on sucha submenu, and throw in some ideas on whatthe other entries could be.
regards,
js ->
Alexandre
_
Liam R E Quin
2010-04-26 04:59:57 UTC (almost 15 years ago)
square brushes
If, for a polygonal brush, there was a read-only message displayed, sides: 4px
that might be useful. However, if aspect ratio is not 1:1 I don't know what would be useful, e.g. for a squashed pentagon...
Liam
