Why doesn't --enable-debug turn off optimization?
2 of 3 messages available
Why doesn't --enable-debug turn off optimization? Omari Stephens 15 Apr 18:56
  Why doesn't --enable-debug turn off optimization? Oliver Bandel 16 Apr 00:42
  201004160128.29144.daniel.h... Daniel Hornung 16 Apr 01:28
Omari Stephens
2010-04-15 18:56:53 UTC (about 15 years ago)
It seems like running configure with --enable-debug should also disable optimization; otherwise you end up with a bunch of magically inlined or optimized-out function calls, optimized-out variables, and confusing execution order.
Thoughts?
--xsdg
Oliver Bandel
2010-04-16 00:42:25 UTC (about 15 years ago)
Thoughts?
AFAIK gcc inlines starting with -O3 and higher.
I'm not sure what happens with optimizations with less than -O3, but maybe the result is not that extremely chaotic.
Completely disabling optimizations would make sure that debugging might be possible easily.
Ciao, Oliver
