Success-return-value
Success-return-value Oliver Bandel 22 Apr 15:46
  Success-return-value Sven Neumann 22 Apr 20:29
Oliver Bandel
2010-04-22 15:46:44 UTC (about 15 years ago)
is there a convention for return values in Gimp, which says: on success return TRUE or a value, and on fauilure FALSE or NULL?
Or can it be different at different sources, rather be a taste of the one who developped something?
Ciao, oliver
2010-04-22 20:29:32 UTC (about 15 years ago)
On Thu, 2010-04-22 at 15:46 +0200, Oliver Bandel wrote:
is there a convention for return values in Gimp, which says: on success return TRUE or a value, and on failure FALSE or NULL?
That is the convention, yes.
Or can it be different at different sources, rather be a taste of the one who developed something?
Well, there is lots of plug-in code that follows different coding styles and conventions. We apply the GIMP coding style on all new files, but there is still cruft in some corners of the code-base that has not been cleaned up yet. So you might find code that uses a different convention for return values.
