Mouse icons
Mouse icons Nery Chucuy 01 Apr 05:23
  Mouse icons LightningIsMyName 01 Apr 13:13
   Mouse icons Nery Chucuy 08 Apr 05:37
Nery Chucuy
2010-04-01 05:23:55 UTC (over 15 years ago)
Mouse icons
Hello guys, I've seen that Gimp has very colorful and nice mouse icons. I wonder what do you use to make that possible? also, would you point me into the right direction where that code is placed at your tree?
Thanks in advance,
-idesisnery
LightningIsMyName
2010-04-01 13:13:24 UTC (over 15 years ago)
Mouse icons
Hello Nery,
You can get custom cursors using GDK. Take a look at this link:
http://library.gnome.org/devel/gdk/stable/gdk-Cursors.html#id615496 In the same way they create a cursor from bitmap data in that example, you can create a cursor from a pixbuf (using gdk_cursor_new_from_pixbuf ()), and the pixbuf will be create from a file (using gdk_pixbuf_new_from_file () on an image file)
All the information you need is located in the GDK documentation: GDK Pixbuf documentation -
http://library.gnome.org/devel/gdk-pixbuf/stable/index.html GDK documentation - http://library.gnome.org/devel/gdk/stable/index.html
Hope this helps =) LightningIsMyName
On Thu, Apr 1, 2010 at 6:23 AM, Nery Chucuy wrote:
Hello guys, I've seen that Gimp has very colorful and nice mouse icons. I wonder what do you use to make that possible? also, would you point me into the right direction where that code is placed at your tree? Thanks in advance,
-idesisnery
Nery Chucuy
2010-04-08 05:37:41 UTC (over 15 years ago)
Mouse icons
thank you!
would that work for a Windows environment?
2010/4/1 LightningIsMyName
Hello Nery,
into
-idesisnery
